Airfoil not able to connect to any speakers
Wed Oct 21, 2015 4:50 pm
BenX10 offline
Hi!
Since today noon I've that problem - and I had not changed anything. Today morning everything has worked as it should.
AS shows the correct speaker list, plugin 1.1.9, AirFoil 4.9.1, Indigo 6.1.4, Mac OS 10.11. Disabling and deleting the plugin's prefs didn't make any change, also tried several reboots of the whole system. The plugin always reports "No speakers available". :cry:
Cheers,
Ben
Thu Oct 22, 2015 8:56 am
Re: Airfoil not able to connect to any speakers
Are you seeing any errors in the Event Log window?
Thu Oct 22, 2015 9:43 am
BenX10 offline
Hi Jay,
No errors at all. If I enable debugging I see this:
Starting plugin "Airfoil 1.1.9" (pid 865)
  Started plugin "Airfoil 1.1.9"
  Airfoil                         No speakers available
  Airfoil                         Turning on debug logging
  Airfoil Debug                   runConcurrentThread: update()
  Airfoil Debug                   update method called
  Airfoil                         Turning off debug logging
Thu Oct 22, 2015 11:39 am
I'm not sure what's going on with your setup. Try this: toggle debugging on, then restart the plugin and copy/paste the results into a reply.
Our testing on 10.11 and Airfoil 4.9.1 has revealed what I believe is a bug in Airfoil around application audio sources. I've contacted them so we'll see what happens. It manifests itself as a repeated error message in the Event Log every second or two. If you are using Airfoil and Indigo, I recommend that you not upgrade to 10.11 until we can work out what's going on.
Thu Oct 22, 2015 12:07 pm
BenX10 offline
Here's the log:
Starting plugin "Airfoil 1.1.9" (pid 14737)
  Airfoil Debug                   Start processing trigger 1725633215
  Airfoil Debug                   Start trigger processing list: {'airfoilUnavailable': {1725633215: <indigo.PluginEventTrigger object at 0x8ce01f0>}, 'sourceChange': {}, 'speakerChange': {'becomesConnected': {}, 'becomesDisconnected': {}, 'becomesUnavailable': {}, 'becomesAvailable': {}}, 'airfoilAvailable': {}}
Forgot to mention: I updated to AirFoil 4.9.1 yesterday afternoon AFTER the problem occurred as I hoped that would solve the problem. Before it was AirFoil 4.8.?
For not upgrading to 10.11 it's too late, done so already.
Cheers,
Ben
Thu Oct 22, 2015 2:39 pm
Make sure you only have one copy of the Airfoil application on your hard drive.
Also, your debug logging doesn't look right - can you confirm that you're running Indigo 6.1.4 and the plugin version 1.1.9?
Thu Oct 22, 2015 3:10 pm
BenX10 offline
Already noticed that in the other thread and checked that yesterday locally on the MacMini which is running AirFoil and Indigo Server and found nothing. Just checked now via AFP access with PathFinder from my MacPro and guess what: Found 4.9.1 twice AND the 4.8.13 running before also twice (damned Gremlins...)! Cleaned up that mess and now everything works. Thanks for your support and getting me to search again. I'm a happy camper now. :D
Cheers,
Ben
Thu Oct 22, 2015 3:13 pm
BenX10 offline
Overseen that, yes I'm running Indigo 6.1.4 and plugin 1.1.9.
Thu Oct 22, 2015 3:27 pm
Yeah, a previous change to debugging altered the debug output in a strange way. I'll fix it in an upcoming release.
Glad it's working for you.
