Nov 27, 2016, 5:35:18 PM
MyQ Debug actionControlDevice: "North Door" Toggle
MyQ Error Error in plugin execution ExecuteAction:
File "plugin.py", line 187, in actionControlDevice
AttributeError: 'RelayDevice' object has no attribute 'isOn'
dougkillmer wrote:Correct. It was opened by car remote.
When I try to open with Indigo, I get the following error:
- Code: Select all
Nov 27, 2016, 5:38:04 PM
MyQ Checking for updates...
MyQ Debug Plugin version detected: 7.0.1
MyQ Debug Current version is: 7.0.1
MyQ Debug Getting latest release from FlyingDiver/Indigo-MyQ...
MyQ Debug GET /repos/FlyingDiver/Indigo-MyQ/releases/latest
MyQ Debug HTTP 200 OK
MyQ Debug Latest release is: 7.0.1
MyQ No updates are available
wideglidejrp wrote:What is the model 9000? The liftmaster site does not show it?
lanbrown wrote:I guess I should look into seeing if I could tap into the door sensor on each garage door as they are both tied into the alarm system. Might be easier than adding a battery powered Z-wave device into the network.
lanbrown wrote:Given that it is just two wires; it is either just an open or closed circuit, so it should be fairly simple to get setup in Indigo.
