Alexa says all devices are not responding
Sat Aug 31, 2019 5:00 am
wormhole offline
Re: Alexa says all devices are not responding
Same, yesterday all of a sudden nothing responds.
Aug 31, 2019 at 6:53:35 AM
Action Group Alexa Hue Garage Door
Virtual Devices sent "Alexa Garage Door" on
Sent INSTEON "Garage Door Sensor" on
Received INSTEON "Garage Door Sensor" off
Trigger Garage Door is Open
Trigger KPL Button 8 Show Garage Door Open
Trigger Garage Door Open Alert
Trigger Alexa Garage Door Trigger
Sent INSTEON "Garage Door Sensor" status request (received input sensor: open)
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Bridge 1' responding to Alexa discovery from 10.0.1.45:35148 [request id: 1] ...
Alexa-Hue Bridge + Publishing device '2nd Floor Hall Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Backyard Patio Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Breakfast Table Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Charlies Closet' to Alexa
Alexa-Hue Bridge + Publishing device 'Christmas Tree' to Alexa
Alexa-Hue Bridge + Publishing device 'Dining Room Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Emmas Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Family Room Eyeballs' to Alexa
Alexa-Hue Bridge + Publishing device 'Family Room Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'FrontdoorLight' to Alexa
Alexa-Hue Bridge + Publishing device 'Garage Door' to Alexa
Alexa-Hue Bridge + Publishing device 'Master Bathroom Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Playroom Lights' to Alexa
Alexa-Hue Bridge ... 13 devices discovered by Alexa on Alexa-Hue Bridge 'Alexa Bridge 1'.
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Bridge 2' responding to Alexa discovery from 10.0.1.45:48469 [request id: 2] ...
Alexa-Hue Bridge + Publishing device 'Guest Room' to Alexa
Alexa-Hue Bridge + Publishing device 'Hall Bath Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Island Chandelier' to Alexa
Alexa-Hue Bridge + Publishing device 'Karens Closet' to Alexa
Alexa-Hue Bridge + Publishing device 'Kitchen Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Living Room Chandelier' to Alexa
Alexa-Hue Bridge + Publishing device 'Living Room Lamps' to Alexa
Alexa-Hue Bridge + Publishing device 'Master Bath Toilet Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Master Bedroom Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Mudroom Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Pantry Light' to Alexa
Alexa-Hue Bridge + Publishing device 'Pergola Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Study Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Theater High Hats' to Alexa
Alexa-Hue Bridge + Publishing device 'Theater LEDs' to Alexa
Alexa-Hue Bridge + Publishing device 'Theater Lights' to Alexa
Alexa-Hue Bridge + Publishing device 'Theater Marquis' to Alexa
Alexa-Hue Bridge ... 17 devices discovered by Alexa on Alexa-Hue Bridge 'Alexa Bridge 2'.
Sent INSTEON "Garage Door Sensor" status request (received output relay: off)
Schedule KPL Button 8 Show Garage Door Open (delayed action)
Sent INSTEON "PowerLinc Interface" on (scene 4 - KPL Button 8)
Sent INSTEON "Mudroom Main" on (scene 4 cleanup)
Sent INSTEON "Master Bed Main Light" on (scene 4 cleanup)
Sent INSTEON "Family Room Main Lights" on (scene 4 cleanup)
Aug 31, 2019 at 6:55:29 AM
Alexa-Hue Bridge sent "Alexa Bridge 3" Discovery on
Alexa-Hue Bridge Error Start Discovery action failed for 'Alexa Bridge 3': broadcaster thread couldn't start. Try restarting the plugin.'
Alexa-Hue Bridge Error Traceback (most recent call last):
Alexa-Hue Bridge Error File "plugin.py", line 1771, in startDiscovery
Alexa-Hue Bridge Error self.globals['alexaHueBridge'][ahbDev.id]['broadcaster'].start()
Alexa-Hue Bridge Error File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 739, in start
Alexa-Hue Bridge Error raise RuntimeError("threads can only be started once")
Alexa-Hue Bridge Error RuntimeError: threads can only be started once
Alexa-Hue Bridge sent "Alexa Bridge 3" Discovery off
Alexa-Hue Bridge Stop Discovery . . . . . . . . . .
Alexa-Hue Bridge Stopping Hue Bridge 'Alexa Bridge 3' discovery threads as 'Turn Off Discovery' requested
Alexa-Hue Bridge Start Discovery action failed
Alexa-Hue Bridge Error Start Discovery action failed for 'Alexa Bridge 3': responder thread couldn't start. Try restarting the plugin.
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Bridge 3' discovery threads as 'Turn On Discovery' requested
Sat Aug 31, 2019 8:05 pm
Barnman offline
Have you figured yours out yet? This is really irritating me!!!!!
Sat Aug 31, 2019 9:05 pm
wormhole offline
Sorry. Have not.
Sun Sep 01, 2019 5:47 am
Barnman wrote:
So here we go again, out of nowhere, all my devices are not responding again, every thing looks good though, so I don’t get it. ...
what versions of MacOs and the plugin are you running?
Can you disable the plugin - leave it disabled for 10 minutes and then enable it again.
Then can you post log entries of the startup from the Indigo log window (not iTouch which is difficult to read) and in also post it in a Code block.
I would like to see what is happening in a more easy to read form. :)
Sun Sep 01, 2019 10:43 am
Barnman offline
I just disabled it, I will let you know what happens in 10min.
Software on my Mac is 10.11.16
Sun Sep 01, 2019 10:55 am
Barnman offline
Sep 1, 2019, 12:41:50 PM
Enabling plugin "Alexa-Hue Bridge 3.0.29"
Starting plugin "Alexa-Hue Bridge 3.0.29" (pid 2529)
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address overridden and specified as: '192.168.0.229'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, non-Echo Network Filter, Method Trace
Started plugin "Alexa-Hue Bridge 3.0.29"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'alexa den lights' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'alexa den lights' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'alexa den lights' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'alexa den lights' started: Host: 192.168.0.229 Port: 8178
Alexa-Hue Bridge 'alexa isle way lights' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'alexa isle way lights' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'alexa isle way lights' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'alexa isle way lights' started: Host: 192.168.0.229 Port: 8181
Alexa-Hue Bridge 'alexa living room lights' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'alexa living room lights' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'alexa living room lights' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'alexa living room lights' started: Host: 192.168.0.229 Port: 8182
Alexa-Hue Bridge 'all lights off' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'all lights off' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'all lights off' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'all lights off' started: Host: 192.168.0.229 Port: 8180
Alexa-Hue Bridge 'bedroom lights' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'bedroom lights' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'bedroom lights' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'bedroom lights' started: Host: 192.168.0.229 Port: 8179
Alexa-Hue Bridge 'hAydens room' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'hAydens room' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'hAydens room' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'hAydens room' started: Host: 192.168.0.229 Port: 8184
Alexa-Hue Bridge 'new device' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'new device' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'new device' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'new device' started: Host: 192.168.0.229 Port: 8185
Alexa-Hue Bridge 'open front gate' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'open front gate' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'open front gate' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'open front gate' started: Host: 192.168.0.229 Port: 8183
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to www.google.com successfully completed.
Sun Sep 01, 2019 12:00 pm
That all seems OK. :?
So if you do a discovery (just after a plugin restart) what appears in the log? :)
Sun Sep 01, 2019 12:05 pm
Barnman offline
Nothing changes in the log.
I’ve done as I read in another thread, I deleted all devices from the desktop Alexa website. Re-started my early gen Alexa , and tried to discover from that one, with no success
Sun Sep 01, 2019 12:21 pm
I am afraid I am at a bit of a loss at the moment. :?
As I said in another thread, my system is working OK - if it wasn't then it would make it easier to try and find a solution.
I am going to try and dig deeper on this tomorrow but unfortunately I haven't got much to go in. :)
Mon Sep 02, 2019 11:49 am
I have released a new version incorporating recent pre-release fixes. :)
Despite extensive testing, I haven't been able to find any solution to or reason for the problems that are being discussed in this thread. :(
I have released the update to get the latest (minor) changes as the official release. :)
Mon Sep 02, 2019 8:04 pm
Barnman offline
I have updated the plugin. I just don’t get it, I deleted all devices, and tried to start fresh.
Sorry for the large pics, but wanted you to see my settings. I am going back to the wiki to verify as well
Mon Sep 02, 2019 8:11 pm
Barnman offline
Sep 2, 2019, 9:51:55 PM
Alexa-Hue Bridge 'new device' updated and now has one Alexa Device published
Alexa-Hue Bridge Alexa-Hue Bridge 'new device' started: Host: 192.168.0.229 Port: 8186
Alexa-Hue Bridge Alexa-Hue Bridge 'new device' responding to Alexa discovery from 192.168.0.2:33370 [request id: 17] ...
Alexa-Hue Bridge + Publishing device 'den lights' to Alexa
Alexa-Hue Bridge ... One device discovered by Alexa on Alexa-Hue Bridge 'new device'.
Alexa-Hue Bridge Alexa-Hue Bridge 'new device' responding to Alexa discovery from 192.168.0.2:33371 [request id: 18] ...
Alexa-Hue Bridge Alexa-Hue Bridge 'new device' responding to Alexa discovery from 192.168.0.2:33372 [request id: 19] ...
Alexa-Hue Bridge Alexa-Hue Bridge 'new device' responding to Alexa discovery from 192.168.0.2:33373 [request id: 20] ...
Sep 2, 2019, 9:57:42 PM
Alexa-Hue Bridge Alexa-Hue Bridge 'Den Lights' responding to Alexa discovery from 192.168.0.2:33379 [request id: 21] ...
Alexa-Hue Bridge ... One device discovered by Alexa on Alexa-Hue Bridge 'Den Lights'.
Alexa-Hue Bridge Alexa-Hue Bridge 'Den Lights' responding to Alexa discovery from 192.168.0.2:33380 [request id: 22] ...
Sep 2, 2019, 10:04:53 PM
Mon Sep 02, 2019 8:14 pm
Barnman offline
The only other stupid question I have, I guess, does the early gen Alexa need to be close to the Mac?
Tue Sep 03, 2019 4:15 am
Thanks for the images and logs. :)
I am even more confused now. :?
Your setup (from the images) looks fine.
The log shows a successful discovery when you have asked Alexa to do a discovery.
The request has come from the echo at IP address 192.168.0.2.
It has discovered and published Den Lights to Alexa, so that should be appearing in your list of devices on the Amazon Alexa website.
So given that discovery seems to be working (which arguably is the more complicated interaction with Alexa), I can't fathom out why the simple turn on/off request isn't.
In answer to your other question regarding distance from your Mac; it shouldn't make any difference - the main thing is to have a decent wi-fi signal. :)
Tue Sep 03, 2019 4:20 am
Barnman offline
So when I ask Alexa to turn on the den lights, instead of saying the device is not responding, it says “den doesn’t support that”
