I recently upgraded from Indigo 6 to 7. Once upgraded I installed the Homebridge Buddy plugin. Inside Indigo I see the Homebridge for Indigo device running and the plugin seems to start up normally. I've added only one insteon switch to Homebridge for simplicity. When trying to pair Homebridge with the iOS Home app I see the Homebridge for Indigo in the select accessory to add to Home window. Once selected the Home app works for about a minute trying to pair then returns a "Couldn't add Homebridge for Indigo - Home couldn't connect to this accessory" error. Do you have any ideas where to start looking to correct this issue? Does Alexa-Hue Bridge interfere with Homebridge? This is installed on a OS X server running Sierra. Log file is as follows: Thanks!
Jan 16, 2017, 1:01:22 PM
EPS - Homebridge Buddy [1/16/2017, 1:00:47 PM] Loaded plugin: homebridge-indigo
[1/16/2017, 1:00:47 PM] Registering platform 'homebridge-indigo.Indigo'
[1/16/2017, 1:00:47 PM] ---
[1/16/2017, 1:00:47 PM] Loaded config.json with 0 accessories and 1 platforms.
[1/16/2017, 1:00:47 PM] Loading 1 platforms...
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Initializing Indigo platform...
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Indigo base URL is http://127.0.0.1:8176
[1/16/2017, 1:00:47 PM] Loading 0 accessories...
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Indigo request: http://127.0.0.1:8176/devices.json/
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Indigo request: http://127.0.0.1:8176/devices/Alexa-Hue%20Bridge.json
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Discovered Emulated Hue Bridge (ID 97112632): Alexa-Hue Bridge
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Ignoring excluded ID 97112632
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Indigo request: http://127.0.0.1:8176/devices/Diningroom%20Light.json
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Discovered SwitchLinc Relay (ID 1819503267): Diningroom Light
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Created 1 accessories
[1/16/2017, 1:00:47 PM] [Homebridge for Indigo] Initializing platform accessory 'Diningroom Light'...
Scan this code with your HomeKit App on your iOS device to pair with Homebridge:
│ 031-45-154 │
[1/16/2017, 1:00:47 PM] Homebridge is running on port 51826.
Config:
an 16, 2017, 1:22:43 PM
EPS - Homebridge Buddy {
"accessories": [],
"bridge": {
"username": "xxx",
"name": "Homebridge for Indigo",
"pin": "031-45-154",
"port": 51826
"description": "Homebridge-Indigo configuration generated by EPS Homebridge Buddy on 2017-01-16 12:50:18 for device Homebridge for Indigo",
"platforms": [
"username": "xxx",
"includeIds": [
"1819503267"
"protocol": "http",
"includeActions": false,
"platform": "Indigo",
"host": "127.0.0.1",
"thermostatsInCelsius": false,
"path": "",
"password": "xxxxxxxx",
"accessoryNamePrefix": "",
"port": "8176"
