autolog wrote:The plugin can't workout what your host name is, for some reason.![]()
This can sometimes be because you have both ethernet and wi-fi enabled and/or maybe one is overriding the other.
Try overriding the Host IP Address - see the documentation here: Alexa-Hue Bridge Plugin Configuration
autolog wrote:OK - Glad it's working again for you.
Barnman wrote:So everything was working good last night, after I added the devices back that I had messed up.
When I got home today, none of the devices were working. I found the ground fault outlet tripped where one of my Alexa dots is. I got that all straightened out, but my question is, why with that one Alexa basically unplugged would none of them work? I will also add, this Dot was the first one I had when I set up the plugin, if that matters.
