Bug Reports and Feature Requests
Tue May 08, 2018 5:23 pm
Re: Bug Reports and Feature Requests
jay (support) wrote:
You've been to Antarctica?
Antarctic waters, cruise out of Buenos Aires. Big ship, so no excursions to the icecap. We're looking at doing another one this winter a smaller ship that does let you get onto the ice.
Thu Aug 23, 2018 3:13 pm
mundmc offline
Any sense on this impacting the current implementation?
“Starting June 26, 2019, our REST API will only support connections that use TLS v1.2 and strong cipher suites. Support for TLS v1.0, v1.1 and weak cipher suites will be removed at that time. Customers running older operating systems or legacy network software may need to upgrade their systems to be compatible with these changes.
Note: This was originally announced May 2018 and postponed from June 2018 to June 2019.”
Great plugin, btw
Thu Aug 23, 2018 3:25 pm
eme jota ce offline
Great plugin, btw
The email I received from Twilio also said:
You are receiving this notice because our logs show your account is connecting to our REST API using one of the protocols or cipher suites that will be deprecated in June, 2019. Therefore, action is required on your part to ensure your Twilio service is not interrupted.
Thanks again for this great plugin.
Thu Aug 23, 2018 4:02 pm
I got the same email today.
I'll do some checking on this. I think I can add some code to the plugin to test if your system is compatible and throw a warning if not.
Thu Aug 23, 2018 4:22 pm
Sadly, without code changes users will have to be running High Sierra or later for this to be resolved since the bug is in Apple's Python install on previous OS versions. The workaround is to use curl (it doesn't use the ancient openssl library) rather than requests. It totally sucks, but I seriously doubt Apple is going to patch older Python installs to fix the problem... :(
Thu Aug 23, 2018 4:25 pm
I have no intention of rewriting the plugin to use curl. ;)
I thought Sierra was OK. That's what I'm running and I didn't have the GitHub issues. I haven't actually tested Twilio yet.
Thu Aug 23, 2018 5:30 pm
I'm pretty sure that Sierra was broken too. You can tell by running:
python -c "import ssl; print ssl.OPENSSL_VERSION"
If it comes back with:
 OpenSSL 0.9.7
or
 OpenSSL 0.9.8
then it's broken. I don't think I have any Macs that have a working Sierra install at the moment.
It sucks because your choice is to either have a broken Python SSL, or a broken FTDI driver. Sometimes I hate Apple.
[EDIT] Matt just verified that Sierra is still using a pre 1.0 version of OpenSSL (which is where support for TLS 1.1+ was added). So Sierra is broken.
Mon Sep 10, 2018 12:59 pm
mundmc offline
This just in around 2PM today after restarting plugin:
   Twilio Error                    checkMessages: twilioClient.messages.delete() error: HTTP 404 error: Unable to delete record: The requested resource /2010-04-01/Accounts/ACfb7a313b10da4ac2c4f467e0361bdd3d/Messages/MM44635b85002d4a38b81edd80a7653af9.json was not found
  File "plugin.py", line 380, in checkMessages
    self.twilioClient.messages(message.sid).delete()
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Twilio.indigoPlugin/Contents/Server Plugin/twilio/rest/api/v2010/account/message/__init__.py", line 326, in delete
    return self._version.delete('delete', self._uri)
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Twilio.indigoPlugin/Contents/Server Plugin/twilio/base/version.py", line 124, in delete
    raise self.exception(method, uri, response, 'Unable to delete record')
TwilioRestException: HTTP 404 error: Unable to delete record: The requested resource /2010-04-01/Accounts/ACfb7a313b10da4ac2c4f467e0361bdd3d/Messages/MM44635b85002d4a38b81edd80a7653af9.json was not found
   Twilio Error                    checkMessages: twilioClient.messages.delete() error: HTTP 404 error: Unable to delete record: The requested resource /2010-04-01/Accounts/ACfb7a313b10da4ac2c4f467e0361bdd3d/Messages/MMd1b1a25b7c01407daf0921dee98864e1.json was not found
TwilioRestException: HTTP 404 error: Unable to delete record: The requested resource /2010-04-01/Accounts/ACfb7a313b10da4ac2c4f467e0361bdd3d/Messages/MMd1b1a25b7c01407daf0921dee98864e1.json was not found
   Twilio Error                    checkMessages: twilioClient.messages.delete() error: HTTP 404 error: Unable to delete record: The requested resource /2010-04-01/Accounts/ACfb7a313b10da4ac2c4f467e0361bdd3d/Messages/MMf16253a9c1d54f87a283b913b99015fe.json was not found
TwilioRestException: HTTP 404 error: Unable to delete record: The requested resource /2010-04-01/Accounts/ACfb7a313b10da4ac2c4f467e0361bdd3d/Messages/MMf16253a9c1d54f87a283b913b99015fe.json was not found
It otherwise appears to be working though.
Mon Sep 10, 2018 2:21 pm
That’s a bug report. It needs to go on GitHub.
What prompted the restart? I suspect that the internal list of messages got out of sync due to the restart. Probably not repeatable but I should do a better job of handling that error.
