How to configure Harmony Hub Plugin
Fri Aug 18, 2017 6:31 am
thedon offline
I can't figure out to configure this.... The plugin option is just disable and reload.
Fri Aug 18, 2017 6:32 am
Re: How to configure Harmony Hub Plugin
You need to create a device to represent the Harmony Hub. You'll need to know the IP address of the Hub to do that.
Fri Aug 18, 2017 7:13 am
thedon offline
I'm not getting the option to create a device....
Screen Shot 2017-08-18 at 9.13.25 AM.png (217.13 KiB) Viewed 2228 times
Fri Aug 18, 2017 7:17 am
Restart the plugin and then post that section of the event log.
Fri Aug 18, 2017 3:12 pm
thedon offline
Aug 18, 2017, 5:11:50 PM
Reloading plugin "Harmony Hub 7.1.2"
Starting plugin "Harmony Hub 7.1.2" (pid 208)
Harmony Hub Error Error in plugin execution InitializeMain:
File "plugin.py", line 9, in <module>
ImportError: No module named sleekxmpp
Stopping plugin "Harmony Hub 7.1.2" (pid 208)
Stopped plugin "Harmony Hub 7.1.2"
Fri Aug 18, 2017 3:33 pm
You need to install sleekxmpp. Read the ReadMe file.
Fri Aug 18, 2017 3:47 pm
thedon offline
Oh this might be a little advanced for me
Fri Aug 18, 2017 4:16 pm
Out of curiosity, why don't you include it? It looks to be pure python and is licensed MIT so those shouldn't be an issue...
Fri Aug 18, 2017 4:18 pm
Dunno. Maybe I should. Running a pip command line didn't seem to be all that big a deal. Maybe I'm wrong.
Fri Aug 18, 2017 5:08 pm
Well, remember, pip may not (probably not?) be installed. So then you have to install pip, then install sleekxmpp, etc. I really wish Apple installed pip - it would make things somewhat more predictable. For instance, consider the following AppleScript:
do shell script "sudo /usr/local/bin/pip install sleekxmpp" with administrator privileges
That works nicely, and prompts the user for the admin password (I'm pretty sure this is how PyCharm installs packages). That script presupposes that pip is installed, but a more complex script could detect if it was, and if not it could install pip first, then install the module.
Fri Aug 18, 2017 6:04 pm
Is that really any easier than cutting and pasting a command into Terminal? The ReadMe says:
Use pip to install sleekxmpp:
sudo pip install sleekxmpp
If you get an error not finding the pip command, do:
sudo easy_install pip
Now, maybe I should just include the package. I really don't think this is all that complicated. But I guess you know the user base better than I do.
Fri Aug 18, 2017 6:51 pm
Different Computers offline
Just to give a bit of perspective as someone who is barely comfortable on the command line:
I can easily understand how someone who has lived in the Mac ecosystem for their entire life would be turned off by having to fire up the terminal. I've learned how to get through most hitches the hard way, and it has been very frustrating--quite similar to the experience I've had with trying to run Linux, but just barely enough better for me to have persevered with the former and not with the latter.
I've got just enough skill to realize that when
$command
doesn't run, maybe I should try
$sudo command
before I ask how to fix the problem. But I'm by no means someone who understands the response that comes back when I try to install pillow with sudo and get a paragraph telling me maybe I should do it some other way.
Having all appropriately licensed dependencies for a plugin (not just HH, any plugin) install or check for installation when you run the plugin would be super awesome. And would go a long way toward making Indigo more accessible for more people.
Sat Aug 19, 2017 6:57 pm
thedon offline
Received this error
Screen Shot 2017-08-19 at 8.52.19 PM.png (218.76 KiB) Viewed 1991 times
Sat Aug 19, 2017 7:04 pm
Upgrade to version 7.2.0 of the plugin. I added sleekxmpp to the plugin bundle.
Sat Aug 19, 2017 8:17 pm
thedon offline
THANKS that worked
