Front Door Lock and Garage Door
Mon Jan 21, 2019 7:36 am
Re: Front Door Lock and Garage Door
DaveL17 wrote:
That'll be a nice mental image to try to escape today.
:twisted: Ah the cracking sound of leather and.. Jay? :D
Sat Feb 09, 2019 11:46 pm
Memaddog offline
markmiller66 wrote:
Use the setting in the attached screen shot. Make sure you hit the "Upload Settings" after changing them.
Hello - I just updated from Indigo 6 to 7.3 and replaced my old HomeBridge command line solution to use the new HomeBridge plugin. Everything is flawless except for the garage door. I'm using a Insteon IO-Linc Controller with firmware 36 (i2 engine). I have tried the "legacy input sensor logic" option and Home app still shows the garage door as open. I did successfully "upload settings" for the IO-Linc after making the change and also reloaded the HomeBridge plugin to make sure everything was being 'read' correctly. I've gone back and forth hope it will suddenly work, but with no success. Any other suggestions or advice?
Update: I just noticed that the Insteon open/close (door/window) sensor I have on a door is also reversed in the Home app. When the door is open, Indigo reports it as "on", but the Home app shows it as closed.
