Errors on my Hue bedside lamp
Stopped plugin HomeKit Bridge
Downgrading plugin HomeKit Bridge to older version 1.0.2-b1 (previous version moved to trash)
Loading plugin "HomeKit Bridge 1.0.2-b1"
Starting plugin "HomeKit Bridge 1.0.2-b1" (pid 563)
HomeKit Bridge Caching all HomeKit Bridge devices...
HomeKit Bridge Error Exception in homekit.special_HSV line 2451: unsupported operand type(s) for /: 'NoneType' and 'float'
CODE: r, g, b = [x/255.0 for x in r, g, b]
For object id 986132826 alias 'Bedroom 1 Bedside Light Clive '
- Code: Select all
##### DEVICE DATA DUMP #####
address : 192.168.100.240 (ID 23)
batteryLevel : None
blueLevel : None
brightness : 0
buttonGroupCount : 0
configured : True
defaultBrightness : 100
description :
deviceTypeId : hueAmbiance
displayStateValRaw : 0
displayStateValUi : 0
enabled : True
energyAccumBaseTime : None
energyAccumTimeDelta : None
energyAccumTotal : None
energyCurLevel : None
errorState :
folderId : 1558050675
com.nathansheldon.indigoplugin.HueLights : (dict)
SupportsColor : true (bool)
SupportsRGB : false (bool)
SupportsWhite : true (bool)
SupportsWhiteTemperature : true (bool)
WhiteTemperatureMax : 6500 (string)
WhiteTemperatureMin : 2000 (string)
address : 192.168.100.240 (ID 23) (string)
bulbId : 23 (string)
defaultBrightness : 50 (string)
manufacturerName : Philips (string)
modelId : LTW012 (string)
nameOnHub : Clive Lamp (string)
rate : 1 (string)
savedBrightness : 254 (integer)
swVersion : 1.29.0_r21169 (string)
type : Color temperature light (string)
uniqueId : 00:17:88:01:02:1d:1b:e1-0b (string)
greenLevel : None
lastChanged : 2018-07-17 19:33:44
lastSuccessfulComm : 2018-07-17 19:33:44
ledStates : []
model : Ambiance Lights
name : Bedroom 1 Bedside Light Clive
onBrightensToDefaultToggle : False
onBrightensToLast : False
onState : False
ownerProps : com.nathansheldon.indigoplugin.HueLights : (dict)
rate : 1 (string)
pluginId : com.nathansheldon.indigoplugin.HueLights
pluginProps : com.eps.indigoplugin.homekit-bridge : (dict)
protocol : Plugin
redLevel : None
remoteDisplay : True
states : States : (dict)
alertMode : none (string)
alertMode.ui : none (string)
brightnessLevel : 0 (integer)
brightnessLevel.ui : 0 (string)
colorMode : ct (string)
colorMode.ui : ct (string)
colorTemp : 2732 (integer)
colorTemp.ui : 2732 (string)
effect : none (string)
effect.ui : none (string)
online : true (bool)
online.ui : True (string)
whiteLevel : 100.00000000 (real)
whiteLevel.ui : 100 (string)
whiteTemperature : 2732.00000000 (real)
whiteTemperature.ui : 2732 (string)
subModel :
supportsAllOff : False
supportsColor : True
supportsRGB : False
supportsStatusRequest : True
supportsWhite : True
supportsWhiteTemperature : True
version : None
whiteLevel : 100.0
whiteLevel2 : None
##### DEVICE SIMULATION DATA #####
Service :
alias : Bedroom 1 Bedside Light Clive
model :
subModel :
indigoType : indigo.DimmerDevice
pluginType : indigo.DimmerDevice.com.nathansheldon.indigoplugin.HueLights.hueAmbiance
type : Lightbulb
desc : Lightbulb
objId : 986132826
serverId : 181278911
invertOnState : False
convertFahrenheit : False
required : (List)
On : False
optional : (List)
Hue : 0.0
Saturation : 0.0
ColorTemperature : 140
Name
Brightness : 0
native : True
requiresPlugin : (List)
actions : (List)
Action : (HomeKitAction)
Characteristic : On
When : equal
Value : False (bool)
Value2 : 0 (bool)
Command : device.turnOff
Arguments : [986132826]
monitors : {986132826: 'attr_onState'}
Characteristic : On
When : equal
Value : True (bool)
Value2 : 0 (bool)
Command : device.turnOn
loadOptional : False
characterDict : (Dict)
On : False
