Scene Controllore 1.0.40 Not executing commands
Posted:
Fri Sep 11, 2020 7:02 am
by Sharek326
Recently upgraded to version 1.0.40. Prior all my commands were working using the original release. Now all the scenes stopped responding I deleted all of the scenes and only recreated 1 just to troubleshoot.
I am using the Aeotec Minimote set to single click button 1 to toggle on / off a light. The log shows the key press but nothing happens
Sep 11, 2020, 9:00:14 AM
Z-Wave received "Office Minimote" button 1 pressed
Re: Scene Controllore 1.0.40 Not executing commands
Posted:
Fri Sep 11, 2020 9:14 am
by howartp
Hi Sharek
Stick a ZWave Watcher on the minimote so we can see what's coming in/out.
If the Mac and Indigo is seeing the commands, there's no reason why the plugin won't.
Peter
Posted:
Fri Sep 11, 2020 1:33 pm
by Sharek326
Setup watcher on the Minimote and get this
Sep 11, 2020, 3:32:29 PM
Z-Wave Watcher Debug Raw command received (Node 81): 01 0A 00 04 00 51 04 2B 01 01 00 8F
I also noticed it isn't just the MiniMote. The Quad Wallmote in the Bath is doing the same no scenes will execute here is a button push from that to turn on 4 HUE bulbs on the vanity
Sep 11, 2020, 5:51:43 PM
Z-Wave received "Bath Wallmote" button 1 pressed
Z-Wave Watcher Debug Raw command received (Node 49): 01 0B 00 04 00 31 05 5B 03 7E 00 01 E3
Posted:
Sun Sep 13, 2020 8:38 am
by howartp
Turn on the plugin debug (Indigo > Plugins > ZWave Scene Controller > Configure) then restart the plugin.
The first thing it does is subscribe to incoming commands.
When any 2B01 command (Basic Scene) is received, it will log it even if it has no corresponding trigger to do anything.
Peter
Posted:
Sun Sep 13, 2020 4:14 pm
by Sharek326
When I rolled it back to .28 everything is fine. I upgraded again to .40 everything stops working ......
Here is the debug on and plugin restarted
Sep 13, 2020, 6:12:21 PM
Stopping plugin Z-Wave Scene Controller (pid 91141)
Stopped plugin Z-Wave Scene Controller
Upgrading plugin Z-Wave Scene Controller to newer version 1.0.40 (previous version moved to trash)
Loading plugin "Z-Wave Scene Controller 1.0.40"
Starting plugin "Z-Wave Scene Controller 1.0.40" (pid 6223)
Started plugin "Z-Wave Scene Controller 1.0.40"
Z-Wave received "Office Outlet" energy total to 337.449 kWh
Z-Wave received "Office Outlet" power load to 65.949 W
Indigo Cocoa client authenticated (192.168.100.73)
Z-Wave Scene Controller Debug logging enabled
Reloading plugin "Z-Wave Scene Controller 1.0.40"
Stopping plugin "Z-Wave Scene Controller 1.0.40" (pid 6223)
Z-Wave Scene Controller Debug Stop processing trigger Office Light On / Off
Z-Wave Scene Controller Debug Stop processing trigger Poweder Vanity Off
Z-Wave Scene Controller Debug Stop processing trigger Poweder Vanity On
Z-Wave Scene Controller Debug Stop processing trigger WallMote Vanity Off
Z-Wave Scene Controller Debug Stop processing trigger WallMote Vanity On
Z-Wave Scene Controller Debug Stop processing trigger WallMote Vanity On Purple
Z-Wave Scene Controller Debug Stop processing trigger WallMote Wirlpool
Z-Wave Scene Controller Debug shutdown called
Stopped plugin "Z-Wave Scene Controller 1.0.40"
Starting plugin "Z-Wave Scene Controller 1.0.40" (pid 6466)
Z-Wave Scene Controller Debug startup called -- subscribing to all incoming Z-Wave commands
Z-Wave Scene Controller Debug Start processing trigger Office Light On / Off
Z-Wave Scene Controller Debug Start processing trigger Poweder Vanity Off
Z-Wave Scene Controller Debug Start processing trigger Poweder Vanity On
Z-Wave Scene Controller Debug Start processing trigger WallMote Vanity Off
Z-Wave Scene Controller Debug Start processing trigger WallMote Vanity On
Z-Wave Scene Controller Debug Start processing trigger WallMote Vanity On Purple
Z-Wave Scene Controller Debug Start processing trigger WallMote Wirlpool
Posted:
Mon Sep 14, 2020 12:16 am
by howartp
Can you send me the zip or .indigoPlugin file for .28
I didn't used to keep old versions so I don't have that one to compare back to.
Peter
Posted:
Mon Sep 14, 2020 6:16 am
by Sharek326
The .28 Plugin? sure where do you want me to send it to
Posted:
Mon Sep 14, 2020 10:37 am
by howartp
I’ll send you a pm.
Posted:
Mon Sep 14, 2020 1:59 pm
by Sharek326
I emailed it
