sleekxmpp install problems
Thu Dec 01, 2016 11:51 am
chasyori offline
  File "plugin.py", line 10, in <module>
ImportError: No module named sleekxmpp
2016-12-01 07:44:09.069 Application Stopping plugin "Harmony Hub 7.0.0" (pid 16786)
pip install sleekxmpp
Requirement already satisfied (use --upgrade to upgrade): sleekxmpp in /usr/local/lib/python2.7/site-packages
what am i doing wrong here?
Thu Dec 01, 2016 12:02 pm
Re: Harmony Hub plugin - Indigo 7
You have a non-standard Python install. You should be getting:
home:~ miniserver$ pip install sleekxmpp
Requirement already satisfied (use --upgrade to upgrade): sleekxmpp in /Library/Python/2.7/site-packages
If you installed Python using homebrew or ports or anything like that, remove it.
Thu Dec 01, 2016 12:05 pm
chasyori offline
Not sure how to do that
Thu Dec 01, 2016 12:12 pm
chasyori offline
get (0.0.11)
pip (8.1.2)
post (0.0.8)
public (0.0.33)
query-string (0.0.8)
request (0.0.8)
setuptools (23.0.0)
sleekxmpp (1.3.1)
wheel (0.29.0)
these packages are installed
Thu Dec 01, 2016 12:13 pm
Neither am I.
However, you can try this command to force pip to install it in the correct place. You probably have an environment variable set that's specifying the wrong place.
sudo pip install --root /Library/Python/2.7/ sleekxmpp
Thu Dec 01, 2016 12:14 pm
chasyori wrote:
get (0.0.11)
pip (8.1.2)
post (0.0.8)
public (0.0.33)
request (0.0.8)
setuptools (23.0.0)
sleekxmpp (1.3.1)
wheel (0.29.0)
Yes, but where?
Thu Dec 01, 2016 12:20 pm
chasyori offline
directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Thu Dec 01, 2016 12:24 pm
Please don't post just part of the command output. Post all of it. And use the CODE tags so it doesn't get line wrapped.
I've seen that warning as a part of a completely successful install. So it might not be an issue. Here's what I see on my system:
$ ls -la /Library/Python/2.7/
total 0
drwxr-xr-x   3 root  wheel   102 Jul 30 20:44 .
drwxr-xr-x   4 root  wheel   136 Sep 13 20:49 ..
drwxr-xr-x  53 root  wheel  1802 Nov 24 16:50 site-packages
$ ls -la /Library/Python/2.7/site-packages/
total 472
drwxr-xr-x  53 root  wheel   1802 Nov 24 16:50 .
drwxr-xr-x   3 root  wheel    102 Jul 30 20:44 ..
-rw-r--r--   1 root  wheel    119 Jul 30 21:36 README
drwxr-xr-x   9 root  wheel    306 Jun 30 16:28 Twisted-16.2.0-py2.7.egg-info
-rw-r--r--   1 root  wheel    185 Nov 17 06:30 easy-install.pth
drwxr-xr-x   8 root  wheel    272 Sep  4 05:25 holidays-0.4.1-py2.7.egg-info
-rw-r--r--   1 root  wheel  58549 Jan  5  2016 holidays.py
-rw-r--r--   1 root  wheel  44179 Sep  4 05:25 holidays.pyc
drwxr-xr-x   9 root  wheel    306 Jun 12 09:00 httplib2
drwxr-xr-x   7 root  wheel    238 Jun 12 09:00 httplib2-0.9.2-py2.7.egg-info
drwxr-xr-x  44 root  wheel   1496 Nov 24 16:50 num2words
drwxr-xr-x   7 root  wheel    238 Nov 24 16:50 num2words-0.5.4-py2.7.egg-info
drwxr-xr-x  34 root  wheel   1156 Nov 17 06:30 pip
drwxr-xr-x  10 root  wheel    340 Nov 17 06:30 pip-9.0.1.dist-info
drwxr-xr-x  32 root  wheel   1088 May 27  2016 requests
drwxr-xr-x   9 root  wheel    306 May 27  2016 requests-2.10.0.dist-info
drwxr-xr-x  26 root  wheel    884 May 27  2016 sleekxmpp
drwxr-xr-x   7 root  wheel    238 May 27  2016 sleekxmpp-1.3.1-py2.7.egg-info
drwxr-xr-x  19 root  wheel    646 Jun 12 09:00 twilio
drwxr-xr-x   8 root  wheel    272 Jun 12 09:00 twilio-5.4.0-py2.7.egg-info
drwxr-xr-x  35 root  wheel   1190 Jun 30 16:27 twisted
drwxr-xr-x   8 root  wheel    272 Jul 16 16:39 twisted_mqtt-0.2.3-py2.7.egg-info
Thu Dec 01, 2016 1:08 pm
Re: sleekxmpp install problems
I split this off into it's own thread.
This is not a plugin issue. It's a system configuration issue. I'm not sure what's happened recently, put we're getting a spate of these kinds of problems for Indigo in general and a number of plugins. I'm not sure if Indigo 7 is more susceptible than previous versions to alternate Python installs, or something else is going on.
From what I can tell, there's really only two solutions. First would be to get rid of any non-standard (not provided by Apple as part of the OS install) versions of Python. Alternatively, if there's a really good reason to have an additional version of Python installed, for use outside Indigo, then the user's going to need to know how to install packages into the location used by Apple's install of Python.
Thu Dec 01, 2016 1:59 pm
My guess is that it wasn't a problem because Indigo 6 wasn't using Python 2.7 - so having something else installing a different Python 2.7 didn't effect Indigo 6. But now, since we're using Python 2.7, everyone who (somehow) installed a rogue version of Python 2.7 is now having issues. I don't know why homebrew would so fubar the built-in Python install, but it's definitely not something we can deal with automatically.
Tue Jan 24, 2017 1:06 pm
Busta999 offline
Just for info.
I have spent the last few hours trying to get this Plugin up and running and going around in circles.
Basically can't get the Plugin running - Python install issues.
Not overly fused at this stage - about to bring up a new iMac to run Indigo and will build that install from scratch so hopefully will not have the issues recurring.
