Are we able to set PINs from a variable?
Thu Jul 05, 2018 11:11 pm
chrisfromthelc offline
Re: Are we able to set PINs from a variable?
I've already had to use it once! I left the house and the wife was trying to program in her own code and ended up programming in...something that wasn't what she wanted. It was easier for me to set the code for her remotely. :D
Tue Oct 30, 2018 4:35 pm
7rdr7 offline
Hi Peter,
I finally got around to trying the variable to set the PIN codes. Works great! Eric's post/questions was also helpful.
You posted earlier:
"I was also going to say yes it can be done easily - I’ll intercept a blank pin in the setPin() routine in code, and redirect to clearPin() instead when it sees blank."
Did you decide to add that function? I ask as when I delete the code (variable entry) and execute the action, the code remains in the locks. Could be a Schlage thing..... but the redirect would be nice if you plan to dig back into the code.
Thank-you for a very useful Plugin.
Tue Oct 30, 2018 4:37 pm
Not yet but will do next time I'm in the code.
Wed Oct 31, 2018 7:13 am
7rdr7 offline
Thanks for the quick response! Good to know it's coming in the future.
