Takes three tries to get action to execute through Homepod.
Sun Feb 03, 2019 11:57 pm
P15-D24 offline
I have an Indigo action that automatically turns on my exterior lights 30 minutes before sunset. In HomeKit I've set up an action called "Outside Lights Off'. Siri via Homepod recognizes the command but the first two times it doesn't works. Siri thinks the action was successful on each attempt. On the third try the lights go out and I see it int the Indigo log. This is a pretty consistent bug.
Also it appears if I turn on the outside light via the defined "Outside Light On" action in HomeKit the light will then turn off correctly on the first voice command to Siri. Any idea what is going on and how to fix?
Running OS X 10.14.5 on 2018 Mac Mini, Indigo 7.3
http://www.p15-d24.com
Mon Feb 04, 2019 4:56 am
durosity offline
Re: Takes three tries to get action to execute through Homep
Does the command work first time if you do it via Siri on your phone?
Mon Feb 04, 2019 11:29 pm
P15-D24 offline
Shut off on the first try with iPhone Siri.
Need to do some additional tests to make sure the results are consistent.
