Airfoil Isn't Running
Fri Jan 10, 2014 5:36 pm
AndrewGWalsh offline
I am getting this message when I switch on debugging - yet I can see the application on the screen.
Everything is on latest versions.
Grateful thanks for any suggestions...
Andrew
Fri Jan 10, 2014 6:20 pm
Re: Airfoil Isn't Running
You probably have multiple copies of Airfoil installed on your Mac. Mavericks (and potentially Mountain Lion) seems to get easily confused when trying to target apple events when there are multiple versions of the same app on any mounted disk. Delete all but the latest Airfoil app and reboot.
Sat Jan 11, 2014 3:33 pm
Thanks for that - although I still have the problem.
I've tried deleting the only copy of Airfoil I can find, rebooting, reinstalling (it is just a copy of the file to the applications directory) and the problem remains.
Sun Jan 12, 2014 11:14 am
Then you're experiencing another bug that was introduced either in Airfoil, Mavericks, or some combination thereof. I believe I have a workaround for that issue - 6.0.8, which should land in the next several days, will hopefully solve the issue.
Mon Jan 13, 2014 2:46 am
Excellent news, I'll wait on 6.0.8 :-)
Sat Jan 18, 2014 2:13 pm
Umm, upgraded to 6.0.8 (and then to 6.0.9) and I still have the problem with Airfoil :-(
I don't suppose you have any other thoughts on the matter?
Andrew
Sat Jan 18, 2014 3:46 pm
Not really - let's do this:
  1. Turn on debugging (Plugins->Airfoil->Toggle Debugging)
  2. Restart the plugin (Plugins->Airfoil->Reload
  3. Let it run until it fails
  4. Turn off debugging (Plugins->Airfoil->Toggle Debugging)
Then email me (indigo DASH support AT perceptiveautomation DOT com) the log from the time the plugin restarts (just copy/paste from the event log window).
Mon Feb 17, 2014 3:32 pm
Did you ever send this or did the problem resolve itself?
