12/16/2020 - MyQ Broken again?
Wed Dec 16, 2020 5:22 pm
My system can't connect to the MyQ servers, and there's a bunch of traffic on the GitHub repository that the plugin is based on. I'm keeping an eye on it, and will update the plugin when/if a solution is found.
https://github.com/arraylabs/pymyq/issu ... -747096541
Wed Dec 16, 2020 7:16 pm
Re: 12/16/2020 - MyQ Broken again?
And it's fixed again. Release 7.5.2 on the plugin store.
Wed Dec 16, 2020 10:13 pm
As always, thanks for your diligence. Less than 2 hours from problem identification to published fix. Setting the bar kinda high there Joe.
Fri Dec 18, 2020 3:52 pm
colovin offline
THANK YOU!
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
Thu Aug 26, 2021 1:10 pm
colovin offline
Is there something going on with the API again? Been working flawlessly until a couple of days ago. I think I have the latest plug-in 7.5.3.
Thu Aug 26, 2021 1:31 pm
Yes, it breaks regularly. I think there's an update to the underlying library in the works. I should be able to update the plugin soon.
Thu Aug 26, 2021 2:13 pm
colovin offline
Great! This last one lasted awhile going by the date of my previous post, 12/20. I don't think mine has been out since then.
Sun Sep 26, 2021 12:32 pm
wideglidejrp offline
MyQ is not working for me. I am using MacOS 11.6 and 7.7.1 of the plugin. If I turn on debugging I get the following:
John R Patrick
Author of
Home Attitude
Sun Sep 26, 2021 1:41 pm
Did you restart the plugin?
Sun Sep 26, 2021 2:28 pm
Yes, restarted plugin, restarted Indigo restarted iMac.
John R Patrick
Author of
Home Attitude
Sun Sep 26, 2021 2:47 pm
colovin offline
Has the plugin been working? Mine still hasn't worked since my 8/26 post. I'm running v7.5.3 which is still the latest shown in the plugin store.
Sun Sep 26, 2021 3:08 pm
Not sure of exact date but plugin was working in the Spring with 7.5.3. I was away for the summer and just tried it again this month. Have not been able to get it working.
John R Patrick
Author of
Home Attitude
Sun Sep 26, 2021 3:22 pm
colovin offline
I just found the github releases page which had 7.7.1 on it. 7.5.3 from the plugin store was released 1/6/21 so it's really old. I just installed 7.7.1 so I'll see what that does. Sounds like it may not be functional anymore. I miss MyQ not working, I've got it linked to my mailbox. When you open the mail box (under certain conditions) it opens the garage door. Great for when I'm coming in from running. Now I have to walk all the way up to the door and punch in a code. Oh the inconvenience!!! :-) I'd love to get it going again.
Mon Sep 27, 2021 1:05 pm
colovin offline
OK, 7.7.1 is giving me this error:
MyQ Warning Unknown writing to subprocess: ''Plugin' object has no attribute 'pymyq''
Mon Sep 27, 2021 1:11 pm
Make sure your configuration for the plugin is correct, then turn on detailed debugging and restart the plugin.
