Page 3 of 3
Re: Alexa Hue-Bridge v3.0.11 won't allow actions to be set u
PostPosted: Mon Mar 12, 2018 9:18 am
by Colorado4Wheeler
Yea, I think some of those devices may have gotten removed while I've been transitioning from HBB to HKB now that I look at the ID's a bit more.
PostPosted: Mon Mar 12, 2018 10:12 am
by autolog
I think there are actually two different problems evident in your log. One of which is missing device ids and the other is non-thread-safe code. :|
Some of the code (in the HttpRequestHandler) isn't thread-safe. I think this explains why once I filtered out non-Echo network traffic, the plugin became more reliable. I have got some Yamaha Musiccast speakers which output a lot of uPnP traffic which the plugin was picking up. So I think what was happening, was that a request from Alexa would arrive and then get "nuked" by other uPnP traffic. This would result in the "device is not responding" messages.
Currently working on 3.0.27 in an effort to fix it. :)
PostPosted: Mon Mar 12, 2018 3:24 pm
by autolog
Version 3.0.27 now available - see announcement :)
PostPosted: Tue Oct 09, 2018 3:51 pm
by mgolden50
All of these changes to support Indigo actions have been working great for months.
But with the upgrade to Indigo 7.2 and the change by Amazon in the devices and routines UI I'm suddenly getting this error repeating many times in my log.
Interestingly, the Alexa routines and associated actions continue to work in spite of the error messages. The Alexa app now shows a red dot and the phrase "there was a problem" on every "device" and their is a ret dot also with the device/action command associated with each routine.
Not sure if Ive done something wrong or this relates to the above updates.
any help is appreciated.
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'self.ahbDev.name'. Line '185' has error='must be string or buffer, not None'
Alexa-Hue Bridge Error StandardError detected in HttpdRequestHandler for 'Alexa Hue-Bridge 09'. Line '185' has error='must be string or buffer, not None'
Alexa-Hue Bridge Error getHueDeviceJSON exception:
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Alexa-Hue Bridge.indigoPlugin/Contents/Server Plugin/hue_listener.py", line 331, in getHueDeviceJSON
self.alexaDeviceNameKey = PLUGIN.globals['alexaHueBridge'][p1_ahbDevId]['hashKeys'][p3_alexaDeviceHashedKey]
KeyError: 'a0f340c8e049c0b80e75723e5cd0f301cba4f2dd5c73a1eb93e22735f5b2cf2d'
Thx
Mike
PostPosted: Tue Oct 09, 2018 4:14 pm
by mgolden50
Never mind--
sorry for the necessary post. I solved the problem.
Thx
Mike
PostPosted: Thu Oct 11, 2018 6:17 am
by mvignola29
Hi Mike
How did you solve the problem, I am getting the same errors.
Any help is appreciated
PostPosted: Thu Oct 11, 2018 10:46 am
by mgolden50
Turns out I haven't fully resolved the issue. But I was able to stop the error messages from flooding my log.
That solution was discovering that I needed to delete the actions from Hue-Bridge that were causing the errors and recreate those actions. In the Alexa app I also deleted those commands from Devices and re-discovered them. Those actions now work properly without error messages.
However, in the app every Hue "Light" command says still says "there is a problem". I have no idea what the app doesn't like about the actions. Especially since the actions seem to work.
