ReloadPlugin() caught exception: FileIOError -- cannot move:
Tue Mar 20, 2018 4:43 pm
qcvictor offline
After Disable HBB plugin for installing HomeKit Bridge and re-enable HBB, got this error :
ReloadPlugin() caught exception: FileIOError -- cannot move: destination file exists
I tried to update latest release same behavior
Upgrading plugin EPS - Homebridge Buddy to newer version 1.0.6 (previous version moved to trash)
Error ReloadPlugin() caught exception: FileIOError -- cannot move: destination file exists
Annoying
Tue Mar 20, 2018 4:49 pm
Colorado4Wheeler offline
Re: ReloadPlugin() caught exception: FileIOError -- cannot m
Sounds like it could be a file system issue. Have you tried just installing the new version by hand? It's pretty simple, just paste the new plugin over the old one, done and done.
Tue Mar 20, 2018 4:55 pm
That means you have two copies of the plugin: one in the Plugins folder and the other in the Plugins (Disabled) folder in your install folder:
/Library/Application Support/Perceptive Automation/Indigo 7/
So when you try to disable the plugin, it fails (because a disable moves from one folder to the other).
Tue Mar 20, 2018 4:57 pm
Awesome to know that, it's not the first time I've read a post about that, now I have a definitive answer!
Tue Mar 20, 2018 5:01 pm
qcvictor offline
Ok that's mean I have to flush this one in the Plugins (Disabled) or the other location ?
Tue Mar 20, 2018 5:03 pm
Well you could just move it out of one or the other so that the file error doesn't happen, you don't have to delete it. But why are you worried about deleting it? All of the devices are saved in Indigo, not the plugin file.
Or did you mean to not say "that's mean"? :shock:
Tue Mar 20, 2018 6:30 pm
You may find it necessary to stop the Indigo server for the change to take effect. If you stop the server, delete one of the two files and restart the server, you should be good to go.
Fri Mar 23, 2018 3:12 pm
qcvictor offline
Finally migrate everything to this fantastic plugin "HomeKit Bridge", even my cheap Chinese cameras work, awesome work Guys thanks for all contributors.
