I'm unable to set a PIN from a variable.
I can read the PIN just fine.
- Code: Select all
Action Group Get Pin
Z-Wave Lock Manager Requesting PIN for user 1
Z-Wave sent "Front Door Deadbolt" raw command [63 02 01]
Z-Wave Lock Manager Status: User code 1 is 9 5 9 9 [Node: 13]
I can also set the PIN by manually assigning it in the action.
- Code: Select all
Action Group Set Pin
Z-Wave Lock Manager Setting PIN for user 1 to: 7135
Z-Wave sent "Front Door Deadbolt" raw command [63 01 01 01 37 31 33 35]
Z-Wave Lock Manager Status: User 1 updated [Node: 13]
Z-Wave Lock Manager Status: User code 1 is 7 1 3 5 [Node: 13]
However, using the %%v:123456%% format (which I've doublechecked that I've used my own variable ID) doesn't seem to work.
Variable with ID
- Screen Shot 2018-07-05 at 5.27.40 PM.png (7.05 KiB) Viewed 4138 times
Action setup
- Screen Shot 2018-07-05 at 5.29.53 PM.png (76.4 KiB) Viewed 4138 times
The PIN is unchanged.
- Code: Select all
Z-Wave Lock Manager Setting PIN for user 1 to: %%v:710549162%%
Z-Wave sent "Front Door Deadbolt" raw command [63 01 01 01]
(yes, the PIN in the variable is different; I made sure of that)
Any ideas? I have a Kwikset 910TRL. It seems to otherwise work fine...it's just the variable issue that's got me stumped.
