Action group "Doesn't Support Dimming" via Routine
Thu Feb 22, 2018 2:27 pm
gt3mike offline
I'm using plugin version 3.0.23 and I've added an Indigo Action Group as an Alexa Device. Turning it on directly using the "Alexa, turn on ______" syntax works fine.
But if I set up an Alexa Routine to turn it on, I get this error:
Alexa-Hue Bridge Error Request received from 'Living Room Dot':57963: Alexa Device "______" doesn't support dimming.
I have the Routine configured to turn it on to 100% brightness. I don't see any option to simply turn it on.
Am I missing something? Is something set up incorrectly?
Workaround: I set up the Alexa Device to also invoke the same Action Group when it is turned off. When I configure the Routine, if I set it to turn the Alexa Device off to 0% brightness, my action group is invoked correctly. This isn't a terrible workaround, but it probably won't work in every scenario.
Thu Feb 22, 2018 4:38 pm
Re: Action group "Doesn't Support Dimming" via Routine
In version 3.0.23, when defining an Alexa Device as an Indigo Action, you can specify the Indigo Dim Action as HANDLE DIM AS ON/OFF.
This was added to specifically handle the Routines because as you say there isn't a way to only turn on or off AFAICS. :)
Also see the V 3.0.23 Pre-Release Notes on Github: 3.0.23 Release - Requires Indigo 7
Thu Feb 22, 2018 4:51 pm
gt3mike offline
Bingo! I knew it was ringing a bell, but I couldn't recall where to find the setting.
