Help Request with Plug-In Setup!
Posted: Tue Sep 25, 2018 9:25 pm
Hey everyone! Thank you so much for the great documentation on GitHub. I've spent the past few hours trying to configure, and I think I'm close.
So when I try saying “Alexa, Discover Devices”, the Echo searches and doesn’t find any. I see no log messages in Indigo indicating that it’s being hit up for information. I’ve also tried using the Alexa app with the same results. I am noticing some errors which say the IP address is incorrect, but I’ve retrieved this directly from the router and am pretty certain it’s the Echo. There's also a thing in the device listing that says "no ack", which strikes me as weird. This goes away when I turn on discovery. Here’s what I’m seeing. (Note I’ve enabled ALL the logging.)
- I’m running Indigo 7.1.1, but the machine is on 10.7.5 (the latest that machine can run). I wonder if the OS may be an issue.
- The IP address of the machine running Indigo is 192.168.2.251. I’ve entered this into the Override Host IP address setting just in case it could help.
- The IP address of the Amazon Echo is 192.168.2.205. Under the “Model” menu in the device settings for the Alexia-Hue Bridge, I’ve selected Amazon Echo Device and pasted this in.
- Under the “Model” menu, I’ve also selected “Emulated Hue Bridge [Devices]” and added devices which are associated with Insteon devices in Indigo.
- To double check, I’ve used Terminal and verified there are no other UPNP services running.
- Code: Select all
Sep 25, 2018 10:16:39 PM
Reloading plugin "Alexa-Hue Bridge 3.0.29"
Stopping plugin "Alexa-Hue Bridge 3.0.29" (pid 29249)
Alexa-Hue Bridge Alexa-Hue Bridge shutdown requested
Stopped plugin "Alexa-Hue Bridge 3.0.29"
Starting plugin "Alexa-Hue Bridge 3.0.29" (pid 29311)
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address overridden and specified as: '192.168.2.251'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, non-Echo Network Filter, Method Trace
Started plugin "Alexa-Hue Bridge 3.0.29"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge Error Alexa-Hue Bridge 'Hue Bridge' at address 192.168.2.205 either has an invalid address or invalid port 8178 - specify in Device Config
Alexa-Hue Bridge Error Error in plugin execution ServerReplacedElem:
File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 1165, in deviceUpdated
File "plugin.py", line 562, in didDeviceCommPropertyChange
KeyError: ('forceDeviceStopStart',)
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to www.google.com successfully completed.
Sep 25, 2018 10:22:00 PM
Alexa-Hue Bridge sent "Hue Bridge" Discovery on
Alexa-Hue Bridge Error StandardError detected in Broadcaster.Init for 'Hue Bridge'. Line '79' has error=''port''
Alexa-Hue Bridge Error StandardError detected in Broadcaster.Run for 'Hue Bridge'. Line '91' has error=''discoveryExpiration''
Alexa-Hue Bridge Error StandardError detected in Responder.Init for 'Hue Bridge'. Line '132' has error=''port''
Alexa-Hue Bridge Error StandardError detected in Responder.Run for 'Hue Bridge'. Line '150' has error=''discoveryExpiration''
Alexa-Hue Bridge Starting Hue Bridge 'Hue Bridge' discovery threads as 'Turn On Discovery' requested
Sep 25, 2018 10:22:52 PM
Alexa-Hue Bridge 'Hue Bridge' updated and now has u5 Alexa Devices published
Alexa-Hue Bridge Error Alexa-Hue Bridge 'Hue Bridge' at address 192.168.2.205 either has an invalid address or invalid port 8179 - specify in Device Config
Alexa-Hue Bridge Error StandardError detected in Broadcaster.Run for 'Hue Bridge'. Line '92' has error=''Broadcaster' object has no attribute 'broadcast_packet''
Sep 25, 2018 10:23:22 PM
Alexa-Hue Bridge Error StandardError detected in Responder.Run for 'Hue Bridge'. Line '177' has error=''Responder' object has no attribute 'response_packet''
