plugin error, ReceivedBroadcast
Mon Sep 26, 2022 3:26 pm
stewkenly offline
I see this error popping up in my logfile now. It does this with all locks, regardless of brand I've just learned.
   Z-Wave                          received "Front Door Lock" status update unlocked (manually)
   Z-Wave Lock Manager             Status: Door unlocked manually [Node: 26]
   Z-Wave Lock Manager Error       Error in plugin execution ReceivedBroadcast:
  File "plugin.py", line 438, in zwaveCommandReceived
  File "plugin.py", line 854, in updateState
type: (26,)
More detail
Sep 27, 2022 at 11:47:44 AM
   Z-Wave                          received "TH Door Lock" status update battery level 100%
   Z-Wave                          received "TH Door Lock" status update is unlocked
   Z-Wave Lock Manager             Status: Door is unlocked [Node: 2]
  File "plugin.py", line 613, in zwaveCommandReceived
type: (2,)
Sep 29, 2022 at 7:23:17 AM
   Z-Wave                          received "Front Door Lock" status update locked (via keypad)
   Z-Wave Lock Manager             Status: User 0 locked door [Node: 26]
  File "plugin.py", line 414, in zwaveCommandReceived
type: (26,)
Sep 29, 2022 at 7:44:58 AM
   Z-Wave                          received "Front Door Lock" status update unlocked (via keypad)
   Z-Wave Lock Manager             Status: User 1 unlocked door [Node: 26]
  File "plugin.py", line 422, in zwaveCommandReceived
type: (26,)
   Z-Wave                          received "Front Door Lock" status update locked (manually)
  File "plugin.py", line 429, in zwaveCommandReceived
type: (26,)
Here are the device details for the lock called TH Door Lock. This is a U_Tec lock
isplayStateImageSel : Unlocked
displayStateValRaw : False
displayStateValUi : unlocked
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 851481124
     com.perceptiveautomation.indigoplugin.zwave : (dict)
          IsLockSubType : true (bool)
          SupportsBatteryLevel : true (bool)
          address : 2 (integer)
          indigoObjVersion : 10 (integer)
          modelNameAndFirmware : Door Lock, firmware 0.00 (string)
          propsPushTickler : 1 (string)
          tempAlwaysFalse : false (bool)
          userEnergyPollingEnabled : false (bool)
          userPollInterval : 0 (integer)
          userPollingEnabled : false (bool)
          userWakeInterval : 60 (integer)
          version : 1.01 (string)
          zwAppVersMajor : 1 (integer)
          zwAppVersMinor : 1 (integer)
          zwAssociationsMap : (dict)
               g1 : (list)
                    Item : 1 (integer)
          zwAssociationsMapStr : 1:[1] (string)
          zwClassCmdBase : 98 (integer)
          zwClassCmdMap : (dict)
               c108 : 1 (integer)
               c114 : 1 (integer)
               c115 : 1 (integer)
               c122 : 1 (integer)
               c128 : 1 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c135 : 1 (integer)
               c142 : 1 (integer)
               c152 : 1 (integer)
               c159 : 1 (integer)
               c32 : 1 (integer)
               c85 : 1 (integer)
               c89 : 1 (integer)
               c90 : 1 (integer)
               c94 : 1 (integer)
               c98 : 1 (integer)
               c99 : 1 (integer)
          zwClassCmdMapStr : 20v1 62v1 5Ev1 55v1 98v1 9Fv1 6Cv1 86v1 72v1 5Av1 87v1 73v1 80v1 63v1 85v1 8Ev1 59v1 7Av1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 64 (integer)
               Item : 1 (integer)
          zwClassInstanceCountMap : (dict)
          zwClassInstanceCountMapStr : - none - (string)
          zwClassName : Door Lock (string)
          zwConfigVals : (dict)
          zwConfigValsStr : - none - (string)
          zwDevSubIndex : 0 (integer)
          zwEncryptClassCmdMap : (dict)
               c114 : true (bool)
               c115 : true (bool)
               c122 : true (bool)
               c128 : true (bool)
               c133 : true (bool)
               c134 : true (bool)
               c135 : true (bool)
               c142 : true (bool)
               c89 : true (bool)
               c90 : true (bool)
               c98 : true (bool)
               c99 : true (bool)
          zwEncryptClassCmdMapStr : 86 72 5A 87 73 80 62 63 85 8E 59 7A (string)
          zwEncryptionStatusStr : Enabled for Commands 86 72 5A 87 73 80 62 63 85 8E 59 7A (string)
          zwEndpointClassMap : (dict)
          zwEndpointClassMapStr : - none - (string)
          zwEndpointDevTypeMap : (dict)
          zwEndpointDevTypeMapStr : - none - (string)
          zwFeatureListStr : routing, battery, beaming, security, frequentWaking (string)
          zwLibType : 3 (integer)
          zwManufactureId : 1106 (integer)
          zwManufactureName : Unknown (string)
          zwModelDefnVers : 0 (integer)
          zwModelId : 262145 (integer)
          zwModelName : Door Lock (string)
          zwNodeNeighbors : (list)
               Item : 1 (integer)
               Item : 3 (integer)
               Item : 4 (integer)
               Item : 5 (integer)
               Item : 6 (integer)
               Item : 7 (integer)
               Item : 8 (integer)
               Item : 9 (integer)
               Item : 12 (integer)
               Item : 13 (integer)
               Item : 14 (integer)
               Item : 16 (integer)
               Item : 18 (integer)
               Item : 19 (integer)
               Item : 20 (integer)
               Item : 21 (integer)
               Item : 22 (integer)
               Item : 24 (integer)
               Item : 34 (integer)
          zwNodeNeighborsStr : 1, 3, 4, 5, 6, 7, 8, 9, 12, 13, 14, 16, 18, 19, 20, 21, 22, 24, 34 (string)
          zwProtoVersMajor : 7 (integer)
          zwProtoVersMinor : 14 (integer)
          zwShowDumpDevToLog : false (bool)
          zwShowEnergyPollingUI : false (bool)
          zwShowMainUI : true (bool)
          zwShowManualModifyConfigParmUI : true (bool)
          zwShowPollingUI : true (bool)
          zwShowSubmitModelInfoUI : true (bool)
          zwShowWakeIntervalUI : false (bool)
          zwWakeInterval : 0 (integer)
lastChanged : 2022-09-27 11:48:55
lastSuccessfulComm : 2022-09-27 11:48:55
ledStates : []
model : Door Lock
name : TH Door Lock
onState : False
ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
          g1 : (list)
               Item : 1 (integer)
          c108 : 1 (integer)
          c114 : 1 (integer)
          c115 : 1 (integer)
          c122 : 1 (integer)
          c128 : 1 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c135 : 1 (integer)
          c142 : 1 (integer)
          c152 : 1 (integer)
          c159 : 1 (integer)
          c32 : 1 (integer)
          c85 : 1 (integer)
          c89 : 1 (integer)
          c90 : 1 (integer)
          c94 : 1 (integer)
          c98 : 1 (integer)
          c99 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 64 (integer)
          Item : 1 (integer)
          c114 : true (bool)
          c115 : true (bool)
          c122 : true (bool)
          c128 : true (bool)
          c133 : true (bool)
          c134 : true (bool)
          c135 : true (bool)
          c142 : true (bool)
          c89 : true (bool)
          c90 : true (bool)
          c98 : true (bool)
          c99 : true (bool)
          Item : 1 (integer)
          Item : 3 (integer)
          Item : 4 (integer)
          Item : 5 (integer)
          Item : 6 (integer)
          Item : 7 (integer)
          Item : 8 (integer)
          Item : 9 (integer)
          Item : 12 (integer)
          Item : 13 (integer)
          Item : 14 (integer)
          Item : 16 (integer)
          Item : 18 (integer)
          Item : 19 (integer)
          Item : 20 (integer)
          Item : 21 (integer)
          Item : 22 (integer)
          Item : 24 (integer)
          Item : 34 (integer)
pluginId : com.perceptiveautomation.indigoplugin.zwave
protocol : ZWave
remoteDisplay : False
states : States : (dict)
     batteryLevel : 100 (integer)
     batteryLevel.ui : 100% (string)
     lastChangedVia : unknown (string)
     onOffState.ui : unlocked (string)
subModel :
subType :
supportsAllOff : False
supportsStatusRequest : True
version : 1.01
And this is the device info for the other lock, its a Schlage
   Script                          address : 26
batteryLevel : 100
buttonConfiguredCount : 0
buttonGroupCount : 0
configured : True
description :
deviceTypeId : zwLockType
displayStateId : onOffState
displayStateImageSel : Locked
displayStateValRaw : True
displayStateValUi : locked
enabled : True
errorState :
folderId : 926766259
          publish-device : true (bool)
          sub-type : Lock (string)
          voice-name : Front Door (string)
          IsSchlageLock : true (bool)
          address : 26 (integer)
          modelNameAndFirmware : Keypad Door Lock, firmware 128.22 (string)
          propsPushTickler : 2 (string)
          userPollAfterActivity : true (bool)
          version : 128.22 (string)
          zwAppVersMajor : 128 (integer)
          zwAppVersMinor : 22 (integer)
               g1 : (list)
                    Item : 1 (integer)
               c112 : 1 (integer)
               c113 : 1 (integer)
               c114 : 1 (integer)
               c122 : 1 (integer)
               c128 : 1 (integer)
               c133 : 1 (integer)
               c134 : 1 (integer)
               c152 : 1 (integer)
               c32 : 1 (integer)
               c34 : 1 (integer)
               c93 : 1 (integer)
               c98 : 1 (integer)
               c99 : 1 (integer)
          zwClassCmdMapStr : 20v1 62v1 63v1 72v1 86v1 98v1 22v1 7Av1 5Dv1 85v1 80v1 70v1 71v1 (string)
          zwClassIds : (list)
               Item : 4 (integer)
               Item : 64 (integer)
               Item : 3 (integer)
          zwClassName : Keypad Door Lock (string)
               c112 : true (bool)
               c113 : true (bool)
               c128 : true (bool)
               c133 : true (bool)
               c32 : true (bool)
               c93 : true (bool)
               c98 : true (bool)
               c99 : true (bool)
          zwEncryptClassCmdMapStr : 5D 85 20 80 70 62 71 63 (string)
          zwEncryptionStatusStr : Enabled for Commands 5D 85 20 80 70 62 71 63 (string)
          zwLibType : 6 (integer)
          zwManufactureId : 59 (integer)
          zwManufactureName : Schlage (string)
          zwModelId : 1665749060 (integer)
          zwModelName : Keypad Door Lock (string)
               Item : 1 (integer)
               Item : 3 (integer)
               Item : 4 (integer)
               Item : 5 (integer)
               Item : 6 (integer)
               Item : 7 (integer)
               Item : 8 (integer)
               Item : 9 (integer)
               Item : 11 (integer)
               Item : 12 (integer)
               Item : 13 (integer)
               Item : 14 (integer)
               Item : 15 (integer)
               Item : 16 (integer)
               Item : 17 (integer)
               Item : 18 (integer)
               Item : 19 (integer)
               Item : 20 (integer)
               Item : 22 (integer)
               Item : 24 (integer)
               Item : 34 (integer)
          zwNodeNeighborsStr : 1, 3, 4, 5, 6, 7, 8, 9, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 22, 24, 34 (string)
          zwProtoVersMajor : 3 (integer)
          zwProtoVersMinor : 42 (integer)
lastChanged : 2022-09-29 09:35:15
lastSuccessfulComm : 2022-09-29 09:35:15
ledStates : []
model : Keypad Door Lock
name : Front Door Lock
onState : True
          g1 : (list)
               Item : 1 (integer)
          c112 : 1 (integer)
          c113 : 1 (integer)
          c114 : 1 (integer)
          c122 : 1 (integer)
          c128 : 1 (integer)
          c133 : 1 (integer)
          c134 : 1 (integer)
          c152 : 1 (integer)
          c32 : 1 (integer)
          c34 : 1 (integer)
          c93 : 1 (integer)
          c98 : 1 (integer)
          c99 : 1 (integer)
     zwClassIds : (list)
          Item : 4 (integer)
          Item : 64 (integer)
          Item : 3 (integer)
          c112 : true (bool)
          c113 : true (bool)
          c128 : true (bool)
          c133 : true (bool)
          c32 : true (bool)
          c93 : true (bool)
          c98 : true (bool)
          c99 : true (bool)
          Item : 1 (integer)
          Item : 3 (integer)
          Item : 4 (integer)
          Item : 5 (integer)
          Item : 6 (integer)
          Item : 7 (integer)
          Item : 8 (integer)
          Item : 9 (integer)
          Item : 11 (integer)
          Item : 12 (integer)
          Item : 13 (integer)
          Item : 14 (integer)
          Item : 15 (integer)
          Item : 16 (integer)
          Item : 17 (integer)
          Item : 18 (integer)
          Item : 19 (integer)
          Item : 20 (integer)
          Item : 22 (integer)
          Item : 24 (integer)
          Item : 34 (integer)
protocol : ZWave
     lastChangedVia : keypad (string)
     onOffState : on (on/off bool)
     onOffState.ui : locked (string)
subModel :
subType :
version : 128.22
Thank you:)
Tue Sep 27, 2022 4:27 pm
Re: plugin error, ReceivedBroadcast
Let me look into this one.
Thu Sep 29, 2022 9:04 am
stewkenly offline
Just updated some details, I thought it was only the Schlage lock, but it does it with the U-Tec lock as well. Thanks again for looking.
