FlyingDiver wrote:Update to v0.2.1, see if that fixes it.
Awesome, that did the trick! Thanks a lot!
FlyingDiver wrote:colinpartridge wrote:FlyingDiver wrote:Search the forums here, there's some other thread on installing Python 2.6 packages.
I'm in the middle of making dinner and can't look for it right now.
No Problem, just wanted to check. Installed pip 2.6 then sleekxmpp then requests module.
Looking forward to playing with this.
Colin
I don't use the requests module, but no harm installing it. Other plugins do.
Starting plugin "Harmony Hub 0.2.0" (pid 85404)
Harmony Hub Error Error in plugin execution InitializeMain:
File "plugin.py", line 13, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/HarmonyHub.indigoPlugin/Contents/Server Plugin/harmony/auth.py", line 10, in <module>
ImportError: No module named requests
colinpartridge wrote:Thats odd then because this showed up in the Events log
- Code: Select all
Harmony Hub Error Error in plugin execution UiValidate:
File "plugin.py", line 378, in parseConfig
KeyError: ('isAVActivity',)
FlyingDiver wrote:I actually do have code to force the state change when the plugin starts an activity, but it wasn't working right. I think I have that fixed now and it'll be in the next release.
autolog wrote:Hi Joe,
Another minor one - clicking on 'About Harmony Hub v0.2.1...' links to http://forums.indigodomo.com/viewtopic.php?f=177 which doesn't exist.
I think the link should go to FlyingDivers Plugins at http://forums.indigodomo.com/viewforum.php?f=177
or http://forums.indigodomo.com/viewtopic.php?f=177&t=16166 for the Harmony Hub thread.
FlyingDiver wrote:Please dump the raw config for each hub into the log, save them into different files, zip them up and email them to me. Email is joe@<forum name>.com.
You must have some devices or activities unlike any of mine with different config data. I need to fix the parser to handle them properly.
colinpartridge wrote:FlyingDiver wrote:Please dump the raw config for each hub into the log, save them into different files, zip them up and email them to me. Email is joe@<forum name>.com.
Standby caller it may be that my Hub firmware appears to different on the non responding units to the one that works.. Currently locked out of logitech's servers due to trying to access them with wrong password...apparently. Will check again once firmware is up to date.
Colin
FlyingDiver wrote:PS - I'm not asking for contributions, but if anyone REALLY wants to donate, take up a collection and get me another hub+remote. My testing is limited with the one I have because DW really doesn't like me mucking with the AV system when she's watching TV.
