How to set IP?
Thu Jun 29, 2017 4:04 am
Tsjompie offline
How to set IP?
Sorry I ask, but seem not able to find how to configure the IP address.
Anyone who can help me configuring that?
Thu Jun 29, 2017 6:23 am
Re: How to set IP?
Do you need help setting the IP address, or determining what it is so that you can fill in the field in the device settings dialog?
You can find the IP address for the hub using the Harmony app on your mobile device, or from the DHCP table in your router. In the Harmony App, make sure you're connected to the Hub. Then from the pull down menu (horizontal lines in top left corner), select "About", then "Versions". The Hub IP address in the fourth field (in the iOS app).
Thu Jun 29, 2017 7:13 am
Tsjompie offline
Re: How to set IP?
Got it!
