Device status
Posted: Thu Feb 15, 2018 4:35 pm
SO lately my Garage door has not been updating its status upon me closing it. I'm not sure if its A HBB issue but I'm am receiving this error after I checked "Enable HB experimental status update in the config section.
I am using HBB 1.0.1
It isn't until I click on "Send Status request" on the Garage Door I/O linc that it gets fixed. But I'm not always home to do this.
- Code: Select all
Feb 15, 2018 5:31:05 PM
Sent INSTEON "Garage Door" status request (received input sensor: closed)
Trigger Garage Door is closed
EPS - Homebridge Buddy Debug 'Garage Door' state 'binaryInput1' has changed, notifying 'Garage'
EPS - Homebridge Buddy Error Exception in plugin.homebridgeForceUpdate line 1566: HTTPConnectionPool(host='myserver', port=80): Max retries exceeded with url: /emoncms2/api/post (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x1082c8bd0>: Failed to establish a new connection: [Errno 8] nodename nor servname provided, or not known',))
CODE: r = requests.get('http://myserver/emoncms2/api/post', data=payload)
- Code: Select all
Sent INSTEON "Garage Door" status request (received output relay: off)
Sent INSTEON "PowerLinc Interface" off (scene 1 - Keypad button 6)
Sent INSTEON "Basement Light" off (scene 1 cleanup)
