No pytz
Fri Aug 30, 2019 5:37 pm
bjmouton offline
Re: No pytz
Well, all that box does is run Indigo & it's been doing it for quite some time without any issues until now.
Know what they say about if it's not broken, don't fix it. I actually have been contemplating upgrading to a newest MAC Mini, so I suppose the time is finally right.
Hopefully all will go well once I get running with a new box.
I truly appreciate your quick responses & willingness to assist.
Tue Sep 03, 2019 5:15 pm
bjmouton offline
Re: No pytz
I have upgraded my home automation box. I am now able to launch the config box and enter my Twilio account info (copied & pasted field text from Twilio web page), but it is not accepting it. Any suggestions?
Screen Shot 2019-09-03 at 18.03.32.png (39.43 KiB) Viewed 414 times
Screen Shot 2019-09-03 at 18.04.37.png (60.92 KiB) Viewed 414 times
Tue Sep 03, 2019 5:57 pm
Re: No pytz
Debug log please.
Tue Sep 03, 2019 6:13 pm
bjmouton offline
Re: No pytz
Enabling plugin "Twilio 7.2.0"
   Starting plugin "Twilio 7.2.0" (pid 1258)
   Started plugin "Twilio 7.2.0"
   Twilio                          Starting Twilio
   Twilio Warning                  accountSID and/or authToken not set
   Twilio Error                    Error in plugin execution runConcurrentThread:
  File "plugin.py", line 74, in runConcurrentThread
AttributeError: 'Plugin' object has no attribute 'twilioClient'
   Twilio Error                    plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
   Twilio Error                    Error in plugin execution UiValidate:
  File "plugin.py", line 155, in validatePrefsConfigUi
KeyError: key updateFrequency not found in dict
Tue Sep 03, 2019 6:21 pm
Re: No pytz
Tue Sep 03, 2019 6:39 pm
bjmouton offline
Re: No pytz
SUCCESS!!
Thank you very much for your assistance & patience!
Billy
Fri Sep 06, 2019 10:20 pm
bjmouton offline
Re: No pytz
Worked OK for few days, then quit working for no apparent reason. Log capture :
  Twilio Error                    Error in plugin execution ExecuteAction:
  File "plugin.py", line 256, in sendSMSAction
  File "plugin.py", line 265, in sendSMS
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Twilio.indigoPlugin/Contents/Server Plugin/twilio/rest/api/v2010/account/message/__init__.py", line 92, in create
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Twilio.indigoPlugin/Contents/Server Plugin/twilio/base/version.py", line 205, in create
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Twilio.indigoPlugin/Contents/Server Plugin/twilio/base/version.py", line 47, in request
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Twilio.indigoPlugin/Contents/Server Plugin/twilio/base/domain.py", line 46, in request
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Twilio.indigoPlugin/Contents/Server Plugin/twilio/rest/__init__.py", line 124, in request
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/Twilio.indigoPlugin/Contents/Server Plugin/twilio/http/http_client.py", line 68, in request
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/sessions.py", line 587, in send
  File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/adapters.py", line 481, in send
ConnectionError: HTTPSConnectionPool(host='api.twilio.com', port=443): Max retries exceeded with url: /2010-04-01/Accounts/ACea1e6926097bb7b2098a988e4d6fbff4/Messages.json (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x10bf15190>: Failed to establish a new connection: [Errno 8] nodename nor servname provided, or not known',))
Sat Sep 07, 2019 6:00 am
Re: No pytz
That looks like some sort of DNS lookup error. Were you having internet connection issues?
Sat Sep 07, 2019 6:42 am
bjmouton offline
Re: No pytz
That was it. I had been running the box on my desktop via wifi only, I then relocated it to my A/V rack where it normally resides, when I did so I plugged in the wired ethernet connection and that connection did not have DNS servers specified.
Once again, thanks for your help!
