Gnuplot Scripts
Wed Jan 20, 2016 3:48 pm
ckeyes888 offline
Re: Gnuplot Scripts
Those changes work fine for me. Any way to change the linespoints color?
plot dataFileForecast using 1:6 with impulses,\
     dataFileForecast using 1:2:(0) with filledcurves above y1=0 linecolor "#999999",\
     dataFileForecast using 1:2 with linespoints linestyle 2 axes x1y1,\
     dataFileForecast using 1:2:3 with labels textcolor rgb "#FFFFFF",\
     dataFileForecast using 1:4:(0) with filledcurves above y1=0 linecolor "#111111",\
     dataFileForecast using 1:4 with linespoints linestyle 2 axes x1y1,\
     dataFileForecast using 1:4:5 with labels textcolor rgb "#FFFFFF",\
     freezeWarning with filledcurves above y1=0 linecolor rgb "#0066CC"
They're drawing as white for me which is the same color as the temps text running along
the line making them hard to read.
Carl
Wed Jan 20, 2016 4:49 pm
Re: Gnuplot Scripts
afulki wrote:
Thanks Dave,
one more fix :) if you change points to linespoints you get the solid line above the fill
e.g.
this dataFileForecast using 1:4 with points linestyle 2 axes x1y1,\
to dataFileForecast using 1:4 with linespoints linestyle 2 axes x1y1,\
My pleasure. Yeah, the reason that I don't go with linespoints is because I want to plot the line above the fill separately to be able to make its color a neighbor of the fill color.
A matter of preference. :D
Wed Jan 20, 2016 7:23 pm
ckeyes888 offline
Re: Gnuplot Scripts
Just a curiosity at this point but anyone have any idea why the colors are so different
between the 10.5.8 and 10.6.8 versions?
Carl
Wed Jan 20, 2016 7:38 pm
Re: Gnuplot Scripts
I don't know about that, but it may be related to how the colors are calibrated in the OS. There's a ton of color control baked into the system.
About your charts, take a look at the plot order. In gnuplot, each plot line is drawn on top of the last--which is why you see the freeze warning and precip lines written on top of your temperatures.
Dave
Wed Jan 20, 2016 8:26 pm
ckeyes888 offline
Re: Gnuplot Scripts
Good to know, thanks Dave.
Carl
Thu Jun 23, 2016 5:49 am
Re: Gnuplot Scripts
I'm not sure what happened last night. All I can come up with is that Durosity must've picked up a check. :D
Screen Shot 2016-06-23 at 6.41.42 AM.png (26.75 KiB) Viewed 5007 times
Mon Jul 11, 2016 7:48 pm
Re: Gnuplot Scripts
Moderator's note: Moved to the Dave's Scripts forum.
