Beginners Guide: Sonos One w/Alexa and Alexa Hue-Bridge
Thu Feb 01, 2018 2:30 am
peteajr offline
Can someone give me step by step instructions as to how to set up the alexa hue bridge and make it work with a Sonos One w/Alexa?
Within the Alexa App I've tried to enable the Phillips Hue Bridge skill. I've created an account and get as far as the app asking me to push the big button on the middle of your bridge. I don't see a button to push and I don't have a hue bridge. I believe the Alexa plug-in is working. The setup in Indigo 7 says the Alexa Hue Bridge is on port 8178, Should I change that to 9100?
Here is some of the log:
Jan 31, 2018, 1:40:30 PM
Starting Indigo Server version 7.1.1 (Mac OS X 10.12.6)
Loading attachments
Loading database "/Users/peteajr/Documents/1639-62nd_Indigo6.indiDb"
Loading plugin "Action Collection 2.0.4"
Starting plugin "Action Collection 2.0.4" (pid 586)
Loading interface "INSTEON Commands 2.0.10"
Starting interface "INSTEON Commands 2.0.10" (pid 587)
Loading plugin "Alexa-Hue Bridge 3.0.20"
Starting plugin "Alexa-Hue Bridge 3.0.20" (pid 588)
Loading plugin "Ring Doorbell 0.1.26"
Starting plugin "Ring Doorbell 0.1.26" (pid 589)
Loading interface "Virtual Devices 2.0.4"
Starting interface "Virtual Devices 2.0.4" (pid 590)
Found disabled interface "Z-Wave 2.0.111"
Found disabled plugin "Airfoil Pro 1.0.9"
Found disabled plugin "Airfoil 1.1.14"
Found disabled plugin "DIRECTV DVR Control 1.1.1"
Found disabled plugin "EasyDAQ Relay Card 2.0.3"
Found disabled plugin "Global Property Manager 2.0"
Found disabled plugin "Growl 2.0.2"
Found disabled plugin "iCal Alarm Processor 2.0.1"
Found disabled plugin "iTunes 2.0.4"
Found disabled plugin "NOAA Weather 2.0.1"
Found disabled plugin "SQL Logger 2.0.7"
Found disabled plugin "Timers and Pesters 2.0.2"
Found disabled plugin "Vera Bridge 1.0.10"
Found disabled plugin "WeatherSnoop 2.1.3"
Bonjour registered "Indigo - 1639-62nd_Indigo6"
Reflector starting reflector connection to https://casa_colorada.indigodomo.net
Started interface "Virtual Devices 2.0.4"
Started plugin "Action Collection 2.0.4"
Started interface "INSTEON Commands 2.0.10"
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address is discovered as: '192.168.2.19'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge No debugging requested
Started plugin "Alexa-Hue Bridge 3.0.20"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'Sonos One Living Room' has 4 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Sonos One Living Room' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Sonos One Living Room' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Sonos One Living Room' started: Host: 192.168.2.19 Port: 8178
WebServer client connected
WebServer started on port 8176 -- digest authentication enabled
Started plugin "Ring Doorbell 0.1.26"
Indigo Cocoa client connected
Ring Doorbell Number of devices found: 1
Ring Doorbell Front Door (id: 4565314)
Ring Doorbell Checking for updates...
Ring Doorbell No updates are available
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to www.google.com successfully completed.
Alexa-Hue Bridge Alexa-Hue Bridge checking for Plugin update
Alexa-Hue Bridge Checking for updates...
Alexa-Hue Bridge No updates are available
Alexa-Hue Bridge Alexa-Hue Bridge next update check scheduled for: Thursday, 2018-Feb-01 at 13:40
Trigger Ring Motion
Trigger Ring Motion copy
Thu Feb 01, 2018 6:49 am
Re: Beginners Guide: Sonos One w/Alexa and Alexa Hue-Bridge
I'll try and help. :)
However, I am not sure exactly what you are trying to do. :?
The Alexa-Hue Bridge plugin is used to enable Alexa to control Indigo devices or invoke Indigo actions Essentially Alexa will only respond to the the commands: turn on, turn off or dim. This is because when Alexa is communicating with the Alexa-Hue Bridge plugin, Alexa is fooled into thinking "she" is communicating with a Phillips Hue Lamp.
Have you read through the Alexa-Hue Bridge plugin documentation?
You don't need the skill for this to work. When Alexa asks you to press the button on the Hub, that means you need to have discovery active on an Alexa Hue Bridge device.
So if you are looking to control your Sonos via the Alexa-Hue bridge you will need to have the Sonos plugin installed.
If you are looking to have Alexa directly control the Sonos then you don't need to use the Alexa-Hue Bridge. As I haven't got any Sonos devices,I can't advise you how to do this.
Let me know if the above makes sense to you and please post back with further question if needed. :)
Thu Feb 01, 2018 12:24 pm
peteajr offline
Thanks Jon. I'm trying to logically think this through. In order for this to work do I need to set up a new device in Indigo for each Insteon device as an Emulated Hue Bridge device? See attached photo where I have one device called Alexa-Hue Bridge. In the setup I've listed all the devices I want to control.
Perhaps I'm going about this in the wrong way?
Instead of "Alexa, discover devices" I should say "Alexa, turn on Front Porch"?
-Pedro
Thu Feb 01, 2018 12:42 pm
Hi Pedro,
You appear to have setup your Alexa devices OK (using the Edit Device Settings for the 'Sonos One Living Room' Alexa-Hue Bridge device). You need to say "Alexa discover devices". It should report back "n devices discovered" (where n is the number of devices defined) or "no new devices discovered" if you have done this a number of times.
Has this step worked OK for you i.e. has Alexa told you that she has discovered devices?
Assuming she has, you should now be able to control your devices by saying e.g. "Alexa turn on back porch".
You can check in the iOS Alexa App to see what devices have been discovered by clicking on 'Smart Home' in the App menu - it should list the devices discovered. :)
Thu Feb 01, 2018 12:57 pm
peteajr offline
Update: I tried "Alexa turn on Front Porch" she answered "Sorry I didn't find Front Porch"
Thu Feb 01, 2018 1:07 pm
peteajr offline
Update: Alexa says can't find devices for your Smarthome. If you haven't already please enable the smart home skill for your device from the Alexa app. Which brings us back to the original post about enabling SmartHome skills. The Sonos skill is enabled and Alexa responds to requests for using Sonos such as playing music on Sonos Living Room and other Sonos devices.
Thu Feb 01, 2018 5:17 pm
Londonmark offline
Have you put your bridge into discover mode (shows as On in Indigo) and then said Alexa discover devices?
Fri Feb 02, 2018 4:54 pm
What type of Echos are you using? The latest Echo (Gen 2) can't discover devices.
The plugin will create entries in the Indigo Event Log when you run a discovery telling what devices it is publishing to Alexa.
Sat Feb 10, 2018 3:40 pm
peteajr offline
I must be missing a step or two.
I am using a new Sonos One w/Alexa. Alexa tells me she's found no devices; please enable the smart home skill. I don't know what smart home skill to enable as there are many. I tried enabling the Phillips Hue Bridge but that requires a piece of hardware called Phillips Hue Bridge..
I just restarted the Indigo server and everything regarding Alexa-Hue Bridge looks fine. 'Sonos One Living Room' has 11 Alexa Devices published.
The log is below. Could 'Started interface "Virtual Devices 2.0..4" be causing a conflict?
Within the Indigo devices list a green dot and Discovery: On appears next to the Sonos One Living Room device.
Log:
Feb 10, 2018, 1:18:10 PM
Loading attachments
Starting plugin "Action Collection 2.0.4" (pid 2677)
Starting interface "INSTEON Commands 2.0.10" (pid 2678)
Starting plugin "Alexa-Hue Bridge 3.0.20" (pid 2679)
Starting plugin "Ring Doorbell 0.1.26" (pid 2680)
Starting interface "Virtual Devices 2.0.4" (pid 2681)
Alexa-Hue Bridge 'Sonos One Living Room' has 11 Alexa Devices published
Feb 10, 2018, 1:18:17 PM
Ring Doorbell Warning A new version is available: https://github.com/mpoulson/Indigo-Ring ... tag/0.1.27
Connected to PowerLinc 2413U interface on port usbserial-A4016OOL
PowerLinc address 1E.DA.65, firmware version 9.11
Alexa-Hue Bridge Alexa-Hue Bridge next update check scheduled for: Sunday, 2018-Feb-11 at 13:18
Sun Feb 11, 2018 1:52 am
peteajr wrote:
... I am using a new Sonos One w/Alexa. Alexa tells me she's found no devices ...
I think that is the issue. The plugin is known to be able to discover with the Amazon Echo (Gen 1) and the Amazon Echo Dot (Gen 1 & Gen 2). Other Amazon Echos such as Echo Show and Echo (Gen 2) don't appear to be able to discover via the plugin.
I suspect your simplest solution will be to purchase an Echo Dot to do the discovery and then your Sonos One w/Alexa will hopefully be able to control your devices via the plugin.
I don't know if anyone else has got a Sonos One w/Alexa to work with the plugin?
You might be a trail blazer with this device. :)
Mon Feb 12, 2018 4:20 pm
peteajr offline
I got a message from the folks at Sonos saying that indeed I would need a Phillips Hue Bridge for this to function properly.
I'm wondering: wouldn't the Insteon Hub do the same thing and talk directly to the Sonos/w Alexa? It would seem to me that Insteon Devices>Insteon Hub>Alexa would be a direct link. I'm going to search for the Insteon Hub topic.
Sat Feb 17, 2018 3:06 pm
peteajr offline
Got the Phillips Hue Bridge Hub, still Nada! This is kind of frustrating not being able to find answers to this problem. My next step is to purchase the Insteon Hub that claims to work with Alexa. That would mean running the Indigo system and the Insteon hub system concurrently so that I can have Alexa working. Wish someone could give me a step by step procedure to get this to work with Indigo alone. :(
Sat Feb 17, 2018 4:16 pm
Colly offline
Hi peteajr,
I don't know the cost of the Insteon Hub but I'm guessing the Echo Dot is cheaper and will most likely solve your problem as Autolog points out.
Once the Dot discovers your devices then the Sonos One should work fine, it will also come in handy to use in another part of your house :) .
PS. I don't think you needed to buy the Philips Hue Bridge as it's not required for the plugin to work..
Sun Feb 18, 2018 9:04 am
As @Colly said, you need to follow my advice and re-read my post as I have already answered your question. :wink:
All the Alexa-Hue Bridge plugin needs to discover devices is an Echo (Gen 1) or Echo Dot (Gen 1 or Gen 2) to communicate with. You don't need to install/activate any Skills or use other hardware.
As I said in my previous post, I am not sure whether anyone else has tried a Sonos One w/Alexa and if it works or not. As @Colly said, it probably will, but you need to use an Amazon device (as previously noted) to successfully discover devices.
Hope this helps . :)
Wed Feb 21, 2018 1:49 pm
peteajr offline
OK. Thanks. I'll get an Echo and see what happens.
Thanks all for your patience with me. :oops:
