Page 1 of 2
Kwikset 910 Error
Posted:
Tue Jun 27, 2017 9:20 am
by roquej
Installed the latest version .41, but getting this error when unlocking:
Z-Wave Lock Manager Error Error in plugin execution ReceivedBroadcast:
File "plugin.py", line 301, in zwaveCommandReceived
File "plugin.py", line 552, in triggerEvent
KeyError: (845063353,)
Any suggestions?
Thank you in advance.
JP
Re: Kwikset 910 Error
Posted:
Tue Jun 27, 2017 9:32 am
by howartp
Have you created dummy devices for your locks?
Posted:
Tue Jun 27, 2017 2:03 pm
by roquej
If by dummy device you are referring to "new device called ZWave Lock Manager > Door Lock", then yes.
Is that what you meant?
JP
Posted:
Wed Jun 28, 2017 4:30 am
by howartp
Yep.
I'll have a look.
Posted:
Wed Jun 28, 2017 1:36 pm
by roquej
Thank you!
Posted:
Sat Jul 22, 2017 4:59 am
by howartp
I've just posted v1.0.43
Nothing in it should have fixed your problem above, but there again your problem above shouldn't be happening...
Can you retry it in .43 and reply back with log if still a problem?
Peter
Posted:
Sat Jul 22, 2017 9:21 am
by roquej
howartp wrote:I've just posted v1.0.43
Peter
Peter - loaded the version but still getting the error when unlocking. As you can see below locking has no issues.
Z-Wave received "Garage Entry Lock" status update locked by user 001 (via keypad)
Z-Wave Lock Manager Status: User 1 locked door [Node: 126]
Z-Wave received "Garage Entry Lock" status update unlocked by user 001 (via keypad)
Z-Wave Lock Manager Status: User 1 unlocked door [Node: 126]
File "plugin.py", line 306, in zwaveCommandReceived
File "plugin.py", line 593, in triggerEvent
Hope this helps to narrow the issue.
JP
Posted:
Sat Jul 22, 2017 9:29 am
by roquej
Peter,
By the way, the same error is also happening with the Yale locks:
Z-Wave received "Side Gate-Back" status update locked (manually)
Z-Wave Lock Manager Status: Door locked manually (one-touch button) [Node: 128]
Z-Wave received "Side Gate-Back" status update unlocked (via keypad)
Z-Wave Lock Manager Status: User 0 unlocked door [Node: 128]
JP
Posted:
Fri Aug 11, 2017 11:32 am
by roquej
Just to provide a bit more info, in case it helps. Using the Z-Wave Watcher, got the following:
Z-Wave Watcher Debug Raw command sent (Node 126): 01 11 00 13 7E 0A 98 80 65 78 4C 2D DF 18 ED 15 25 DA 2D (True)
Z-Wave received "Garage Entry Lock" status update locked (manually)
Z-Wave Watcher Debug Raw command received (Node 126): 01 08 00 04 00 7E 02 98 40 57
Z-Wave Watcher Debug Raw command received (Node 126): 01 0A 00 04 00 7E 04 71 05 15 01 FF
Z-Wave Watcher Debug Raw command received (Node 126): 01 1E 00 04 00 7E 18 98 81 4C 5F 69 BA B3 E3 2D 7D 63 07 7E 65 28 65 0A 10 43 27 C2 FF 13 3D 05
Z-Wave Lock Manager Status: Door locked manually [Node: 126]
Z-Wave received "Half Bath Light" status update is on
Z-Wave Watcher Debug Raw command sent (Node 126): 01 11 00 13 7E 0A 98 80 65 78 4C 2D DF 18 ED 15 25 DC 2B (True)
Z-Wave Watcher Debug Raw command received (Node 126): 01 0A 00 04 00 7E 04 71 05 13 01 FF
Z-Wave Watcher Debug Raw command received (Node 126): 01 1E 00 04 00 7E 18 98 81 B0 B1 D8 63 7E 77 34 2B E8 D0 39 A6 EE 65 7C 48 48 EE 5B 6F 42 33 CD
JP
Posted:
Fri Aug 11, 2017 1:14 pm
by howartp
Sorry roquej; I thought I'd caught up on all my threads last week!
I'll try look at this tomorrow.
Posted:
Wed Aug 16, 2017 2:02 pm
by howartp
What device or trigger has ID of '845063353'?
Posted:
Wed Aug 16, 2017 3:16 pm
by roquej
Device ID "845063353' belongs to a Yale Real Living B1L lock.
JP
Posted:
Fri Aug 18, 2017 2:34 pm
by howartp
In the trigger definition, is the trigger based on the Yale lock device, or on my dummy device?
Peter
Posted:
Fri Aug 18, 2017 4:55 pm
by roquej
your dummy device
JP
Posted:
Fri Aug 18, 2017 5:07 pm
by roquej
Peter,
Just to see how if it would help, I deleted all the dummy devices and associated triggers. Also removed the plugin and reinstalled the new .45 version. After recreating the dummy devices and a few triggers, the error seem to go away.
Not sure if it was the new version or just clearing something with the previous devices, but everything seems to work now!
Thank you for looking into the issue. Really appreciate the awesome plugin.
JP
