New Activity Devices available in Harmony Hub plugin
Mon Jun 17, 2019 8:42 am
Umtauscher offline
Re: New Activity Devices available in Harmony Hub plugin
Sadly this is not repeatable.
If I find something to reproduce, I will let you know, thanks.
Wed Oct 23, 2019 4:48 am
siclark offline
Hi flyingdiver
Unfortunately I'm getting the same issues now. The activity devices only update when used t turn on the activity. If unused remote or iOS app they remain out of sync.
It's replicable.
Wed Oct 23, 2019 5:27 am
It's replicable.
Then I need to see the logs. Make sure everything shows all activities off, then set debug logging, then turn on an activity. When they don't sync (give it a few seconds), post the log.
Wed Oct 23, 2019 6:14 am
siclark offline
Typically they are now responding as expected. I will try again later.
Wed Oct 23, 2019 6:28 am
If you can get it to reproduce the error with logging, please open an issue here and include the log: https://github.com/FlyingDiver/Indigo-Harmony/issues
