Animated GIF for Control Page
Thu Jun 04, 2020 11:52 am
mgolden50 offline
Re: Animated GIF for Control Page
Dave,
Do you have a way I can send you a properly formatted version of the script?
Thu Jun 04, 2020 2:42 pm
Can you attach it to a post as a .txt file?
Thu Jun 04, 2020 4:35 pm
Not sure why it's not formatting in his previous post, but when I copy/paste it into a reply here it worked:
#! /usr/bin/env python2.7
# -*- coding: utf-8 -*-
import os
A prototype script for creating a "ticker tape" style animated, horizontally scrolling
long text string, for use on Indigo control pages based on the ImageMagick library.
import subprocess
## Where the animated GIF image will reside.  Spaces must be escaped.
work_fldr = "/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4/IndigoWebServer/images/controls/static/"
## This variable limits the character width of the "ticker tape" on the Control Page
## The pixel width of the initial .png frame image needs to be sufficient to accomodate
## the specified number of characters at the point size specified in the imageMagick
## setup
DisplayFieldLength = 29
## When finally interrated with Indigo, the line below will point to and Indigo varible.
char_List = "       Today: Sunny, with a high near 108. West wind 5 to 10 mph.      Tonight: Mostly clear, with a low around 78. West wind around 5 mph becoming calm in the evening. "
## The lines following convert the long string into a list of strings that are
## within the specified width and successively moved one character to the left
list_Of_Chars = []
list_Of_Display_FrameStrings = []
t = char_List
for i in range(len(t)):
   t = t[1:] + t[0]
   eachDisplayFrameCharList = t[0:DisplayFieldLength]
   eachDisplayrameString = "".join(eachDisplayFrameCharList)
## This is the final list of Display Field Strigs
   list_Of_Display_FrameStrings.append(eachDisplayrameString)
## Now comes the magic of ImageMagick which converts each display field string into
## a graphic image and combines it with a frame image copied from an initial frame
## template. the new .png frames are then given a sequential number and saved to be
## used by ImageMagic to create the final Gif animation file.
## First part of the output command string.
## The first ImageMagick command specifies the delay time that each animation frame
## waits before the next image is displayed and sets size in pixels of the text image
## within the frame image.
output_cmd = "/opt/local/bin/convert -delay 15 -size 200x27 "
## Next iterate through the items in the list_Of_Display_FrameStrings to create
## sequential frame images based on each sequential display string image.
## those images are saved as enumerated files that will be used to build the animation.
for num in range(1, len(list_Of_Display_FrameStrings) + 1):
   ## Build each frame image setting the font, font color, t texpoint size, and the
   ## reference to the text to be added to the frame image.
   proc = subprocess.Popen("/opt/local/bin/convert {0}bar.png -font arial -fill Goldenrod -pointsize 70 -gravity center  -annotate +10+17  '{1}' "
                            "{0}bar_frame{2}.png".format(work_fldr, list_Of_Display_FrameStrings[num - 1], num), stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
## For debugging, you can look at the shell's return.
    #print(proc.communicate())
    ## Add command to the output command string to save each new frame image.
    output_cmd += "-dispose previous -page +0+0 {0}bar_frame{1}.png ".format(work_fldr, num)
## The last part of the output command string
output_cmd += "-loop 0 {0}bar_animation.gif".format(work_fldr)
## Next to last call ImageMagick to actually build the GIF animation usinge the command
## composed in the preceding line
proc1 = subprocess.Popen(output_cmd, stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
## Finally, emove all of the .png files that were used to create the animaton--since next animated strings may have different file counts
fileCount = len(list_Of_Display_FrameStrings)
for n in range (0,fileCount):
#     print((work_fldr+"bar_frame"+str(n)+".png"))
      cmd_rm = "rm -rf "+work_fldr+"bar_frame"+str(n)+".png"
      os.system(cmd_rm)
   #os.remove ("/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4/IndigoWebServer/images/controls/static/bar_frame1.png")
   except OSError as err:
      print("rm -rf "+work_fldr+"bar_frame"+str(n)+".png")
Thu Jun 04, 2020 5:01 pm
Thanks Jay! I will have a look and see what's what.
Thu Jun 04, 2020 5:43 pm
mgolden50 offline
Hi Dave,
Text file attached hope this works.
Mike
Animated GIF Scrolling Text Generator v0.2 copy.txt
(2.74 KiB) Downloaded 185 times
Thu Jun 04, 2020 5:59 pm
I've dressed up the code a bit--hopefully, it will make it a bit easier for others to follow and use within Indigo. I'm afraid I've never used "APNG Assembler" before, so I can't provide any insights on that front.
import os
import subprocess
    import indigo
except ImportError:
    pass
work_folder = "/Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4/IndigoWebServer/images/controls/static/"
# Page The pixel width of the initial .png frame image needs to be sufficient
# to accommodate the specified number of characters at the point size
# specified in the imageMagick setup
display_field_length = 29
# When finally interrated with Indigo, the line below will point to and Indigo variable.
char_list = u"       Today: Sunny, with a high near 108. West wind 5 to 10 mph.      Tonight: Mostly clear, with a low around 78. West wind around 5 mph becoming calm in the evening."
# within the specified width and successively moved one character to the left.
list_of_display_frame_strings = []
for i in range(len(char_list)):
    char_list = char_list[1:] + char_list[0]
    each_display_frame_char_list = char_list[0:display_field_length]
    each_display_frame_string = "".join(each_display_frame_char_list)
    # This is the final list of Display Field Strings
    list_of_display_frame_strings.append(each_display_frame_string)
# into a graphic image and combines it with a frame image copied from an
# initial frame template. the new .png frames are then given a sequential
# number and saved to be used by ImageMagic to create the final GIF animation
# file. First part of the output command string.
# frame waits before the next image is displayed and sets size in pixels of the
# text image within the frame image.
# sequential frame images based on each sequential display string image. Those
# images are saved as enumerated files that will be used to build the
# animation.
for num in range(1, len(list_of_display_frame_strings) + 1):
    # Build each frame image setting the font, font color, text point size,
    # and the reference to the text to be added to the frame image.
    proc = subprocess.Popen("/opt/local/bin/convert {0}bar.png -font arial -fill Goldenrod -pointsize 70 -gravity center -annotate +10+17 '{1}' {0}bar_frame{2}.png".format(
                            work_folder, list_of_display_frame_strings[num - 1], num), stdout=subprocess.PIPE, stderr=subprocess.PIPE, shell=True)
    # indigo.server.log(proc.communicate())
    output_cmd += "-dispose previous -page +0+0 {0}bar_frame{1}.png ".format(work_folder, num)
output_cmd += "-loop 0 {0}bar_animation.gif".format(work_folder)
# Next to last call ImageMagick to actually build the GIF animation using the
# command composed in the preceding line.
# Finally, remove all of the .png files that were used to create the animation--since next animated strings may have different file counts.
file_count = len(list_of_display_frame_strings)
for n in range(0, file_count):
        indigo.server.log(u"{0}bar_frame{1}.png".format(work_folder, n))
        cmd_rm = "rm -rf {0}bar_frame{1}.png".format(work_folder, n)
        os.system(cmd_rm)
        indigo.server.log(u"rm -rf {0}bar_frame{1}.png".format(work_folder, n))
Thu Jun 04, 2020 6:22 pm
mgolden50 offline
Thanks Dave,
The only help I think I need is how to make a call to the following CLI command with the correct form of reference to the list of png frames in work_fldr created by your code.
apngasm -o outfile.png frame1.png frame2.png frame3.png... through frame.png
I imagine its something equivalent to the popen mechanism you used in your code. but I just don't get the syntax yet.
Anyone else have an idea how to do this.
Mike
Thu Jun 04, 2020 7:46 pm
mgolden50 wrote:
Thanks Dave,
Mike
IIRC, popen generally expects arguments in the form of a list--so it would be something like:
subprocess.popen(["apngasm", "-o", "outfile.png", "frame1.png", "frame2.png", "frame3.png", "frame.png"])
or if you use the shell=True argument then it's all as one long string.
subprocess.popen("apngasm -o outfile.png frame1.png frame2.png frame3.png frame.png", shell=True)
Sun Jun 07, 2020 12:24 pm
mgolden50 offline
Hi again Dave,
Victory!!!
I now have APNG Assembler Python code that will programmatically create both GIF and APNG animations for horizontally scrolling text strings.
However, I think that realtime Indigo Control Page APNG creation might be generally useful for a lot of folks--allowing the content of animations to be modified on the fly while continuously displaying on a Control Page on Safari.
The debugging of the required command line string was fairly nit-picky. The sample terminal command I developed is:
apngasm -F -d 40 -o /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4/IndigoWebServer/images/controls/static/bar_animation.png /Library/Application\ Support/Perceptive\ Automation/Indigo\ 7.4/IndigoWebServer/images/controls/static/bar_frame10.png
When this string worked in terminal,I was only a matter of making it a popen Python command modeled on what you did with ImageMagick. Thanks again for the coaching and examples with ImageMagick.
I may start drinking milk !!!
The [code][/code] function is still not working for me on the forum web site so I'm attaching the code as a text file again.
The flags under the message box shows that BBCode is On.
Thanks again for all of your support.
Mike
Animation Generator for GIF and APNG Formats.txt
(3.64 KiB) Downloaded 194 times
Sun Jun 07, 2020 2:00 pm
Hey, congratulations. I'm glad you were able to find something that will work for you. One suggestion would be to look at whether you could increase the number of frames in the animation. It would (at least theoretically) make the scroll smoother.
Well done!
Sun Jun 07, 2020 2:21 pm
mgolden50 offline
To do that I would need to find a way to make ImageMagic interpolate between a frame and the next frame that is shifted by one character.. Baically shifting the image partial characters worth of pixels to the left. Do you know if Imagick has the capability to do that? I'll do some looking into it. I agree that the character by character scrolling is a bit rough.
Sun Jun 07, 2020 3:42 pm
Unfortunately, I don't think ImageMagick has the capability to do that.
Tue Jun 09, 2020 9:37 am
mgolden50 offline
I have a new wrinkle with the APNG image on a control page on Safari.
When I update the animation content that change is not reflected on the page until I manually refresh the browser.
Is there a way to refresh the browser or the image automatically?
Tue Jun 09, 2020 1:06 pm
What I typically do in those cases is load the image as a Refreshing Image URL object.
