All Alexa Devices through Indigo "Not Responding"
Sun Jan 27, 2019 5:56 pm
wormhole offline
Did something happen with the plugin? Using the latest, 3.0.29, but now in the Alexa app or if i say something to an echo its "Device is unresponsive". I have restarted Indigo Server and the plugin to no avail. Thanks in advance. Just happened today. Only thing i did was make some enhancement to the wifi in my home (which i don't think should impact Indigo).
Here is the reload of the plugin
Started plugin "Alexa-Hue Bridge 3.0.29"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'Alexa Devices 1' has u19 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Devices 1' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Devices 1' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Devices 1' started: Host: 10.0.1.100 Port: 8177
Alexa-Hue Bridge 'Alexa Devices 2' has u17 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Devices 2' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Devices 2' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Devices 2' started: Host: 10.0.1.100 Port: 8180
Alexa-Hue Bridge 'Alexa Groups' has u3 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Groups' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Groups' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Groups' started: Host: 10.0.1.100 Port: 8178
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to www.google.com successfully completed.
Alexa-Hue Bridge Plugin Host IP Address is discovered as: '10.0.1.100'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
Schedule Auto Off - Pantry (delayed action)
Sun Jan 27, 2019 6:08 pm
wormhole offline
Re: All Alexa Devices through Indigo "Not Responding"
I opened up the settings and saw this come across the event log.
Alexa-Hue Bridge Error 'Alexa Devices 2' Responder.run: socket error: [Errno 65] No route to host
Alexa-Hue Bridge Error 'Alexa Groups' Responder.run: socket error: [Errno 64] Host is down
Alexa-Hue Bridge Error 'Alexa Devices 1' Responder.run: socket error: [Errno 64] Host is down
Sun Jan 27, 2019 6:13 pm
wormhole offline
Found another thread, noticed under State it said 'Discover: Off", tried double clicking, that didn't work, then i reloaded the plugin and now it says Discovery:On, however Alexa still not working, all devices still showing as 'Device is Unresponsive" in app. Even deleting an app and re searching finds no devices.
wormhole offline
Also, as soon as Discovery goes to ON, it immediately then goes to off....sorry for all the posts.
Sun Jan 27, 2019 6:15 pm
wormhole offline
when i double click Discovery:Off, this shows up in events.
Alexa-Hue Bridge sent "Alexa Devices 1" Discovery Toggle
Alexa-Hue Bridge Error Start Discovery action failed for 'Alexa Devices 1': broadcaster thread couldn't start. Try restarting the plugin.'
Alexa-Hue Bridge Error Traceback (most recent call last):
Alexa-Hue Bridge Error File "plugin.py", line 1771, in startDiscovery
Alexa-Hue Bridge Error self.globals['alexaHueBridge'][ahbDev.id]['broadcaster'].start()
Alexa-Hue Bridge Error File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/threading.py", line 739, in start
Alexa-Hue Bridge Error raise RuntimeError("threads can only be started once")
Alexa-Hue Bridge Error RuntimeError: threads can only be started once
Sun Jan 27, 2019 6:17 pm
wormhole offline
Sorry, now Discovery seems to remain "ON", but still no dice.
Sun Jan 27, 2019 6:48 pm
wormhole offline
So it won't remain 'ON', still getting
Alexa-Hue Bridge Error 'Alexa Groups' Responder.run: socket error: [Errno 65] No route to host
Alexa-Hue Bridge Error 'Alexa Devices 2' Responder.run: socket error: [Errno 64] Host is down
Sun Jan 27, 2019 6:53 pm
wormhole offline
Now I am getting a bunch of other errors...could this be a PLM issue?
Harmony Hub Warning Hub - Family Room: Socket test failure
Harmony Hub Error Hub - Family Room: Error starting harmonyHub device, possibly bad IP address, disabling...
Harmony Hub Warning Hub - Theater: Socket test failure
Harmony Hub Error Hub - Theater: Error starting harmonyHub device, possibly bad IP address, disabling...
Cynical SecuritySpy Error Security Spy Server unavailable: ('401', 'Unauthorized')
Cynical SecuritySpy Error Security Spy - Backyard unavailable: host device Security Spy Server is unavailable
Cynical SecuritySpy Error Security Spy - Driveway Camera unavailable: host device Security Spy Server is unavailable
Cynical SecuritySpy Error Security Spy - Family Room unavailable: host device Security Spy Server is unavailable
Cynical SecuritySpy Error Security Spy - Pool unavailable: host device Security Spy Server is unavailable
Jan 27, 2019 at 7:53:17 PM
Error PowerLinc not responding -- attempting reset
Power Failure possible power failure
Connected to PowerLinc 2413U interface on port usbserial-A403KERF
PowerLinc address 39.56.D2, firmware version 9.14
Trigger Power Failure
Error email reply to address not specified: see Email tab in the Preferences Dialog
Thing is everything works on my iOS app....
Sun Jan 27, 2019 7:14 pm
wormhole offline
Rebooted Mac, started and stopped and restarted server. Discovery remains ON for Alexa plugin, but nothing is working via Alexa iOS app or echo's, no issues other than for Security Spy, Harmony and Alexa plugins on restart. Any help greatly appreciated, i'm pulling my hair out. Nothing changed whatsoever on the Airport Extreme that acts as my router.
Jan 27, 2019 at 7:59:32 PM
Starting Indigo Server version 7.2.0 (Mac OS X 10.14.2)
Loading attachments
Loading database "/Library/Application Support/Perceptive Automation/Indigo 7.2/Databases/3 Twin Knolls Dr.indiDb"
Loading plugin "Roku Network Remote 2.3.0"
Starting plugin "Roku Network Remote 2.3.0" (pid 791)
Loading plugin "NOAA Weather Plus 1.1.8"
Starting plugin "NOAA Weather Plus 1.1.8" (pid 792)
Loading plugin "Harmony Hub 7.2.3"
Starting plugin "Harmony Hub 7.2.3" (pid 793)
Loading plugin "TiVo Network Remote 2.2.0"
Starting plugin "TiVo Network Remote 2.2.0" (pid 794)
Loading interface "Virtual Devices 2.0.5"
Starting interface "Virtual Devices 2.0.5" (pid 795)
Loading plugin "Plex Media Server Manager 2.3.4"
Starting plugin "Plex Media Server Manager 2.3.4" (pid 796)
Loading plugin "Cynical Denon 1.8.0"
Starting plugin "Cynical Denon 1.8.0" (pid 797)
Loading plugin "Cynical SecuritySpy 2.3.0"
Starting plugin "Cynical SecuritySpy 2.3.0" (pid 798)
Loading plugin "Cynical Network 1.8.0"
Starting plugin "Cynical Network 1.8.0" (pid 799)
Loading plugin "NEST Home 2.0.50"
Starting plugin "NEST Home 2.0.50" (pid 800)
Loading plugin "NOAA Weather 2.0.1"
Starting plugin "NOAA Weather 2.0.1" (pid 801)
Loading interface "INSTEON Commands 2.2.1"
Starting interface "INSTEON Commands 2.2.1" (pid 802)
Loading plugin "Action Collection 2.1.1"
Starting plugin "Action Collection 2.1.1" (pid 803)
Loading plugin "Ring Doorbell 0.1.30"
Starting plugin "Ring Doorbell 0.1.30" (pid 804)
Loading plugin "HomeKit Bridge 1.0.2"
Starting plugin "HomeKit Bridge 1.0.2" (pid 805)
Loading plugin "Alexa-Hue Bridge 3.0.29"
Starting plugin "Alexa-Hue Bridge 3.0.29" (pid 806)
Error plugin "EPS Homebridge.indigoPlugin" is missing file: /Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/EPS Homebridge.indigoPlugin/Contents/Info.plist
Found disabled plugin "Cynical Behaviors 1.1.0"
Found disabled plugin "Growl 2.0.2"
Found disabled interface "Z-Wave 2.0.119"
Found disabled plugin "Dynamic Control 1.1.0"
Found disabled plugin "Jandy Aqualink Plugin 1.2.3"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Timers and Pesters 2.0.2"
Found disabled plugin "Airfoil Pro 1.0.9"
Found disabled plugin "EPS - Super Conditions 0.5"
Found disabled plugin "SQL Logger 2.1.0"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "WeatherSnoop 3.0.0"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "EPS - Homebridge Buddy 1.0.1"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Bonjour registered "Indigo - 3 Twin Knolls Dr"
Started interface "Virtual Devices 2.0.5"
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Started plugin "NOAA Weather Plus 1.1.8"
Cynical Network API version 2.0
Cynical Network Python version 2.7.10.final.0
Started plugin "Cynical Network 1.8.0"
Started interface "INSTEON Commands 2.2.1"
Started plugin "NOAA Weather 2.0.1"
Started plugin "Action Collection 2.1.1"
Cynical Denon API version 2.0
Cynical Denon Python version 2.7.10.final.0
Started plugin "Harmony Hub 7.2.3"
Harmony Hub Starting Harmony Hub
Harmony Hub Checking for updates...
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Started plugin "Cynical Denon 1.8.0"
Cynical SecuritySpy API version 2.0
Cynical SecuritySpy Python version 2.7.10.final.0
Started plugin "Cynical SecuritySpy 2.3.0"
Started plugin "NEST Home 2.0.50"
NEST Home ** Data Tracking Online **
Started plugin "Roku Network Remote 2.3.0"
Started plugin "TiVo Network Remote 2.2.0"
Started plugin "Plex Media Server Manager 2.3.4"
HomeKit Bridge Caching all HomeKit Bridge devices...
Harmony Hub No updates are available
Started plugin "Ring Doorbell 0.1.30"
Started plugin "HomeKit Bridge 1.0.2"
HomeKit Bridge Attempting to start 'HomeKit Bridge'
HomeKit Bridge HomeKit Bridge is running the latest version, no update needed
Ring Doorbell Number of devices found: 2
Ring Doorbell Backyard (id: 13856402)
Ring Doorbell Front Door (id: 56363)
HomeKit Bridge Server 'HomeKit Bridge' has successfully started, you can use your HomeKit apps or Siri for this accessory
Ring Doorbell the version of the plugin is up to date; version on server:0.1.30
Indigo Cocoa client connected
HomeKit Bridge HomeKit Bridge is loaded and ready to use
Jan 27, 2019 at 7:59:40 PM
Trigger iTunesSync
Trigger NOAA Weather Sync
Trigger Google Weather Trigger
Jan 27, 2019 at 8:00:00 PM
Schedule Poll Garage Door
Schedule Check KPL 8 status
Schedule Garage Door Check
Sent INSTEON "Garage Door Sensor" status request (received input sensor: closed)
Sent INSTEON "Garage Door Sensor" status request (received output relay: off)
Sent INSTEON "PowerLinc Interface" off (scene 4 - KPL Button 8)
Sent INSTEON "Mudroom Main" off (scene 4 cleanup)
Sent INSTEON "Master Bed Main Light" off (scene 4 cleanup)
Sent INSTEON "Family Room Main Lights" off (scene 4 cleanup)
Jan 27, 2019 at 8:00:19 PM
Jan 27, 2019 at 8:01:04 PM
Jan 27, 2019 at 8:02:52 PM
Sun Jan 27, 2019 7:37 pm
wormhole offline
Lat post for now, rebooted the Airport Extreme router, that fixed the harmony hub plugin issue...now the only issues remaining are the Alexa plugin (showing Discovery ON, but echo's and iOS alexa app showing unresponsive), and the Security Spy plugin, everything else works.
Reloading plugin "Alexa-Hue Bridge 3.0.29"
Stopping plugin "Alexa-Hue Bridge 3.0.29" (pid 806)
Alexa-Hue Bridge Alexa-Hue Bridge shutdown requested
Alexa-Hue Bridge HTTP server stopping...
Alexa-Hue Bridge HTTP server stopped
Stopped plugin "Alexa-Hue Bridge 3.0.29"
Starting plugin "Alexa-Hue Bridge 3.0.29" (pid 988)
Sun Jan 27, 2019 8:10 pm
wormhole offline
Fixed Security Spy, was solely an authentication issue...now if i could just figure out Alexa Hue plugin....
Sun Jan 27, 2019 8:46 pm
wormhole offline
Thought I fixed it...deleted one device in one of the bridges, added it back, rediscovered, it worked for a minute or two, then it failed again. Tried deleting all the alexa devices on my iOS app, then on within Indigo, recreated, nothing...it did work for a moment in time (per below), but now back to Not Responding :( ...
Jan 27, 2019 at 9:24:03 PM
Alexa-Hue Bridge Request received from 10.0.1.121:38420: Setting on state of Alexa device "Playroom Lights" ["Playroom Main"] to OFF
Sent INSTEON "Playroom Main" off
Jan 27, 2019 at 9:24:27 PM
Received INSTEON "Study Lights" on
Jan 27, 2019 at 9:25:00 PM
Received INSTEON "Study Lights" off
Trigger Study Lights Off
Sent INSTEON "Study Lights 2" off
Jan 27, 2019 at 9:25:30 PM
Alexa-Hue Bridge Request received from 10.0.1.121:38427: Setting on state of Alexa device "Downstairs Lights" ["Downstairs Lights"] to OFF
Action Group All Downstairs Lights Off
Virtual Devices sent "Downstairs Lights" off
Sent INSTEON "Breakfast Table" off
Trigger Breakfast Table Off
Error "Family Room Aux Lights" off; send failed (no acknowledgment)
Sent INSTEON "Family Room Eyeballs" off
Sent INSTEON "Kitchen Main Lights" off
Trigger Kitchen Main Light Off
Sent INSTEON "Island Chandelier" off
Sent INSTEON "Under Counter Lights" off
Sent INSTEON "Study Lights" off
Sent INSTEON "Living Room Chandelier" off
Error "Living Room Lamp" off; send failed (no acknowledgment)
Sent INSTEON "Dining Room Chandelier" off
Sent INSTEON "Pantry Light" off
Sent INSTEON "Breakfast Table 2" off
Sent INSTEON "Kitchen Main Lights 2" off
Sun Jan 27, 2019 9:04 pm
wormhole offline
Could it have something to do with it seeming to think the devices are V2 despite the plugin being V3.0.29?
Jan 27, 2019 at 9:37:22 PM
Alexa-Hue Bridge 'Alexa Devices 2' updated and now has no Alexa Devices published
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Second Floor' definition detected in Indigo Device '2nd Floor Hall Lights': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Breakfast Table' definition detected in Indigo Device 'Breakfast Table': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Charlies Closet' definition detected in Indigo Device 'Charlies Closet': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Dining Room' definition detected in Indigo Device 'Dining Room Chandelier': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Beans Room' definition detected in Indigo Device 'Emmas Light': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Family Room Auxillery' definition detected in Indigo Device 'Family Room Aux Lights': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Family Room Eyeballs' definition detected in Indigo Device 'Family Room Eyeballs': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Family Room' definition detected in Indigo Device 'Family Room Main Lights': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Christmas Lights' definition detected in Indigo Device 'Foyer Outlet': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Guest Room' definition detected in Indigo Device 'Guest Room': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Hall Bath Fan' definition detected in Indigo Device 'Hall Bath Fan': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Hall Bath Light' definition detected in Indigo Device 'Hall Bath Light': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Island Light' definition detected in Indigo Device 'Island Chandelier': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Karens Closet' definition detected in Indigo Device 'Karens Closet': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Kitchen Lights' definition detected in Indigo Device 'Kitchen Main Lights': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Living Room Lights' definition detected in Indigo Device 'Living Room Chandelier': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Living Room Lamp' definition detected in Indigo Device 'Living Room Lamp': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Master Bathroom' definition detected in Indigo Device 'Master Bath Main Light': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Master Bedroom' definition detected in Indigo Device 'Master Bed Main Light': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Mudroom Light' definition detected in Indigo Device 'Mudroom Main': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Pantry Light' definition detected in Indigo Device 'Pantry Light': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Playroom Lights' definition detected in Indigo Device 'Playroom Main': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Powder Room Fan' definition detected in Indigo Device 'Powder Room Fan': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Powder Room Light' definition detected in Indigo Device 'Powder Room Light': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Rachels Light' definition detected in Indigo Device 'Rachels Light': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Study Lights' definition detected in Indigo Device 'Study Lights': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Under Counter Lights' definition detected in Indigo Device 'Under Counter Lights': Converting to V3 format.
Alexa-Hue Bridge Error 'Alexa Devices 1' has u27 Alexa Devices published [LIMIT OF 20 DEVICES EXCEEDED - DISCOVERY MAY NOT WORK!!!]
Alexa-Hue Bridge Error Move excess Alexa devices to another existing or new Alexa-Hue Bridge
Alexa-Hue Bridge Error You can't publish any more Alexa Devices - you've reached the maximum of 20 imposed by the plugin on behalf of Amazon Alexa.
Jan 27, 2019 at 9:40:00 PM
Jan 27, 2019 at 9:42:12 PM
Alexa-Hue Bridge 'Alexa Devices 1' updated and now has u20 Alexa Devices published
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Master Bath Jacuzzi Light' definition detected in Indigo Device 'Master Bath Jacuzzi Light': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Master Bath Toilet Fan' definition detected in Indigo Device 'Master Bath Toilet Fan': Converting to V3 format.
Alexa-Hue Bridge Error Alexa Device (Plugin V2.x.x) 'Master Bath Toilet Light' definition detected in Indigo Device 'Master Bath Toilet Light': Unable to convert as Alexa Device Name is already allocated on Alexa-Hue Bridge 'Alexa Devices 1'
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'AV Room' definition detected in Indigo Device 'Theater AV Room': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Theater High Hats' definition detected in Indigo Device 'Theater High Hats': Converting to V3 format.
Alexa-Hue Bridge Alexa Device (Plugin V2.x.x) 'Theater LEDs' definition detected in Indigo Device 'Theater LED Strips': Converting to V3 format.
Alexa-Hue Bridge
Sun Jan 27, 2019 9:28 pm
wormhole offline
yes, i see those, 20 is the limit, there aren't more, and it was converted a year ago when V3 came out...can you make a suggestion? In addition, i deleted those devices and started from scratch. Only have 1 device now with 5 lights added to it to test, nothing shows up with searching for devices on the app. see below
Jan 27, 2019 at 10:29:25 PM
Stopping plugin "Alexa-Hue Bridge 3.0.29" (pid 1349)
Starting plugin "Alexa-Hue Bridge 3.0.29" (pid 1447)
Alexa-Hue Bridge 'Alexa Bridge 1' has u5 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Bridge 1' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Bridge 1' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Bridge 1' started: Host: 10.0.1.100 Port: 8179
Alexa-Hue Bridge sent "Alexa Bridge 1" Discovery Toggle
Alexa-Hue Bridge Stop Discovery . . . . . . . . . .
Alexa-Hue Bridge Stopping Hue Bridge 'Alexa Bridge 1' discovery threads as 'Turn Off Discovery' requested
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Bridge 1' discovery threads as 'Turn On Discovery' requested
Alexa-Hue Bridge 'Alexa Bridge 1' updated and now has u5 Alexa Devices published
Mon Jan 28, 2019 3:57 am
Just reading through and catching up on this thread :)
Version 2 and earlier versions of the plugin stored the Alexa information as properties in the individual Indigo devices that you wanted to control. Version 3 changed to storing the information about the devices you wanted to control in the Alexa-Hue Bridges devices. Version 3 of the plugin doesn't remove the old properties stored in the Individual Indigo devices just in case you needed to roll-back to Version 2 [a sort of safety net].
As you effectively reset the plugin by deleting everything, when the plugin restarted it realised you had nothing defined and offered to convert the information still retained in the individual Indigo devices that you previously controlled. So that explains the V2 / V3 situation.
I would suggest that you use the the web app (accessed via https://alexa.amazon.com) to delete all the devices and then run discovery again by asking Alexa to "Discover Devices".
Not sure if this applies, but sometimes having both Ethernet and Wi-Fi enabled can cause problems. If this is the case it might be worth testing the discovery with one turned off. It does seem to me that this all seemed to start when you did something to your wi-fi (your #1 post).
