Harmony Hub Won't Start
Fri Dec 23, 2016 8:40 am
Re: Harmony Hub Won't Start
Try:
sudo pip2.7 install sleekxmpp
If it says pip2.7 not found, try:
sudo pip install sleekxmpp
Fri Dec 23, 2016 10:03 am
maslett offline
Joe,
76WildwoodSt-Indigo-Server:~ 76wildwoodst$ sudo pip install sleekxmpp
Password:
sudo: pip: command not found
Fri Dec 23, 2016 2:19 pm
Then do this first, then the other:
sudo easy_install pip
Fri Dec 23, 2016 3:59 pm
maslett offline
That worked Joe, Thank you so much for your help. I look forward to getting the Harmony up and running. Merry Christmas
Fri Dec 23, 2016 4:53 pm
Albatros offline
I have had a similar problem, it installed sleekxmpp for python 2.6. PIP wasn't the right version. Maybe adjust the instal guides with the note that if people have problems with sleekxmpp.
I did:
1. If "sudo pip2.7 install sleekxmpp" is thats fine. If n't working than:
2 ." sudo easy_install pip" than
3. "sudo pip2.7 install sleekxmpp"
Fri Dec 23, 2016 7:15 pm
maslett offline
So HarmonyHib is now working but I think the install of Py2,7 Sleekxmmp has caused an issue with the Nest Plugin's by Chameleon. I am now getting version errors. Looks like thee maybe an incompatibilities.
Fri Dec 23, 2016 7:24 pm
I saw your other thread. That's definitely a Nest plugin or server error.
Fri Dec 23, 2016 7:44 pm
maslett offline
Joe, yes looks that way. It had been working fine. Looks like the update PY install may have caused an issue. Will let you know, Mark
Sat Dec 24, 2016 7:16 am
maslett offline
I reloaded the libraries and attachments from the plug-in menu and the Nest error messages have stopped. Mark
Tue Dec 27, 2016 11:25 pm
dnomode offline
I'm getting the following when trying to enable the plug in.
   Enabling plugin "Harmony Hub 7.1.0"
   Starting plugin "Harmony Hub 7.1.0" (pid 35667)
   Harmony Hub Error               Error in plugin execution InitializeMain:
  File "plugin.py", line 9, in <module>
ImportError: No module named sleekxmpp
   Stopping plugin "Harmony Hub 7.1.0" (pid 35667)
   Stopped plugin "Harmony Hub 7.1.0"
I ran:
Still getting the above error.
What am I missing?
Edmond
Wed Dec 28, 2016 7:11 am
dnomode wrote:
What am I missing?
The results of running the three commands above. Can't tell if they worked or not. If you ran them in the order you posted, then the first two probably failed. You need to run the "easy_install" command first, then one or the other of the "pip" commands.
Sun Jan 01, 2017 9:34 pm
dnomode offline
OK, I ran it the other way around. It gave me an error and I ran the second command with a -H flag. Please see below.
Edmonds-Mac-mini:~ edmond$ sudo easy_install pip
Searching for pip
Best match: pip 9.0.1
Adding pip 9.0.1 to easy-install.pth file
Installing pip script to /Library/Frameworks/Python.framework/Versions/2.7/bin
Installing pip3.5 script to /Library/Frameworks/Python.framework/Versions/2.7/bin
Installing pip3 script to /Library/Frameworks/Python.framework/Versions/2.7/bin
Using /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
Processing dependencies for pip
Finished processing dependencies for pip
Edmonds-Mac-mini:~ edmond$ sudo pip2.7 install sleekxmpp
The directory '/Users/edmondkloss/Library/Caches/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/Users/edmondkloss/Library/Caches/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already satisfied: sleekxmpp in /Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages
Edmonds-Mac-mini:~ edmond$ sudo -H pip2.7 install sleekxmpp
:cry: Im still getting the following when trying to start the plugin.
   Starting plugin "Harmony Hub 7.1.0" (pid 87511)
   Stopping plugin "Harmony Hub 7.1.0" (pid 87511)
What you think?
Edmond
Mon Jan 02, 2017 7:29 am
dnomode wrote:
What you think?
I think it's another case of a non-standard Python install messing things up. If you had a standard install, pip and sleekxmpp would have gotten installed to "/Library/Python/2.7/", which is where Indigo is expecting it to be. Instead, your version of Python is installing things to "/Library/Frameworks/Python.framework/Versions/2.7/".
Did you install a new/different version of Python using the installer from python.org? Or using homebrew or ports?
Please post the output of these commands:
which python
echo $PATH
Mon Jan 02, 2017 11:08 am
dnomode offline
I dont recall how I installed python.
Here is the output
Last login: Sun Jan  1 19:26:55 on ttys000
Edmonds-Mac-mini:~ edmond$ which python
/Library/Frameworks/Python.framework/Versions/2.7/bin/python
Edmonds-Mac-mini:~ edmond$ echo $PATH
/opt/local/bin:/opt/local/sbin:/Library/Frameworks/Python.framework/Versions/3.5/bin:/Library/Frameworks/Python.framework/Versions/2.7/bin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin
Mon Jan 02, 2017 12:10 pm
Looks like you installed both Python3.5 and Python2.7 using a non-Apple installer. This is not a Harmony Hub issue. It's a Python install issue. I honestly don't know how to fix that.
You could try forcing it to use the "normal" pip install:
sudo /usr/local/bin/pip install sleekxmpp
or
sudo /usr/local/bin/pip2.7 install sleekxmpp
It needs to do the install to "/Library/Python/2.7/site-packages".
Or you could just manually copy the files from "/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/site-packages" to "/Library/Python/2.7/site-packages".
