autolog wrote:Are these caused by the Alexa-Hue Bridge plugin? If so I would expect a bit more detail in the log.
'clientConnectionStatus' does not appear anywhere in the Alexa-Hue plugin code. So it's something else causing that error.
PETStech wrote:
I'm going to uninstall/reinstall/reconfigure the Alexa-Hue Bridge and see if I can get it working, again.
Tried above. Still, Alexa not discovering Alex-Hue Bridge., neither with iOS app nor via website, while Smart Life and MagicLight WF skills and devices found and working. Meanwhile, control with Indigo Touch and Indigo 7.2 apps continues without any problem.
At a BIG loss. Surprised more are reporting problems since mid-August Alexa upgrade.
- Tom
Sep 4, 2019 at 1:14:02 AM
Disabling plugin "Alexa-Hue Bridge 3.0.32"
Stopping plugin "Alexa-Hue Bridge 3.0.32" (pid 915)
Alexa-Hue Bridge Alexa-Hue Bridge shutdown requested
Alexa-Hue Bridge HTTP server stopping...
Alexa-Hue Bridge HTTP server stopped
Stopped plugin "Alexa-Hue Bridge 3.0.32"
Enabling plugin "Alexa-Hue Bridge 3.0.32"
Starting plugin "Alexa-Hue Bridge 3.0.32" (pid 1002)
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address is discovered as: '192.168.1.2'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, non-Echo Network Filter, Method Trace
Started plugin "Alexa-Hue Bridge 3.0.32"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'ALEX Test bridge' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'ALEX Test bridge' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'ALEX Test bridge' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'ALEX Test bridge' started: Host: 192.168.1.2 Port: 8178
Alexa-Hue Bridge 'ALEXA BRIDGE 1' has u3 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'ALEXA BRIDGE 1' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'ALEXA BRIDGE 1' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'ALEXA BRIDGE 1' started: Host: 192.168.1.2 Port: 8180
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to http://www.google.com successfully completed.
Sep 4, 2019 at 1:15:28 AM
Alexa-Hue Bridge Error 'ALEXA BRIDGE 1' Responder.run: socket error: [Errno 64] Host is down
Alexa-Hue Bridge Error 'ALEX Test bridge' Responder.run: socket error: [Errno 64] Host is down
Sep 4, 2019 at 1:23:43 AM
Alexa-Hue Bridge Error plugin does not define method checkRateLimit
Sep 4, 2019 at 1:33:11 AM
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'self.ahbDev.name'. Line '185' has error='[Errno 32] Broken pipe'
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'ALEXA BRIDGE 1'. Line '185' has error='[Errno 32] Broken pipe'
Barnman wrote:I figured mine out, I had one echo dot 2nd gen that was not updated last week.
I disconnected all my other dots and shows, and then it discovered without any issues. I feel pretty confident that it is all related to the software level of the echo device
jay (support) wrote:Barnman wrote:I figured mine out, I had one echo dot 2nd gen that was not updated last week.
What is the version number of the latest Echo release? Mine are still working, but I haven't tried to do a discover and I'm not inclined to do it now for fear that it will break something.
jay (support) wrote:Yep, mine are still at a version (641571120 on one, slightly different on others but still 64157*) slightly earlier than the latter one you posted. I don't recall disabling automatic updates, and I don't see any way to turn it on/off in the Alexa app. Anyone know how to toggle automatic updates on an Echo?
