split("@")[0]
File "/Library/Application Support/Perceptive Automation/Indigo 6/IndigoPluginHost.app/Contents/PlugIns/appscript/reference.py", line 498, in __call__
raise CommandError(self, (args, kargs), e, self.AS_appdata)
CommandError: Command failed:
OSERROR: -1728
MESSAGE: Can't get reference.
OFFENDING OBJECT: app(u'/Applications/Server/Airfoil/Airfoil.app').speakers.ID(u'745E1C30A0B9@VSX-1023')
COMMAND: app(u'/Applications/Server/Airfoil/Airfoil.app').get(app(u'/Applications/Server/Airfoil/Airfoil.app').speakers.ID(u'745E1C30A0B9@VSX-1023').id)
philc wrote:I updated both the plugin and the airfoil app, and everything is working fine. You have to do both to make it work. If you did update both, please make that clear.
JGTracy wrote:But: tha Airfoil feature for changing speaker volume doesn't work.
Airfoil Debug runConcurrentThread: update()
Airfoil Debug update method called
Airfoil Debug update: Airfoil is running
Airfoil Debug update: application sources: [app(u'/Applications/Server/Airfoil/Airfoil.app').application_sources.ID(0), app(u'/Applications/Server/Airfoil/Airfoil.app').application_sources.ID(1), app(u'/Applications/Server/Airfoil/Airfoil.app').application_sources.ID(2), app(u'/Applications/Server/Airfoil/Airfoil.app').application_sources.ID(3)]
Airfoil Debug update: device sources: [app(u'/Applications/Server/Airfoil/Airfoil.app').device_sources.ID(4), app(u'/Applications/Server/Airfoil/Airfoil.app').device_sources.ID(5), app(u'/Applications/Server/Airfoil/Airfoil.app').device_sources.ID(6), app(u'/Applications/Server/Airfoil/Airfoil.app').device_sources.ID(7)]
Airfoil Debug update: system sources: [app(u'/Applications/Server/Airfoil/Airfoil.app').system_sources.ID(8)]
Airfoil Debug update: speakers: [app(u'/Applications/Server/Airfoil/Airfoil.app').speakers.ID(u'com.rogueamoeba.airfoil.LocalSpeaker'), app(u'/Applications/Server/Airfoil/Airfoil.app').speakers.ID(u'745E1C30A0B9@VSX-1023'), app(u'/Applications/Server/Airfoil/Airfoil.app').speakers.ID(u'0011240663D1@Bedroom Speakers')]
Airfoil Debug update: Computer (com.rogueamoeba.airfoil.LocalSpeaker) - Connected: 1
Airfoil Debug update: adding to newKnownSpeakers for id: ID-com.rogueamoeba.airfoil.LocalSpeaker value: (u'Computer', u'connected')
Airfoil Error Update failed. Check to see if Airfoil is functioning correctly.
Airfoil Debug Update failed with exception:
File "plugin.py", line 484, in update
speakerId = self.airfoil.get(speaker.id).split("@")[0]
OSERROR: -1728
jay (support) wrote:Anyone can get that release - I linked to it in a different post. If you're unwilling to run a beta, then unfortunately you'll have to wait until Rogue Amoeba releases 4.8.13 final - the bugs are on their side and we couldn't work around all of the issues.
