Alexa issue
Fri Feb 15, 2019 11:18 am
rgspb offline
Alexa issue
I'm getting a strange log from the Alexa-Hue bridge plugin. I'm also not getting updates to the Alexa app, I'm guessing this is the cause. The only thing that has changed is that I added one device to the Alexa setup.
Alexa-Hue Bridge Error getHueDeviceJSON exception:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/hue_listener.py", line 331, in getHueDeviceJSON
self.alexaDeviceNameKey = PLUGIN.globals['alexaHueBridge'][p1_ahbDevId]['hashKeys'][p3_alexaDeviceHashedKey]
KeyError: 'a46e5d2bbe2d3b05b2d28b6054d98c18046bce28893d04e050724168116d5587'
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'self.ahbDev.name'. Line '185' has error='must be string or buffer, not None'
KeyError: 'f06e825b7ef05927c8095049d20089dcac9a403cbdd481d139bc8ab38e8846bf'
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'Alexa'. Line '185' has error='must be string or buffer, not None'
KeyError: '5c996ab43a5a6add6f25af505dd970429824c98a4e511ef62b70dfca0ba6a5f0'
Fri Feb 15, 2019 2:44 pm
autolog offline
Re: Alexa issue
Not sure what is going on here :?
Looks like the plugin can't find the hash key for the Indigo device - this is the mechanism that ties up the Alexa device with the Indigo device.
A potential work-around is to delete all the devices on Alexa via the Alexa website and then do a re-discovery so that everything gets reset. :)
Fri Feb 15, 2019 4:26 pm
rgspb offline
Re: Alexa issue
The Alexa app isn't deleting items I delete on Indigo and not adding items I add.
Fri Feb 15, 2019 5:26 pm
autolog offline
Re: Alexa issue
Deleting devices on Indigo won't delete them from the Alexa App - You have to do that via the alexa.amazon.com via a web browser.
When you say it doesn't add them, are you doing a discovery and Alexa is not finding anything?
I'll be back online tomorrow morning at some point (UK time). :)
Sat Feb 16, 2019 11:34 am
rgspb offline
Re: Alexa issue
One thing is for sure, Alexa is no longer communicating with Indigo. No idea why. There is no way in Indigo to force a discovery, not that I can see.
Sat Feb 16, 2019 2:30 pm
rgspb offline
Re: Alexa issue
Now, all of a sudden, discovery is working in Indigo and Alexa is cooperating. I'm so confused, but things are working so I'll take it!
