If you tick this box, then you can specify the host address of the Apple Mac that the Alexa-Hue Bridge plugin is running on (rather than the plugin discovering it automatically). This is not normally needed but can help in problem situations.
When this is ticked, it reveals the field to enter the Host IP Address into. It is your responsibility to specify it correctly e.g. '192.168.1.100' (no quotes). Reload the Plugin after saving this change.
sarahcat wrote:... Nothing in the log. Not sure how to turn debugging on specifically for the plug-in, ...
BigDaddyNC wrote:I got my Echo Dot Gen 1 delivered yesterday and got right to setting it up.
Went ahead and unplugged all of my other Echo Dots and set up the new (old) one. It discovered all of the devices published by the Hue Bridge Emulator and restored that function.
billorav wrote:Not sure if this helps in your Skill development
billorav wrote:Hopefully Amazon won't brick the 1st Gen Echo's anytime soon. Thanks.
Just curious, since you also mentioned that everything did not get discovered when you had some of your 2nd and 3rd gen Echos unplugged and I had no such problem. I have a lot of devices and unplugging them all would be a real pain.
Since I have the Gen 1 and a Gen 2 (both Echo Dots) right next to me in my Study, I would mute the mic on the Gen 2 and un-mute the Gen 1 and issue the discovery command and discovery works as advertised.
Users browsing this forum: No registered users and 19 guests
