New BETA test version - 7.1.0
Wed Nov 23, 2016 11:14 am
I'm looking for testers for a new beta version - https://github.com/FlyingDiver/Indigo-M ... tag/v7.1.0
This pre-release uses a newer version of the MyQ API. This cuts down on the number of calls to their servers needed for normal operations.
I'm also logging some additional information about each device found that may help to get light control working. I'm especially looking for people who have MyQ enabled lights to run this version.
If you do install it, please enable debug logging, then restart the plugin. Post the getDevices output of the log here (use code tags). It'll look something like this:
   MyQ Debug                       getDevices: 3 Devices
   MyQ Debug                       getDevices: MyQDeviceTypeId = 1, MyQDeviceTypeName = Gateway, DeviceId = 1700492096
   MyQ Debug                          "online" = "True"
   MyQ Debug                          "enumeraterequired" = "0"
   MyQ Debug                          "learnmodestate" = "0"
   MyQ Debug                          "addedtime" = "2016-06-14 17:46:46"
   MyQ Debug                          "devices" = "1700492105,1700492104"
   MyQ Debug                          "numdevices" = "2"
   MyQ Debug                          "desc" = "Cape Harbour"
   MyQ Debug                          "fwver" = "4.2"
   MyQ Debug                          "name" = "GW0100084678"
   MyQ Debug                          "deviceName" = "GW0100084678"
   MyQ Debug                          "customerName" = "GW0100084678"
   MyQ Debug                          "ishomekitcapable" = "False"
   MyQ Debug                          "ishomekitactive" = "False"
   MyQ Debug                          "IsFirmwareCurrent" = "True"
   MyQ Debug                       getDevices: MyQDeviceTypeId = 2, MyQDeviceTypeName = GarageDoorOpener, DeviceId = 1700492105
   MyQ Debug                          "gatewayID" = "1700492096"
   MyQ Debug                          "desc" = "Large Garage Door"
   MyQ Debug                          "doorstate" = "2"
   MyQ Debug                          "addedtime" = "1465944621047"
   MyQ Debug                          "isunattendedopenallowed" = "1"
   MyQ Debug                          "isunattendedcloseallowed" = "1"
   MyQ Debug                          "name" = "CG0838484818"
   MyQ Debug                          "customerName" = "CG0838484818"
   MyQ                             GarageDoorOpener Large Garage Door is Closed
   MyQ Debug                       getDevices: MyQDeviceTypeId = 2, MyQDeviceTypeName = GarageDoorOpener, DeviceId = 1700492104
   MyQ Debug                          "desc" = "Small Garage Door"
   MyQ Debug                          "addedtime" = "1465944585487"
   MyQ Debug                          "name" = "CG0838484821"
   MyQ Debug                          "customerName" = "CG0838484821"
   MyQ                             GarageDoorOpener Small Garage Door is Closed
Wed Nov 23, 2016 1:11 pm
Bollar offline
Re: New BETA test version - 7.1.0
I don't have any MyQ lights, but here you go:
   Started plugin "MyQ 7.1.0"
   MyQ                             Starting MyQ
   MyQ Debug                       updateFrequency = 86400.0
   MyQ Debug                       statusFrequency = 86400.0
   MyQ Debug                       Range Rover: Device Version is up to date
   MyQ Debug                       Tesla: Device Version is up to date
   MyQ                             Checking for updates...
   MyQ Debug                       Plugin version detected: 7.1.0
   MyQ Debug                       Current version is: 7.1.0
   MyQ Debug                       Getting latest release from FlyingDiver/Indigo-MyQ...
   MyQ Debug                       GET /repos/FlyingDiver/Indigo-MyQ/releases/latest
   MyQ Debug                       HTTP 200 OK
   MyQ Debug                       Latest release is: 7.0.1
   MyQ                             No updates are available
   MyQ Debug                       myqLogin: response = <Response [200]>
   MyQ Debug                       myqLogin: content = {"UserId":0,"SecurityToken":"xxx","ReturnCode":"0","ErrorMessage":"","BrandId":2,"BrandName":"Chamberlain","RegionId":1}
   MyQ Debug                       myqLogin: Success, Brand = Chamberlain, SecurityToken = xxx
   MyQ Debug                       getDevices: 4 Devices
   MyQ Debug                       getDevices: MyQDeviceTypeId = 16, MyQDeviceTypeName = Gateway WGDO DC, DeviceId = 218505227
   MyQ Debug                          "addedtime" = "2016-05-28 22:52:14"
   MyQ Debug                          "devices" = "285286819"
   MyQ Debug                          "numdevices" = "1"
   MyQ Debug                          "desc" = "Home Range Rover"
   MyQ Debug                          "fwver" = "2.8"
   MyQ Debug                          "name" = "GW0E000093DE"
   MyQ Debug                          "deviceName" = "GW0E000093DE"
   MyQ Debug                          "customerName" = "GW0E000093DE"
   MyQ Debug                       getDevices: MyQDeviceTypeId = 16, MyQDeviceTypeName = Gateway WGDO DC, DeviceId = 1700458909
   MyQ Debug                          "addedtime" = "2016-05-28 21:01:10"
   MyQ Debug                          "devices" = "1700458910"
   MyQ Debug                          "desc" = "Home Tesla"
   MyQ Debug                          "name" = "GW0E00031426"
   MyQ Debug                          "deviceName" = "GW0E00031426"
   MyQ Debug                          "customerName" = "GW0E00031426"
   MyQ Debug                       getDevices: MyQDeviceTypeId = 17, MyQDeviceTypeName = Garage Door Opener WGDO, DeviceId = 285286819
   MyQ Debug                          "gatewayID" = "218505227"
   MyQ Debug                          "desc" = "Range Rover"
   MyQ Debug                          "addedtime" = "1464493936767"
   MyQ Debug                          "name" = "CG086E0127BC"
   MyQ Debug                          "deviceName" = "CG086E0127BC"
   MyQ                             Garage Door Opener WGDO Range Rover is Closed
   MyQ Debug                       getDevices: MyQDeviceTypeId = 17, MyQDeviceTypeName = Garage Door Opener WGDO, DeviceId = 1700458910
   MyQ Debug                          "gatewayID" = "1700458909"
   MyQ Debug                          "desc" = "Tesla"
   MyQ Debug                          "doorstate" = "1"
   MyQ Debug                          "addedtime" = "1464487270950"
   MyQ Debug                          "name" = "CG086E06284C"
   MyQ Debug                          "deviceName" = "CG086E06284C"
   MyQ                             Garage Door Opener WGDO Tesla is Open
Wed Nov 23, 2016 2:41 pm
OK, that's pretty much as expected. And those other devices are controllers, you can see the same info (pretty much) for those devices as for my gateway.
