Error Message
Wed Dec 23, 2020 3:22 pm
Bildhauer offline
Error Message
Hello,
what can I do to avoid the following error:
    Z-Wave received "Taster Büro" scene 6 (0006)
    Z-Wave Watcher Debug Raw command received (Node 197): 01 0B 00 04 00 C5 05 5B 03 61 00 06 0F
    Z-Wave Scene Controller Debug Node ID 197 found in controllerIDs
    Z-Wave Scene Controller Debug -----
    Z-Wave Scene Controller Debug Version: 1.0.41
    Z-Wave Scene Controller Debug Central Scene Command received:
    Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 C5 05 5B 03 61 00 06 0F
    Z-Wave Scene Controller Debug Node: 197
    Z-Wave Scene Controller Debug Button: 6
    Z-Wave Scene Controller Debug ActionID: 0
    Z-Wave Scene Controller Debug Action: Click
    Z-Wave Scene Controller Debug 403 i: 0
    Z-Wave Scene Controller Debug 410 dA List: deviceAddress
    Z-Wave Scene Controller Debug 414 dAddress: 677091038
    Z-Wave Scene Controller Error Error in plugin execution ReceivedBroadcast:
    File "plugin.py", line 257, in zwaveCommandReceived
    File "plugin.py", line 421, in triggerEvent
    UnicodeEncodeError: 'ascii' codec can't encode character u'\xfc' in position 5318: ordinal not in range(128)
I'm using version 1.041!
Thanks in advance for your help!
Best regards
Stephan O. Merckens
Wed Dec 23, 2020 4:21 pm
Re: Error Message
HI Stephan
Either rename your trigger without umlaut's or turn off Debug for the plugin.
I've put a fix in the next release ready for when I get round to it.
Peter
Fri Dec 25, 2020 3:21 pm
Bildhauer offline
Re: Error Message
Ok, renaming without Umlaut did work.
Best regards
Bildhauer
