New Alexa User
Sat Nov 04, 2017 7:28 pm
Re: New Alexa User
What kind of Echo is it? The Echo Show (as far as I know) just doesn't work with the plugin.
Sun Nov 05, 2017 9:41 am
jyarington offline
Re: New Alexa User
Its the new 2nd generation echo not the show or the one with the integrated Phillips hub.
Sun Nov 05, 2017 10:39 am
Re: New Alexa User
Still no messages from the Echo in the log. :|
I presume from the other messages that UPNP is enabled in your router?
Maybe anyone else reading this thread with a 2nd Gen Echo can confirm whether it works or not?
Sun Nov 05, 2017 9:18 pm
ckeyes888 offline
Re: New Alexa User
I have a 2nd gen dot that works fine with the plugin.
Carl
Mon Nov 06, 2017 8:41 am
jyarington offline
Re: New Alexa User
Thanks thats reassuring. I am wondering if its an apple extreme router issue. I know that its does not support Upnp. I can try and add the hub port to the port mapping on the router and see what happens. I had to do that for the indigo IOS app to work.
Mon Nov 06, 2017 10:42 am
Re: New Alexa User
I believe jyarington said a second generation Echo (not Dot). I've been a bit concerned about the next generation of Echos given that the Show doesn't work (i.e. any Echos that ship after the Show first shipped). So the question remains: anyone have a second generation Echo (not a Dot, the one with fabric, wood-look or silver finish) working with the plugin?
Thu Nov 09, 2017 8:11 am
jyarington offline
Re: New Alexa User
I have been trying different things to see if I could get things working and I noticed today that the plug in sent a response to the echo. I did a full network reboot so Alex got a new IP 192.168.1.52. I turned off WOL on the 2 AV recievers so they were not listening in stand by mode. I did a port search on the echo and it found no open ports. They could be blocked from the search. Let me know if you see anything different in the new log.
log.txt
(22.43 KiB) Downloaded 33 times
Fri Nov 10, 2017 11:11 am
kennybroh offline
Re: New Alexa User
Yes-- I just got a couple of 2nd Get Echos. Honestly I haven't been focusing on the Alexa-Indigo integration as much as I once did because I assume it is still subject to the same limitations on number of devices, etc. But I'm happy to dive in and test whatever the issue might be with the new gens. I have several different types of1st gen units now--a couple of Echos, Dots, and one Tap.
How can I help?
Sat Nov 11, 2017 9:46 am
Re: New Alexa User
I have had a look at the log and tried to replicate the scenario on my test system.
At the point where the plugin is returning the response :
<?xml version="1.0"?>\
<root xmlns="urn:schemas-upnp-org:device-1-0">\
<specVersion>\
<major>1</major>\
<minor>0</minor>\
</specVersion>\
<URLBase>http://192.168.1.19:8179/</URLBase>\
<device>\
<deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>\
<friendlyName>Alexa Hue Bridge</friendlyName>\
<manufacturer>Royal Philips Electronics</manufacturer>\
<manufacturerURL>http://www.philips.com</manufacturerURL>\
<modelDescription>Philips hue Personal Wireless Lighting</modelDescription>\
<modelName>Philips hue bridge 2012</modelName>\
<modelNumber>929000226503</modelNumber>\
<modelURL>http://www.meethue.com</modelURL>\
<serialNumber>001788101fe2</serialNumber>\
<UDN>uuid:c58f23d4-c261-11e7-b4c9-a8206612046e</UDN>\
<presentationURL>index.html</presentationURL>\
<iconList>\
<icon>\
<mimetype>image/png</mimetype>\
<height>48</height>\
<width>48</width>\
<depth>24</depth>\
<url>hue_logo_0.png</url>\
</icon>\
<icon>\
<height>120</height>\
<width>120</width>\
<depth>24</depth>\
<url>hue_logo_3.png</url>\
</icon>\
</iconList>\
</device>\
</root>\
My log then sees the request:
GET /api/SNWhIkUf8bYmMu7FoMPEyUFwEYYoP8QrrzwsZbOI/lights HTTP/1.1
which is asking the plugin to return the list of devices.
I don't see that in your log.
So it seems we are getting further but not quite far enough. :|
Sat Nov 11, 2017 9:49 am
Re: New Alexa User
How can I help?
Version 3 of the plugin has removed the restriction on number of devices by allowing multiple Alexa-Hue bridges and 20 devices per Alexa-Hue bridge.
It would be very helpful if you could test whether the new 2nd Gen Echo can be used to discover devices using the latest version of the plugin. :)
Sat Nov 11, 2017 9:53 am
kennybroh offline
Re: New Alexa User
OK. Are those "virtual" alexa-hue bridges?
Sat Nov 11, 2017 10:09 am
Re: New Alexa User
Yes and they are setup as Indigo devices (which is different to how the earlier versions of the plugin worked).
Have a look at the README (on how to set it up) at https://github.com/IndigoDomotics/alexa-hue-bridge
Note: The documentation will be moved to the Wiki in the near future :)
Sat Nov 11, 2017 10:10 am
kennybroh offline
Re: New Alexa User
OK, and is an Insteon hub part of this? I ask because I have one, but it seems to have died... no light at all.
Sat Nov 11, 2017 10:12 am
kennybroh offline
Re: New Alexa User
Just saw that I am running V. 1.1 of the plugin!
Sat Nov 11, 2017 10:15 am
kennybroh offline
Re: New Alexa User
That page is not responding....
Nevermind on this. Something not just so with my MacMini at the moment...
