Lock Manager and Yale Keyless Connected Smart Lock (UK)
Sun Jan 28, 2018 12:56 pm
shapa offline
Re: Lock Manager and Yale Keyless Connected Smart Lock (UK)
Using (for >1 year) yale z-wave UK-spec lock. No issues. In fact, I also converted US-spec locks to the EU standard using EU z-wave modules from Yale.
Mon Jan 29, 2018 2:31 am
Interesting idea, Shapa!
Thu Oct 04, 2018 3:54 am
CBowles offline
Firstly, thanks you for developing a great plugin!
I have the Yale Keyless connected lock and am trying to get it to report various unlock methods.
Identifying user unlock by key code works great but when unlocked via a key tag, it reports an unknown status:
Z-Wave received "Back Door Lock" status update is on
Z-Wave Lock Manager Unknown lock status received: 144 [Node: 15]
Could you update the plugin to report this as Unlocked via Key Tag/Key Card or such like?
An alternative would be to add a Event such as "Status equals or contains" etc."
Looking forward to seeing the plugin evolve!
Chris
Sun Oct 07, 2018 2:00 pm
Could you turn on debug (Plugins > Lock Manager > configure) and post what it sees when you tag it?
Peter
Mon Oct 08, 2018 1:30 pm
CBowles offline
Hi Peter,
Here's the debug logging as requested...
8 Oct 2018, 20:19:35
Z-Wave Lock Manager Debug logging enabled
Z-Wave Lock Manager Debug Node ID 15 (Hex 15) found in lockIDs
Z-Wave Lock Manager Debug Raw: 01 0A 00 04 00 0F 04 71 05 90 02 FF
Z-Wave Lock Manager Debug -----
Z-Wave received "Back Door Lock" status update locked (via timer)
Z-Wave Lock Manager Debug Raw: 01 0A 00 04 00 0F 04 71 05 1B 01 FF
Z-Wave Lock Manager Status: Door re-locked automatically [Node: 15]
Z-Wave Lock Manager Debug triggerEvent called: relockedAuto
Z-Wave Lock Manager Debug Updating state: lockState
I also took the liberty of testing with a key card rather than a key tag incase it's different but the Raw code (and status response) appears to be the same...
I hope that helps!
Let me know if you'd like anything else tested.
Looking forward to user key code logging being implemented :wink:
Many thanks,
Chris
Thu Nov 29, 2018 10:10 am
CBowles offline
Hi Peter,
Have you had any luck with identifying the Key Tag/Card unlock status?
Many thanks,
Chris
