- Code: Select all
Dec 21, 2017 at 2:19:46 PM
Alexa-Hue Bridge 'Alexa Hub (Rooms)' updated and now has 9 Alexa Devices published
Dec 21, 2017 at 2:20:19 PM
Alexa-Hue Bridge Error getHueDeviceJSON exception:
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/hue_listener.py", line 303, in getHueDeviceJSON
alexaDeviceNameKey = PLUGIN.globals['alexaHueBridge'][ahbDevId]['hashKeys'][alexaDeviceHashedKey]
KeyError: '349a55b16a1e2034edd3bfedbef54e82ba37b515c09f209cea7816859a3db77c'
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'Alexa Hub (Upstairs)'. Line '154' has error='must be string or buffer, not None'
KeyError: '27808b2cd97ec60300a4b89c4c41772ed3f7fb2ee9a1a513a5a74ba24c83e2b6'
KeyError: '2026db2ab953dd9d6a423f6e584963a7841ae647c4ca26be5e92948a40425e15'
I restarted the Alexa plugin to see if that would fix it and then went to my Alexa site to discover my new devices and:
- Code: Select all
Dec 21, 2017 at 2:22:11 PM
Reloading plugin "Alexa-Hue Bridge 3.0.20"
Stopping plugin "Alexa-Hue Bridge 3.0.20" (pid 422)
Alexa-Hue Bridge Alexa-Hue Bridge shutdown requested
Alexa-Hue Bridge HTTP server stopping...
Alexa-Hue Bridge HTTP server stopped
Stopped plugin "Alexa-Hue Bridge 3.0.20"
Starting plugin "Alexa-Hue Bridge 3.0.20" (pid 21150)
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address is discovered as: '10.1.200.3'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge No debugging requested
Started plugin "Alexa-Hue Bridge 3.0.20"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge 'Alexa Hub (Admin)' has 8 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Hub (Admin)' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Hub (Admin)' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Hub (Admin)' started: Host: 10.1.200.3 Port: 8186
Alexa-Hue Bridge 'Alexa Hub (Basement)' has 10 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Hub (Basement)' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Hub (Basement)' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Hub (Basement)' started: Host: 10.1.200.3 Port: 8185
Alexa-Hue Bridge 'Alexa Hub (Rooms)' has 9 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Hub (Rooms)' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Hub (Rooms)' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Hub (Rooms)' started: Host: 10.1.200.3 Port: 8183
Alexa-Hue Bridge 'Alexa Hub (Upstairs)' has 20 Alexa Devices published
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Hub (Upstairs)' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Alexa Hub (Upstairs)' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Alexa Hub (Upstairs)' started: Host: 10.1.200.3 Port: 8184
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to www.google.com successfully completed.
Dec 21, 2017 at 2:22:44 PM
Now all my new devices got discovered but the message keeps complaining. I can see from the messages that it's the Upstairs, which is my most populated server, but I don't see any problems with it. I opened up the config and saved it again in case there was something amok.
Things are working, I believe, but wanted to put this up there so you could diagnose any error trapping issues that might be occurring.
