NEO COOLCAM SOS Alarm 4 button keyfob
Wed Jan 31, 2018 10:24 am
SpikeB offline
I got everything working, only think is, when I click on one of the 3 buttons event log is responding saying scene 1,2 or 3, when I want to switch between scene 1,2 or 3 the scene controller device is only responding on first 1-click and then I have to double-click to switch, and 1-click to switch again.
Thu Feb 01, 2018 2:30 am
Re: NEO COOLCAM SOS Alarm 4 button keyfob
Hi Spike.
I’m not sure I follow.
Could you explain more?
Peter
Thu Feb 01, 2018 3:49 am
SpikeB offline
Event log is saying the key fob works when I press key 1 event log is saying.
Z-Wave received "Hal alarm remote" scene 1
Z-Wave Scene Controller Debug -----
Z-Wave Scene Controller Debug Central Scene Command received:
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 66 05 5B 03 00 00 01 CA
Z-Wave Scene Controller Debug Node: 102
Z-Wave Scene Controller Debug Button: 1
Z-Wave Scene Controller Debug ActionID: 0
Z-Wave Scene Controller Debug Action: Click
Trigger test
Z-Wave Scene Controller Debug Updating device Hal alarm remote key with button 1
Z-Wave Scene Controller Debug 00
Z-Wave Debug SENT setMultiLevelValue: 01 0A 00 13 2C 03 26 01 FF 25 E3 D7
Z-Wave sent "Woonkamer lamp 1 (tbkhome zwave)" on
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 2C 03 26 03 63 9B
Z-Wave Debug . . requestDimmerStatus: node 044, endpoint None, value 99
and the scene controller device is switching to state scene 1.
When I want to switch the scene controller device to state scene 3, I must double-click on button 3, a single click doesn't work to change the state of the device.
Single-click button 3:
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 66 05 5B 03 00 00 03 C8
Z-Wave Debug . . sceneActivateCmd2: node 102, type: 0, scene: 3
Z-Wave received "Hal alarm remote" scene 3
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 66 05 5B 03 00 00 03 C8
Z-Wave Scene Controller Debug Button: 3
Double-click button 3 or click on button 2 and then button 3 gives the same result.
Z-Wave Debug RCVD sceneActivateCmd2: 01 0B 00 04 00 66 05 5B 03 01 00 03 C9
Z-Wave Scene Controller Debug Raw command: 01 0B 00 04 00 66 05 5B 03 01 00 03 C9
Trigger test copy
Z-Wave Scene Controller Debug Updating device Hal alarm remote key with button 3
Z-Wave Scene Controller Debug 11
Z-Wave Debug SENT setMultiLevelValue: 01 0A 00 13 2C 03 26 01 00 25 F2 39
Z-Wave sent "Woonkamer lamp 1 (tbkhome zwave)" off
Z-Wave Debug RCVD requestDimmerStatus: 01 09 00 04 00 2C 03 26 03 00 F8
Z-Wave Debug . . requestDimmerStatus: node 044, endpoint None, value 0
I discovered that the first press key command is a single click, en the second press key command must be a double click (same or different button(s)), it doesn't matter which scene you choose.
Thu Feb 01, 2018 12:31 pm
SpikeB offline
Hello Peter,
I got it working, I used incoming command (raw packet)
Regards,
Spike
Thu Feb 01, 2018 1:17 pm
I still want to re-read the thread later and see what’s going on; it should be doing everything right.
