Updated to 6.1.5 and getting the error message: update: airfoil.isrunning() is returning false.
Airfoil is running (4.9.2) on it's own (no other instances).
Plugin is 1.1.10.
OS X is 10.11.2
Am I missing something?
Airfoil Error Error in plugin execution ExecuteAction:
File "plugin.py", line 168, in disconnectFromSpeaker
<type 'exceptions.KeyError'>: key ID-68A86D5CDE58 not found in dict
sudo find / -name "Airfoil.app" -print
Jan 25, 2016, 8:56:52 AM
Enabling plugin "Airfoil 1.1.10"
Starting plugin "Airfoil 1.1.10" (pid 5682)
Started plugin "Airfoil 1.1.10"
Airfoil Error Update failed. Check to see if Airfoil is functioning correctly and that there is only a single copy of the application on your hard drive.
Airfoil Turning on debug logging
Airfoil Debug runConcurrentThread: update()
Airfoil Debug update method called
Airfoil Debug update: Airfoil is running
Airfoil Debug update: application sources: [app(u'/Applications/Airfoil.app').application_sources.ID(0), app(u'/Applications/Airfoil.app').application_sources.ID(1), app(u'/Applications/Airfoil.app').application_sources.ID(2)]
Airfoil Debug update: device sources: [app(u'/Applications/Airfoil.app').device_sources.ID(3), app(u'/Applications/Airfoil.app').device_sources.ID(4), app(u'/Applications/Airfoil.app').device_sources.ID(5), app(u'/Applications/Airfoil.app').device_sources.ID(6), app(u'/Applications/Airfoil.app').device_sources.ID(7)]
Airfoil Debug update: system sources: [app(u'/Applications/Airfoil.app').system_sources.ID(8)]
Airfoil Debug Current Source: k.missing_value
Airfoil Debug Update failed with exception:
File "plugin.py", line 462, in update
theCurrentSourceId = self.airfoil.get(theCurrentSource.id)
AttributeError: 'Keyword' object has no attribute 'id'
File "plugin.py", line 513, in update
newKnownSpeakers[speakerId] = (speakerName, connStr)
ValueError: IllegalParameterError -- illegal XML tag name character
Airfoil Debug update: application sources: [app(u'/Applications/Airfoil.app').application_sources.ID(0), app(u'/Applications/Airfoil.app').application_sources.ID(1), app(u'/Applications/Airfoil.app').application_sources.ID(2), app(u'/Applications/Airfoil.app').application_sources.ID(3), app(u'/Applications/Airfoil.app').application_sources.ID(4)]
Airfoil Debug update: device sources: [app(u'/Applications/Airfoil.app').device_sources.ID(5)]
Airfoil Debug update: system sources: [app(u'/Applications/Airfoil.app').system_sources.ID(6)]
Airfoil Debug Current Source: app(u'/Applications/Airfoil.app').application_sources.ID(0)
Airfoil Debug update: speakers: [app(u'/Applications/Airfoil.app').speakers.ID(u'com.rogueamoeba.airfoil.LocalSpeaker'), app(u'/Applications/Airfoil.app').speakers.ID(u'fc-58-fa-89-55-a1:output'), app(u'/Applications/Airfoil.app').speakers.ID(u'60F81DCA89F7@Macbook Pro 15'), app(u'/Applications/Airfoil.app').speakers.ID(u'68A86D6366E6@Bathroom'), app(u'/Applications/Airfoil.app').speakers.ID(u'881FA13DEE0E@Office')]
Airfoil Debug update: Computer (com.rogueamoeba.airfoil.LocalSpeaker) - Connected: 0
Airfoil Debug update: adding to newKnownSpeakers for id: ID-com.rogueamoeba.airfoil.LocalSpeaker value: (u'Computer', u'disconnected')
Airfoil Debug update: Anker A7910 (fc-58-fa-89-55-a1:output) - Connected: 0
Airfoil Debug update: adding to newKnownSpeakers for id: ID-fc-58-fa-89-55-a1:output value: (u'Anker A7910', u'disconnected')
