Startup problem
Sun May 26, 2019 1:50 am
berkinet offline
Startup problem
Normally, the HomeKit Bridge plugin runs just fine. However, if the computer restarts (like after power failure) the plugin will not load when Indigo restarts. Here is the log...
    24 May 2019 at 12:03:39
    Starting Indigo Server version 7.3.0 (Mac OS X 10.14.4)
    Loading attachments
    Loading database "/Library/Application Support/Perceptive Automation/Indigo 7.3/Databases/CasaMilagro.indiDb"
    Loading plugin "HomeKit Bridge 1.0.2"
    Starting plugin "HomeKit Bridge 1.0.2" (pid 952)
    HomeKit Bridge : Caching all HomeKit Bridge devices...
    Started plugin "HomeKit Bridge 1.0.2"
    HomeKit Bridge: Attempting to start 'Casa Milagro HomeKIt Server'
    HomeKit Bridge: HomeKit Bridge is running the latest version, no update needed
    HomeKit Bridge : HomeKit Bridge is loaded and ready to use
    24 May 2019 at 12:04:10
    Trigger: Start system Homebridge [=> This is where I start a separate Homebridge server instance outside of Indigo <=]
    24 May 2019 at 12:05:05
    HomeKit Bridge Error: HomeKit server 'Casa Milagro HomeKIt Server' could not be started, please check the service logs for more information,
    now issuing a forced shutdown of the service to be safe.
    If you continue to have problems starting this server use the Advanced Plugin Actions menu option to rebuild the Homebridge folder.
    Instructions at https://github.com/Colorado4Wheeler/Hom ... dge-folder
    HomeKit Bridge: Attempting to stop 'Casa Milagro HomeKIt Server'
    HomeKit Bridge Error: Exception in hkfactory.send_refresh_to_homebridge line 177: HTTPConnectionPool(host='127.0.0.1', port=8445): Max retries exceeded with url: /devices/26e8fd7a8c2bb0241b4dab16e16ff364204ede07fd2e6554e05e8094db17f330 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x105ef6750>: Failed to establish a new connection: [Errno 61] Connection refused',))
    CODE: r = requests.post(url, data=payload, headers=headers)
    HomeKit Bridge Error: Exception in hkfactory.send_refresh_to_homebridge line 177: HTTPConnectionPool(host='127.0.0.1', port=8445): Max retries exceeded with url: /devices/26e8fd7a8c2bb0241b4dab16e16ff364204ede07fd2e6554e05e8094db17f330 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x105ef6ad0>: Failed to establish a new connection: [Errno 61] Connection refused',))
    HomeKit Bridge Error: Exception in hkfactory.send_refresh_to_homebridge line 177: HTTPConnectionPool(host='127.0.0.1', port=8445): Max retries exceeded with url: /devices/26e8fd7a8c2bb0241b4dab16e16ff364204ede07fd2e6554e05e8094db17f330 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x105ef69d0>: Failed to establish a new connection: [Errno 61] Connection refused',))
    HomeKit Bridge Error: Exception in hkfactory.send_refresh_to_homebridge line 177: HTTPConnectionPool(host='127.0.0.1', port=8445): Max retries exceeded with url: /devices/26e8fd7a8c2bb0241b4dab16e16ff364204ede07fd2e6554e05e8094db17f330 (Caused by NewConnectionError('<requests.packages.urllib3.connection.HTTPConnection object at 0x105ef6a90>: Failed to establish a new connection: [Errno 61] Connection refused',))
    HomeKit Bridge: HomeKit server 'Casa Milagro HomeKIt Server' has been stopped
    24 May 2019 at 12:05:54
    24 May 2019 at 12:06:09 [=>At this point I manually restart the Plugin from Indigo <=]
    HomeKit Bridge: Server 'Casa Milagro HomeKIt Server' has successfully started, you can use your HomeKit apps or Siri for this accessory [=> And, now it is running <=]
It is interestingvthe plugin fails right after I start a separate instance of Homebridge out side of Indigo (I needed to run a Homebridge plugin that is not supported by the Indigo Homeit plugin). Note, I am using different server identification, etc for the other server and, once the Indigo plugin is restarted, everything works fine.
Any ideas?
Sun May 26, 2019 6:23 am
Re: Startup problem
Have you tried putting a delay on the startup of the "outside" Homebridge, so that it doesn't start until the HKB devices are all running?
Sun May 26, 2019 7:50 am
berkinet offline
Re: Startup problem
No. But that's worth a try. What is interesting is this does not happen if I kill and restart Indigo, only on initial startup after rebooting the computer.
Mon Jun 03, 2019 8:12 am
Colorado4Wheeler offline
Re: Startup problem
What Diver said is a legitimate way to address the problem. The issue is that you are trying to start up a server instance before the plugin has finished initializing and that means that the built in HTTP server cannot answer requests yet, so when you try to start an HKB server in this fashion it cannot talk to the plugin and throws that error.
What is the purpose of hand-starting the HKB server in this way rather than just letting the plugin auto start your servers for you?
Mon Jun 03, 2019 8:29 am
berkinet offline
Re: Startup problem
Colorado4Wheeler wrote:
What Diver said is a legitimate way to address the problem. [... ...] What is the purpose of hand-starting the HKB server in this way rather than just letting the plugin auto start your servers for you?
Yes. Adding the delay fixed the problem. I am using a separate HKB instance to run the HomeBridge Doorbird plugin.
Mon Aug 12, 2019 12:41 pm
rehafer offline
Re: Startup problem
I’m having a similar problem with auto restart after a power failure. I’m using an app called Delay Start to delay the starting of Indigo for 3 min which fixes most problems except I have to manually reload the KKB plugin to get the servers running. The reload always works the first try. (I have too much experience with power outages) Any ideas?
