Install problems
Posted: Thu Jul 25, 2019 8:42 pm
I have been struggling for a few days trying to get Indigo to co-exist with Alexa.
I have now purchased a gen2 Alexa dot after reports that the gen 3 devices were incompatible but no success. This is what I get after starting the plugin:
Enabling plugin "Alexa-Hue Bridge 3.0.29"
Starting plugin "Alexa-Hue Bridge 3.0.29" (pid 12490)
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address is discovered as: '192.168.1.10'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, non-Echo Network Filter, Method Trace
Started plugin "Alexa-Hue Bridge 3.0.29"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge Error Alexa-Hue Bridge 'Alexa 1' at address - none - either has an invalid address or invalid port 8178 - specify in Device Config
Z-Wave received "Pool light" energy total to 23.761 kWh
Z-Wave received "Pool light" power load to 16.506 W
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to www.google.com successfully completed.
The host address is correct. I have also tried manually entering the address of the iMac where Indigo and the plugin reside.
So don't know what the error - including address - none - is referring to.
If I turn discovery of the 'Alexa 1' device on, I get:
Alexa-Hue Bridge sent "Alexa 1" Discovery on
Alexa-Hue Bridge Error StandardError detected in Broadcaster.Init for 'Alexa 1'. Line '79' has error=''port''
Alexa-Hue Bridge Error StandardError detected in Broadcaster.Run for 'Alexa 1'. Line '91' has error=''discoveryExpiration''
Alexa-Hue Bridge Error StandardError detected in Responder.Init for 'Alexa 1'. Line '132' has error=''port''
Alexa-Hue Bridge Starting Hue Bridge 'Alexa 1' discovery threads as 'Turn On Discovery' requested
Alexa-Hue Bridge Error StandardError detected in Responder.Run for 'Alexa 1'. Line '150' has error=''discoveryExpiration''
Alexa-Hue Bridge Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/IndigoPluginHost.app/Contents/Resources/PlugIns/plugin_base.py", line 1165, in deviceUpdated
File "plugin.py", line 562, in didDeviceCommPropertyChange
KeyError: ('forceDeviceStopStart',)
I have tried Asking Alexa to discover devices but it does not find any.
Many thanks for any and all suggestions....
