Is there a homebridge or home bridge buddy for DUMMIES guide
Sat Dec 16, 2017 8:13 pm
george99 offline
Maybe its me, but I can't figure this one out. I downloaded buddy for the plugin store, but the docs say that I have to install home bridge first.
I went to home bridge installation instructions, and it says that I can just use buddy since it installs homebridge.
Either way, I installed buddy, but I am just not getting this.
A little help is appreciated. Help me just turn an instead switch on and off with this and I will be happy.
Sat Dec 16, 2017 9:17 pm
george99 offline
Re: Is there a homebridge or home bridge buddy for DUMMIES g
Well just to clarify, I installed the buddy, and I created a device:
TYPE: EPS - Homebridge Buddy
Model: Homebridge Indigo Server
Called it "Home".
The State of the device show "off". When I try to turn it on, it turns on for a second and then goes back off. Not even sure if I am supposed to do that.
I went into the Home app on my phone and tried to add the 8 digit code as shown in the device address, and it doesn't find anything.
I am lost at this point.
Sat Dec 16, 2017 9:31 pm
george99 offline
Ok, I change the IP in the con gif to 127.0.0.1. And instantly, it started working.
A minute later, it stopped working. Everything shows unavailable, and nothing is working again.
Sun Dec 17, 2017 9:26 am
echiang offline
If you haven't followed from the beginning the homebridge buddy development and the earlier homebridge-indigo plug-in from Webdeck, it's understandable that it can be hard to follow and setup. Anyway, I'll try to help get you started:
Homebridge Buddy automatically creates a home bridge called "Homebridge for Indigo" that by default is running on the same computer as your indigo server.
You then edit the Homebridge for Indigo Device to select your indigo devices that you want to work with Homebridge/Siri. You'll also need to configure the IOS Home app to use the "Homebridge for Indigo" device. A tip: I've found at least for my setup, to always reboot my computer after making changes to the Homebridge for Indigo device. In theory you do not have to reboot, but for my setup, if I don't, then often Indigo becomes unresponsive.
You can find some information on setting up homebridge buddy in this thread "Homebridge Buddy Info & Updates"
viewtopic.php?f=204&t=17405
Also, in the Homebride-master folder that come with the plug-in, check out the "*.adocs" files in the docs subfolder, there is documentation there.
Good Luck.
Sun Dec 17, 2017 4:55 pm
george99 offline
Thanks, I appreciate the tips.
That seems to be working now. My home app on my iphone is finding it now. Great.
However, I included 49 indigo devices (lights only), but it is not showing all of them in the home app.
Instead it is showing apple TVs, Fire Tvs, Sonos's, etc All stuff that I have in my house, but I didn't specify to include.
Any ideas?
Sun Dec 17, 2017 5:06 pm
george99 offline
Well I spoke too soon.
Again the homebridge server is not on. Indigo shows that it is off. If I try to turn on, it doesn't turn on.
I keep seeing this in the log:
 EPS - Homebridge Buddy          Starting the Homebridge server 'Home', do not try to use Siri until you get a message that the server has started
   EPS - Homebridge Buddy          sent "Home" on
   EPS - Homebridge Buddy Warning  The Homebridge server 'Home' has stopped
I just restarted computer too. No luck.
Mon Dec 18, 2017 2:44 pm
Colorado4Wheeler offline
Please check the log file and post your results. I'm guessing that you did not supply the username or password for Indigo. You can find the logs in the Plugin menu under the EPS - Homebridge Buddy option.
Mon Dec 18, 2017 8:03 pm
george99 offline
That's not it, because it did work a few times for a short while (few minutes). If it was a user/pw issue, it wouldn't have worked at all.
While it worked, I was able to confirm it too. Using the Home app, I was able to toggle lights, etc.
Mon Dec 18, 2017 8:06 pm
george99 offline
This is what I get. All in a timespan of a few seconds after reloading the plugin and then clicking "Start Homebridge".
   EPS - Homebridge Buddy          EPS - Homebridge Buddy is loaded and ready to use
Mon Dec 18, 2017 8:10 pm
george99 offline
Ok, I just enabled thread debugging, and now I see this error when reloading:
   EPS - Homebridge Buddy Error    Exception in plugin.homebridgeDiscovery line 1426: No JSON object could be decoded
                      CODE: json_data = json.load(json_file)
Mon Dec 18, 2017 8:42 pm
echiang offline
If devices are not showing up in the IOS Home app, make sure that "Remote Display" is checked in Indigo.
I have an Apple TV in home network and I've never seen it show up in the Indigo logs/homebridge. May be you need to delete/uninstall home bridge buddy in Indigo and start over? Did you delete all the custom homebridges? You probably only want to have the one "Homebridge for Indigo" before trying to setup anything else.
Ed
Mon Dec 18, 2017 9:15 pm
Again, if you could please upload or PM me the Homebridge log that would tell us much more than the Indigo console log.
Mon Dec 18, 2017 9:16 pm
george99 offline
Ok, I swear I didn't do anything. Suddenly the home bridge is working now and I can control devices in the home app.
2 questions:
1. Why is this intermittently working?
2. Why am I a seeing a ton of devices which I didn't include, some of which aren't even in my indigo setup like fire tv and Apple TV. Sonos too.
Mon Dec 18, 2017 9:21 pm
george99 offline
Ahh ok, I didn't realize there was a different log output. Here it is:
Dec 18, 2017 at 22:20:07
   EPS - Homebridge Buddy          [2017-12-18 22:05:43] Loaded plugin: homebridge-indigo
[2017-12-18 22:05:43] Registering platform 'homebridge-indigo.Indigo'
[2017-12-18 22:05:43] ---
[2017-12-18 22:05:43] Loaded plugin: homebridge-itunes
[2017-12-18 22:05:43] Registering platform 'homebridge-itunes.iTunes'
[2017-12-18 22:05:43] Loaded config.json with 0 accessories and 2 platforms.
[2017-12-18 22:05:43] Loading 2 platforms...
[2017-12-18 22:05:43] [Homebridge Server] Initializing Indigo platform...
[2017-12-18 22:05:43] [Homebridge Server] Indigo base URL is http://127.0.0.1:8176
[2017-12-18 22:05:43] Initializing iTunes platform...
[2017-12-18 22:05:43] Loading 0 accessories...
[2017-12-18 22:05:43] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices.json/
[2017-12-18 22:05:43] Error: 34:42: execution error: iTunes got an error: Can’t get selected of AirPlay device id 11475. (-1728)
    at ChildProcess.<anonymous> (/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Homebridge.indigoPlugin/Contents/Server Plugin/bin/hb/node-v8.4.0-darwin-x64/lib/node_modules/homebridge-itunes/node_modules/node-osascript/lib/index.js:39:12)
    at emitTwo (events.js:125:13)
    at ChildProcess.emit (events.js:213:7)
    at maybeClose (internal/child_process.js:927:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:211:5)
[2017-12-18 22:05:43] Error: 34:46: execution error: iTunes got an error: Can’t get sound volume of AirPlay device id 11475. (-1728)
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/AC%20-%20DOWN%20-%20Water%20Detector.json
[2017-12-18 22:05:44] Error: 34:42: execution error: iTunes got an error: Can’t get selected of AirPlay device id 11479. (-1728)
    at Socket.stream.socket.on (internal/child_process.js:348:11)
    at emitOne (events.js:115:13)
    at Socket.emit (events.js:210:7)
    at Pipe._handle.close [as _onclose] (net.js:545:12)
[2017-12-18 22:05:44] [Homebridge Server] Discovered Leak Sensor (ID 764263504): AC - DOWN - Water Detector
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 764263504
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/AC%20-%20Electronics%20-%20LEAK%20SENSOR.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Leak Sensor (ID 640358107): AC - Electronics - LEAK SENSOR
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 640358107
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/AC%20-%20UP%20-%20Water%20Detector.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Leak Sensor (ID 830274435): AC - UP - Water Detector
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 830274435
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/AC%20Shutoff.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Outdoor Appliance (2634) (ID 1852811661): AC Shutoff
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1852811661
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Adi%20-%20Closet.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Relay (ID 668327195): Adi - Closet
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/adi%40nyc8.com//Home.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Homebridge Indigo Server (ID 1866140168): Home
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1866140168
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Alarm.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered ad2usb Keypad (ID 1393892123): Alarm
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1393892123
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Alarm%20On.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Virtual On/Off Device (ID 1380596783): Alarm On
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1380596783
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Danielle.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1395225964): Bathroom - Danielle
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Downstairs.json
[2017-12-18 22:05:44] Error: 34:46: execution error: iTunes got an error: Can’t get sound volume of AirPlay device id 11479. (-1728)
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 418454720): Bathroom - Downstairs
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Guy.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 527449816): Bathroom - Guy
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Hailey.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1629015929): Bathroom - Hailey
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Camera%20Hub%20-%20Electronics%20Room.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Outdoor Appliance (2634) (ID 156883398): Camera Hub - Electronics Room
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 156883398
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Camera%20Hub%20-%20Garage.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Outdoor Appliance (2634) (ID 938441280): Camera Hub - Garage
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 938441280
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Camera%20Hub%20-%20Upstairs.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Outdoor Appliance (2634) (ID 1650573004): Camera Hub - Upstairs
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1650573004
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Car%20Lock%20-%20Raptor.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered I/O-Linc Controller (ID 674407827): Car Lock - Raptor
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 674407827
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Coach%20Lights.json
[2017-12-18 22:05:44] Error: 34:42: execution error: iTunes got an error: Can’t get selected of AirPlay device id 11478. (-1728)
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Relay (ID 1819182796): Coach Lights
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 581979404): Danielle
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle%20-%20Closet.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Relay (ID 123646226): Danielle - Closet
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle%20-%20Vanity.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 509789185): Danielle - Vanity
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Dining%20Room.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 420143582): Dining Room
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Downstairs%20Bathroom%20-%20Vanity.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1177139047): Downstairs Bathroom - Vanity
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Electronics%20Closet.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered 8 Watt LED Bulb (2672-222) (ID 1525850054): Electronics Closet
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Electronics%20Water%20Alarm.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Water/Temperature Sensor (WWA02AA) (ID 1655909028): Electronics Water Alarm
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1655909028
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Foyer.json
[2017-12-18 22:05:44] Error: 34:46: execution error: iTunes got an error: Can’t get sound volume of AirPlay device id 11478. (-1728)
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 535331317): Foyer
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Front%20Door.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Relay (ID 563180445): Front Door
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Garage.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Relay (ID 595574842): Garage
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Garage%20-%20Adi.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered I/O-Linc Controller (ID 1473144236): Garage - Adi
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1473144236
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Garage%20-%20George.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered I/O-Linc Controller (ID 1441843614): Garage - George
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1441843614
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Garage%20Amp.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Outdoor Appliance (2634) (ID 1754988267): Garage Amp
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1754988267
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Garage%20Lock.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SmartCode Lock (ID 1350786833): Garage Lock
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 1350786833
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/George%20-%20Closet.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Relay (ID 271302255): George - Closet
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/george%40nyc8.com//Home.json
[2017-12-18 22:05:44] Error: 34:42: execution error: iTunes got an error: Can’t get selected of AirPlay device id 11477. (-1728)
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guest.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1774471315): Guest
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guy.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1666495297): Guy
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guy%20-%20Vanity.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 870437751): Guy - Vanity
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hailey.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1803065759): Hailey
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hailey%20-%20Vanity.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 203606119): Hailey - Vanity
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hall.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 406614683): Hall
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hall%20-%20Downstairs.json
[2017-12-18 22:05:44] Error: 34:46: execution error: iTunes got an error: Can’t get sound volume of AirPlay device id 11477. (-1728)
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1062686285): Hall - Downstairs
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Home.json
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 16160697): Kitchen
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20-%20Cabinet.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Relay (ID 1961974615): Kitchen - Cabinet
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20-%20Counter.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 523471466): Kitchen - Counter
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20Table.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1629515148): Kitchen Table
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Landing.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 219693695): Landing
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Laundry%20Room.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered SwitchLinc Relay (ID 1940626138): Laundry Room
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20-%20Danielle%20Bathroom.json
[2017-12-18 22:05:44] [Homebridge Server] Discovered Leak Sensor (ID 762782331): Leak - Danielle Bathroom
[2017-12-18 22:05:44] [Homebridge Server] Ignoring excluded ID 762782331
[2017-12-18 22:05:44] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20-%20Guy%20Bathroom.json
[2017-12-18 22:05:44] Error: 34:42: execution error: iTunes got an error: Can’t get selected of AirPlay device id 11480. (-1728)
[2017-12-18 22:05:45] [Homebridge Server] Discovered Leak Sensor (ID 33842602): Leak - Guy Bathroom
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 33842602
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20-%20Hailey%20Bathroom.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Leak Sensor (ID 1927235780): Leak - Hailey Bathroom
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1927235780
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20-%20Master%20Bathroom.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Leak Sensor (ID 1729289775): Leak - Master Bathroom
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1729289775
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20Dishwasher.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Leak Sensor (ID 1976605905): Leak Dishwasher
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1976605905
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20Downstairs%20Bathroom.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Leak Sensor (ID 139789144): Leak Downstairs Bathroom
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 139789144
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20Kitchen%20Sink.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Leak Sensor (ID 50184861): Leak Kitchen Sink
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 50184861
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20Laundry.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Leak Sensor (ID 1730017185): Leak Laundry
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1730017185
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Leak%20Watch.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Leak Watch (ID 1951154079): Leak Watch
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1951154079
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20Fan.json
[2017-12-18 22:05:45] Error: 34:46: execution error: iTunes got an error: Can’t get sound volume of AirPlay device id 11480. (-1728)
[2017-12-18 22:05:45] [Homebridge Server] Discovered FanLinc (ID 1639758859): Living Fan
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1639758859
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20Fan%20Light.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered FanLinc (ID 144614653): Living Fan Light
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20Room.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1478792504): Living Room
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20Switch.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered KeypadLinc Dimmer (2334) (ID 144251889): Living Switch
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 144251889
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Loft.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1386911075): Loft
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Loft%20-%20Closet.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Relay (ID 1236756526): Loft - Closet
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20-%20Vanity.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 125987953): Master - Vanity
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Bathroom.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1953916339): Master Bathroom
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Bedroom.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 350021620): Master Bedroom
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Hall.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1649165143): Master Hall
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Shower.json
[2017-12-18 22:05:45] Error: 34:42: execution error: iTunes got an error: Can’t get selected of AirPlay device id 11476. (-1728)
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 144520526): Master Shower
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Toilet.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 639120450): Master Toilet
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/NOAA.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Weather Station (ID 1212930748): NOAA
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1212930748
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Office.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1739690154): Office
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Pantry.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1687017033): Pantry
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20-%20Fan.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered FanLinc (ID 1531350225): Patio - Fan
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1531350225
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20-%20Fan%20Light.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered FanLinc (ID 98162485): Patio - Fan Light
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20Lights.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 210811730): Patio Lights
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20Switch.json
[2017-12-18 22:05:45] Error: 34:46: execution error: iTunes got an error: Can’t get sound volume of AirPlay device id 11476. (-1728)
[2017-12-18 22:05:45] [Homebridge Server] Discovered KeypadLinc Dimmer (2334) (ID 819652830): Patio Switch
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 819652830
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Pitching%20Machine.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered LampLinc (dual-band) (ID 642422498): Pitching Machine
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 642422498
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Queen.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 480303059): Queen
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Queen%20Dining%20Amp.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Outdoor Appliance (2634) (ID 818771788): Queen Dining Amp
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 818771788
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Screen%20Door.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Binary Sensor (routing) (ID 938154024): Screen Door
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 938154024
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Bathroom.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 1431087670): Sonos - Bathroom
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1431087670
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Garage.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 377331201): Sonos - Garage
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 377331201
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Kitchen.json
[2017-12-18 22:05:45] Error: 34:42: execution error: iTunes got an error: Can’t get selected of AirPlay device id 11481. (-1728)
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 40867635): Sonos - Kitchen
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 40867635
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Living%20Room.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 977206909): Sonos - Living Room
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 977206909
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Loft.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 338560805): Sonos - Loft
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 338560805
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Master%20Bedroom.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 388763307): Sonos - Master Bedroom
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 388763307
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Patio.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 1419680473): Sonos - Patio
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1419680473
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Pool.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 1500909385): Sonos - Pool
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1500909385
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Queen%20Dining.json
[2017-12-18 22:05:45] Error: 34:46: execution error: iTunes got an error: Can’t get sound volume of AirPlay device id 11481. (-1728)
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 584183978): Sonos - Queen Dining
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 584183978
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Veranda.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 1665276582): Sonos - Veranda
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1665276582
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Sonos%20-%20Yard.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Sonos Zone Player (ID 461564188): Sonos - Yard
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 461564188
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Stadium.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Relay Power Switch (ID 613397268): Stadium
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Stairs.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 1627166239): Stairs
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Temperature%20-%20Electronics.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Water/Temperature Sensor (WWA02AA) (ID 1137383453): Temperature - Electronics
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1137383453
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Thermostat%20DOWN.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Thermostat (TH8320ZW1000) (ID 179013801): Thermostat DOWN
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 179013801
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Thermostat%20UP.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Thermostat (TH8320ZW1000) (ID 561158749): Thermostat UP
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 561158749
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/V%20-%20Front%20Lights.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Device Group (ID 1062510973): V - Front Lights
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1062510973
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/V%20-%20Guest%20and%20Laundry.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Device Group (ID 388815013): V - Guest and Laundry
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 388815013
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/V%20-%20Kitchen%20and%20Living%20Room.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Device Group (ID 1778458557): V - Kitchen and Living Room
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1778458557
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/V%20-%20Loft%20and%20Stairs.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Device Group (ID 1459667187): V - Loft and Stairs
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1459667187
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/V%20-%20Master%20Suite.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Device Group (ID 1778438877): V - Master Suite
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1778438877
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/V%20-%20Outside%20Lights.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Device Group (ID 1688633334): V - Outside Lights
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1688633334
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/V%20-%20Queen%20and%20Dining.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Device Group (ID 921182345): V - Queen and Dining
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 921182345
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/V%20-%20Upstairs%20Bed%20%26%20Baths.json
[2017-12-18 22:05:45] [Homebridge Server] Discovered Device Group (ID 1219780722): V - Upstairs Bed & Baths
[2017-12-18 22:05:45] [Homebridge Server] Ignoring excluded ID 1219780722
[2017-12-18 22:05:45] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Veranda.json
[2017-12-18 22:05:46] [Homebridge Server] Discovered SwitchLinc Dimmer (dual-band) (ID 572815344): Veranda
[2017-12-18 22:05:46] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Veranda%20-%20Fan.json
[2017-12-18 22:05:46] [Homebridge Server] Discovered FanLinc (ID 206908138): Veranda - Fan
[2017-12-18 22:05:46] [Homebridge Server] Ignoring excluded ID 206908138
[2017-12-18 22:05:46] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Veranda%20-%20Fan%20Light.json
[2017-12-18 22:05:46] [Homebridge Server] Discovered FanLinc (ID 101423818): Veranda - Fan Light
[2017-12-18 22:05:46] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Veranda%20Switch.json
[2017-12-18 22:05:46] [Homebridge Server] Discovered KeypadLinc Dimmer (2334-232) (ID 1796299582): Veranda Switch
[2017-12-18 22:05:46] [Homebridge Server] Ignoring excluded ID 1796299582
[2017-12-18 22:05:46] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Wall%20Unit.json
[2017-12-18 22:05:46] [Homebridge Server] Discovered LampLinc (dual-band) (ID 968923650): Wall Unit
[2017-12-18 22:05:46] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/WATER%20SHUTOFF%20VALVE.json
[2017-12-18 22:05:46] [Homebridge Server] Discovered I/O-Linc Controller (ID 546212197): WATER SHUTOFF VALVE
[2017-12-18 22:05:46] [Homebridge Server] Ignoring excluded ID 546212197
[2017-12-18 22:05:46] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/WeatherUnderground.json
[2017-12-18 22:05:46] [Homebridge Server] Discovered WUnderground Weather (ID 469440317): WeatherUnderground
[2017-12-18 22:05:46] [Homebridge Server] Ignoring excluded ID 469440317
[2017-12-18 22:05:46] [Homebridge Server] Created 49 accessories
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Adi - Closet'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Bathroom - Danielle'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Bathroom - Downstairs'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Bathroom - Guy'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Bathroom - Hailey'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Coach Lights'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Danielle'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Danielle - Closet'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Danielle - Vanity'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Dining Room'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Downstairs Bathroom - Vanity'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Electronics Closet'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Foyer'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Front Door'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Garage'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'George - Closet'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Guest'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Guy'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Guy - Vanity'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Hailey'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Hailey - Vanity'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Hall'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Hall - Downstairs'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Kitchen'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Kitchen - Cabinet'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Kitchen - Counter'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Kitchen Table'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Landing'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Laundry Room'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Living Fan Light'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Living Room'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Loft'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Loft - Closet'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Master - Vanity'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Master Bathroom'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Master Bedroom'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Master Hall'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Master Shower'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Master Toilet'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Office'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Pantry'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Patio - Fan Light'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Patio Lights'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Queen'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Stadium'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Stairs'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Veranda'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Veranda - Fan Light'...
[2017-12-18 22:05:46] [Homebridge Server] Initializing platform accessory 'Wall Unit'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
    │ 031-45-154 │
[2017-12-18 22:05:46] Homebridge is running on port 51826.
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20-%20Cabinet.json
[2017-12-18 22:11:50] [Homebridge Server] Kitchen - Cabinet: getOnState() => false
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Adi%20-%20Closet.json
[2017-12-18 22:11:50] [Homebridge Server] Adi - Closet: getOnState() => false
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Loft%20-%20Closet.json
[2017-12-18 22:11:50] [Homebridge Server] Loft - Closet: getOnState() => false
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle%20-%20Vanity.json
[2017-12-18 22:11:50] [Homebridge Server] Danielle - Vanity: getOnState() => false
[2017-12-18 22:11:50] [Homebridge Server] Danielle - Vanity: query(brightness) => 0
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Bedroom.json
[2017-12-18 22:11:50] [Homebridge Server] Master Bedroom: query(brightness) => 100
[2017-12-18 22:11:50] [Homebridge Server] Master Bedroom: getOnState() => true
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Loft.json
[2017-12-18 22:11:50] [Homebridge Server] Loft: getOnState() => false
[2017-12-18 22:11:50] [Homebridge Server] Loft: query(brightness) => 0
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Veranda%20-%20Fan%20Light.json
[2017-12-18 22:11:50] [Homebridge Server] Veranda - Fan Light: getOnState() => false
[2017-12-18 22:11:50] [Homebridge Server] Veranda - Fan Light: query(brightness) => 0
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20-%20Vanity.json
[2017-12-18 22:11:50] [Homebridge Server] Master - Vanity: query(brightness) => 0
[2017-12-18 22:11:50] [Homebridge Server] Master - Vanity: getOnState() => false
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20Table.json
[2017-12-18 22:11:50] [Homebridge Server] Kitchen Table: query(brightness) => 0
[2017-12-18 22:11:50] [Homebridge Server] Kitchen Table: getOnState() => false
[2017-12-18 22:11:50] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20-%20Fan%20Light.json
[2017-12-18 22:11:51] [Homebridge Server] Patio - Fan Light: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20-%20Fan%20Light.json
[2017-12-18 22:11:51] [Homebridge Server] Patio - Fan Light: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Foyer.json
[2017-12-18 22:11:51] [Homebridge Server] Foyer: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Foyer: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Office.json
[2017-12-18 22:11:51] [Homebridge Server] Office: query(brightness) => 100
[2017-12-18 22:11:51] [Homebridge Server] Office: getOnState() => true
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hall.json
[2017-12-18 22:11:51] [Homebridge Server] Hall: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Hall: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hailey.json
[2017-12-18 22:11:51] [Homebridge Server] Hailey: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Hailey: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hall%20-%20Downstairs.json
[2017-12-18 22:11:51] [Homebridge Server] Hall - Downstairs: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Hall - Downstairs: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Bathroom.json
[2017-12-18 22:11:51] [Homebridge Server] Master Bathroom: query(brightness) => 100
[2017-12-18 22:11:51] [Homebridge Server] Master Bathroom: getOnState() => true
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Wall%20Unit.json
[2017-12-18 22:11:51] [Homebridge Server] Wall Unit: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Wall Unit: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Garage.json
[2017-12-18 22:11:51] [Homebridge Server] Garage: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Downstairs.json
[2017-12-18 22:11:51] [Homebridge Server] Bathroom - Downstairs: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Bathroom - Downstairs: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Hailey.json
[2017-12-18 22:11:51] [Homebridge Server] Bathroom - Hailey: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Bathroom - Hailey: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guy.json
[2017-12-18 22:11:51] [Homebridge Server] Guy: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Guy: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Guy.json
[2017-12-18 22:11:51] [Homebridge Server] Bathroom - Guy: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Bathroom - Guy: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guest.json
[2017-12-18 22:11:51] [Homebridge Server] Guest: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Guest: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Dining%20Room.json
[2017-12-18 22:11:51] [Homebridge Server] Dining Room: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Dining Room: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Toilet.json
[2017-12-18 22:11:51] [Homebridge Server] Master Toilet: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Master Toilet: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle%20-%20Closet.json
[2017-12-18 22:11:51] [Homebridge Server] Danielle - Closet: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Laundry%20Room.json
[2017-12-18 22:11:51] [Homebridge Server] Laundry Room: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20Lights.json
[2017-12-18 22:11:51] [Homebridge Server] Patio Lights: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Patio Lights: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Shower.json
[2017-12-18 22:11:51] [Homebridge Server] Master Shower: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Master Shower: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Queen.json
[2017-12-18 22:11:51] [Homebridge Server] Queen: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Queen: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/George%20-%20Closet.json
[2017-12-18 22:11:51] [Homebridge Server] George - Closet: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hailey%20-%20Vanity.json
[2017-12-18 22:11:51] [Homebridge Server] Hailey - Vanity: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Hailey - Vanity: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Landing.json
[2017-12-18 22:11:51] [Homebridge Server] Landing: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Landing: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Stadium.json
[2017-12-18 22:11:51] [Homebridge Server] Stadium: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Front%20Door.json
[2017-12-18 22:11:51] [Homebridge Server] Front Door: getOnState() => true
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Stairs.json
[2017-12-18 22:11:51] [Homebridge Server] Stairs: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Stairs: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Coach%20Lights.json
[2017-12-18 22:11:51] [Homebridge Server] Coach Lights: getOnState() => true
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guy%20-%20Vanity.json
[2017-12-18 22:11:51] [Homebridge Server] Guy - Vanity: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Guy - Vanity: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle.json
[2017-12-18 22:11:51] [Homebridge Server] Danielle: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Danielle: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20Fan%20Light.json
[2017-12-18 22:11:51] [Homebridge Server] Living Fan Light: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Living Fan Light: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Downstairs%20Bathroom%20-%20Vanity.json
[2017-12-18 22:11:51] [Homebridge Server] Downstairs Bathroom - Vanity: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Downstairs Bathroom - Vanity: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Hall.json
[2017-12-18 22:11:51] [Homebridge Server] Master Hall: getOnState() => false
[2017-12-18 22:11:51] [Homebridge Server] Master Hall: query(brightness) => 0
[2017-12-18 22:11:51] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Pantry.json
[2017-12-18 22:11:52] [Homebridge Server] Pantry: getOnState() => false
[2017-12-18 22:11:52] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Pantry.json
[2017-12-18 22:11:52] [Homebridge Server] Pantry: query(brightness) => 0
[2017-12-18 22:11:52] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen.json
[2017-12-18 22:11:52] [Homebridge Server] Kitchen: getOnState() => false
[2017-12-18 22:11:52] [Homebridge Server] Kitchen: query(brightness) => 0
[2017-12-18 22:11:52] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20Room.json
[2017-12-18 22:11:52] [Homebridge Server] Living Room: getOnState() => false
[2017-12-18 22:11:52] [Homebridge Server] Living Room: query(brightness) => 0
[2017-12-18 22:11:52] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20-%20Counter.json
[2017-12-18 22:11:52] [Homebridge Server] Kitchen - Counter: getOnState() => false
[2017-12-18 22:11:52] [Homebridge Server] Kitchen - Counter: query(brightness) => 0
[2017-12-18 22:11:52] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Danielle.json
[2017-12-18 22:11:52] [Homebridge Server] Bathroom - Danielle: query(brightness) => 0
[2017-12-18 22:11:52] [Homebridge Server] Bathroom - Danielle: getOnState() => false
[2017-12-18 22:11:52] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Veranda.json
[2017-12-18 22:11:52] [Homebridge Server] Veranda: getOnState() => false
[2017-12-18 22:11:52] [Homebridge Server] Veranda: query(brightness) => 0
[2017-12-18 22:11:52] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Electronics%20Closet.json
[2017-12-18 22:11:52] [Homebridge Server] Electronics Closet: getOnState() => false
[2017-12-18 22:11:52] [Homebridge Server] Electronics Closet: query(brightness) => 0
[2017-12-18 22:12:30] [Homebridge Server] Office: setLightOnState(0)
[2017-12-18 22:12:30] [Homebridge Server] Office: setOnState(false)
[2017-12-18 22:12:30] [Homebridge Server] updateStatus of Office: {"isOn":0}
[2017-12-18 22:12:30] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Office.json
[2017-12-18 22:12:32] [Homebridge Server] Office: setLightOnState(1)
[2017-12-18 22:12:32] [Homebridge Server] Office: setBrightness(100)
[2017-12-18 22:12:32] [Homebridge Server] updateStatus of Office: {"brightness":100}
[2017-12-18 22:12:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Office.json
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20-%20Cabinet.json
[2017-12-18 22:16:32] [Homebridge Server] Kitchen - Cabinet: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Adi%20-%20Closet.json
[2017-12-18 22:16:32] [Homebridge Server] Adi - Closet: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Loft%20-%20Closet.json
[2017-12-18 22:16:32] [Homebridge Server] Loft - Closet: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle%20-%20Vanity.json
[2017-12-18 22:16:32] [Homebridge Server] Danielle - Vanity: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Danielle - Vanity: query(brightness) => 0
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Bedroom.json
[2017-12-18 22:16:32] [Homebridge Server] Master Bedroom: query(brightness) => 0
[2017-12-18 22:16:32] [Homebridge Server] Master Bedroom: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Loft.json
[2017-12-18 22:16:32] [Homebridge Server] Loft: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Loft: query(brightness) => 0
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Veranda%20-%20Fan%20Light.json
[2017-12-18 22:16:32] [Homebridge Server] Veranda - Fan Light: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Veranda - Fan Light: query(brightness) => 0
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20-%20Vanity.json
[2017-12-18 22:16:32] [Homebridge Server] Master - Vanity: query(brightness) => 0
[2017-12-18 22:16:32] [Homebridge Server] Master - Vanity: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20Table.json
[2017-12-18 22:16:32] [Homebridge Server] Kitchen Table: query(brightness) => 0
[2017-12-18 22:16:32] [Homebridge Server] Kitchen Table: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20-%20Fan%20Light.json
[2017-12-18 22:16:32] [Homebridge Server] Patio - Fan Light: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Patio - Fan Light: query(brightness) => 0
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Foyer.json
[2017-12-18 22:16:32] [Homebridge Server] Foyer: query(brightness) => 0
[2017-12-18 22:16:32] [Homebridge Server] Foyer: getOnState() => false
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Office.json
[2017-12-18 22:16:32] [Homebridge Server] Office: query(brightness) => 100
[2017-12-18 22:16:32] [Homebridge Server] Office: getOnState() => true
[2017-12-18 22:16:32] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hall.json
[2017-12-18 22:16:32] [Homebridge Server] Hall: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Hall: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hailey.json
[2017-12-18 22:16:33] [Homebridge Server] Hailey: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Hailey: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hall%20-%20Downstairs.json
[2017-12-18 22:16:33] [Homebridge Server] Hall - Downstairs: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Hall - Downstairs: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Bathroom.json
[2017-12-18 22:16:33] [Homebridge Server] Master Bathroom: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Master Bathroom: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Wall%20Unit.json
[2017-12-18 22:16:33] [Homebridge Server] Wall Unit: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Wall Unit: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Garage.json
[2017-12-18 22:16:33] [Homebridge Server] Garage: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Downstairs.json
[2017-12-18 22:16:33] [Homebridge Server] Bathroom - Downstairs: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Bathroom - Downstairs: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Hailey.json
[2017-12-18 22:16:33] [Homebridge Server] Bathroom - Hailey: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Bathroom - Hailey: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guy.json
[2017-12-18 22:16:33] [Homebridge Server] Guy: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Guy: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Guy.json
[2017-12-18 22:16:33] [Homebridge Server] Bathroom - Guy: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Bathroom - Guy: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guest.json
[2017-12-18 22:16:33] [Homebridge Server] Guest: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Guest: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Dining%20Room.json
[2017-12-18 22:16:33] [Homebridge Server] Dining Room: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Dining Room: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Toilet.json
[2017-12-18 22:16:33] [Homebridge Server] Master Toilet: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Master Toilet: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle%20-%20Closet.json
[2017-12-18 22:16:33] [Homebridge Server] Danielle - Closet: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Laundry%20Room.json
[2017-12-18 22:16:33] [Homebridge Server] Laundry Room: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Patio%20Lights.json
[2017-12-18 22:16:33] [Homebridge Server] Patio Lights: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Patio Lights: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Shower.json
[2017-12-18 22:16:33] [Homebridge Server] Master Shower: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Master Shower: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Queen.json
[2017-12-18 22:16:33] [Homebridge Server] Queen: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Queen: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/George%20-%20Closet.json
[2017-12-18 22:16:33] [Homebridge Server] George - Closet: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Hailey%20-%20Vanity.json
[2017-12-18 22:16:33] [Homebridge Server] Hailey - Vanity: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Hailey - Vanity: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Landing.json
[2017-12-18 22:16:33] [Homebridge Server] Landing: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Landing: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Stadium.json
[2017-12-18 22:16:33] [Homebridge Server] Stadium: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Front%20Door.json
[2017-12-18 22:16:33] [Homebridge Server] Front Door: getOnState() => true
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Stairs.json
[2017-12-18 22:16:33] [Homebridge Server] Stairs: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Stairs: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Coach%20Lights.json
[2017-12-18 22:16:33] [Homebridge Server] Coach Lights: getOnState() => true
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Guy%20-%20Vanity.json
[2017-12-18 22:16:33] [Homebridge Server] Guy - Vanity: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Guy - Vanity: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Danielle.json
[2017-12-18 22:16:33] [Homebridge Server] Danielle: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Danielle: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20Fan%20Light.json
[2017-12-18 22:16:33] [Homebridge Server] Living Fan Light: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Living Fan Light: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Downstairs%20Bathroom%20-%20Vanity.json
[2017-12-18 22:16:33] [Homebridge Server] Downstairs Bathroom - Vanity: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Downstairs Bathroom - Vanity: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Master%20Hall.json
[2017-12-18 22:16:33] [Homebridge Server] Master Hall: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Master Hall: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Pantry.json
[2017-12-18 22:16:33] [Homebridge Server] Pantry: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Pantry: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen.json
[2017-12-18 22:16:33] [Homebridge Server] Kitchen: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Kitchen: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Living%20Room.json
[2017-12-18 22:16:33] [Homebridge Server] Living Room: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Living Room: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Kitchen%20-%20Counter.json
[2017-12-18 22:16:33] [Homebridge Server] Kitchen - Counter: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Kitchen - Counter: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Bathroom%20-%20Danielle.json
[2017-12-18 22:16:33] [Homebridge Server] Bathroom - Danielle: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Bathroom - Danielle: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Veranda.json
[2017-12-18 22:16:33] [Homebridge Server] Veranda: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Veranda: query(brightness) => 0
[2017-12-18 22:16:33] [Homebridge Server] Indigo request: http://127.0.0.1:8176/devices/Electronics%20Closet.json
[2017-12-18 22:16:33] [Homebridge Server] Electronics Closet: getOnState() => false
[2017-12-18 22:16:33] [Homebridge Server] Electronics Closet: query(brightness) => 0
Mon Dec 18, 2017 10:03 pm
Colorado4Wheeler offline
Re: Is there a homebridge or home bridge buddy for DUMMIES g
Please try disabling the iTunes portion of the plugin to see what happens, your errors are tied to that and airplay.
