Indigo 6 Beta 6 and 7 Released
Thu Mar 07, 2013 5:48 pm
6.0 Beta 7 is now available for download.
Important: this version includes many Z-Wave related enhancements. Because of the nature of some of these changes, you might have to re-sync (via the device dialog) some of your modules. The devices that need to be re-synced will be shown in the Event Log, and communication with them will be disabled in Indigo until they are re-synced.
In addition to the major 6.0 improvements this update includes:
  • Added support for EZController / Z-Troller computer interface (minimum firwmare 1.17 required).
  • Added Z-Wave support for battery command class via a new batterLevel device state.
  • Added Z-Wave support for setting the wake interval of battery operated devices.
  • Added Z-Wave support for Aeotec Multi Sensor DSB05 (including temperature, luminosity, and humidity sensors).
  • Added Z-Wave support for Everspring door/window sensors SM103 and HSM02.
  • Added Z-Wave support for FortrezZ water and temperature sensor WWA-02AA.
  • Added Z-Wave configuration parameters (accessible via Edit Device Settings... button) for: Aeotec Multi Sensor (DSB05), Aeotec Door/Window Sensor (DSB041005), FortrezZ sensor (WWA-02AA), Evolve Lamp Module (LDM-15), GE Lamp Module (45602), ACT / HomePro Lamp Module (ZDM230), ACT / HomePro Dimmer Switch (ZDW120), GE Dimmer Switch (45606), Cooper / Evolve Dimmer Switch (RF9534DS).
  • Added support for new INSTEON module: Smoke Bridge for First Alert smoke and carbon monoxide detector.
  • Added support for new INSTEON modules: Micro Dimmer, Relay, and Open/Close (dual-band).
  • Added ability to change I/O-Linc Momentary relay duration via an action or the Interfaces->INSTEON/X10 Power Line->Set I/O Linc Momentary Duration... menu item.
  • Added auto-sizing of all plugin dialogs.
  • Fixed iTunes incompatibility introduced with iTunes 11. You may need to re-pair your Indigo device with iTunes 11.
  • Fixed bug in the Mac Indigo client that would cause it to hang if you had a lot of devices updating very frequently (like Timers).
  • Improved automatic version checking to never block server processing.
  • Improved plugin double-click installing to handle plugin alpha/beta version strings.
  • Changed UI description for dimmer ramp rate of 9 minutes in INSTEON link editor (some modules do not support it).
  • Device Collection: added validation of the pseudo on/off device config dialog and trapped some configuration errors.
Developer API Changes:
  • Plugin API version number has been incremented to v1.6.
  • Plugin API addition: added optional uiValue argument to device updateStateOnServer() method.
  • Plugin API addition: added sensorValue attribute to device sensor instances (sensor devices can now support onState and/or sensorValue states).
Beta 7 Change:
Shortly after release one of our users (thanks Dewster!) caught a problem with beta 6, so included in beta 7 is a tweak to updateStateOnServer() to better maintain backwards compatibility. Some plugins were having errors caused by the placement of the new beta 6 parameter, uiValue. Beta 7 resolves those errors.
