Indigo 7.3 Release Notes
Tue Apr 16, 2019 12:37 pm
7.3.0 is now available for download (you must be logged in to your Indigo Account to download). For an overview of the changes in this version, see our blog announcement here.
Note: This release may not be available to all Indigo 7 users, specifically those who have allowed their Up-to-Date Subscription to lapse. The downloads page will show if you are eligible for the latest release or you can also check the licenses page in your Indigo Account or use the Indigo 7(.X)->License Details... menu to see the status of your subscription.
Any maintenance releases of Indigo 7.3 (7.3.1, etc) will be outlined below this post on this forum topic.
A reminder on app and path names: we've made it easier for users to switch back to a previous Indigo version if they like. For this release, we've changed the install path to:
/Library/Application Support/Perceptive Automation/Indigo 7.3/
The installer is smarter than it used to be and now moves control page images over for you (among other improvements). The other change is that the Indigo Mac Client app is now named Indigo 7.3 to identify which client you're trying to launch. If you have problems upgrading from a previous version of Indigo then read through the appropriate upgrade section:
New General Features and Fixes
  • Added additional visual indicators to Plugin menu items to indicate if a plugin update is available in the Plugin Store (black arrow update is compatible, red arrow if update requires newer version of Indigo)
  • Added a new menu item on all Plugin submenus to show the plugin in the Plugin Store. If there's an update available the menu title reflects that.
  • Added a new column to the Plugins panel in the Indigo Preferences window that shows the latest version available in the plugin store. The Plugin name column now includes the version currently installed. Double-clicking on the new version number opens a browser to the Plugin Store page to download the new version.
  • Added visual indicators for each interface to indicate if they are enabled or not (green for enabled, gray for disabled).
  • Added several keyboard shortcuts in the Mac Client for items on the File, Plugin, and Help menus.
  • Improved Control Page editor handling of automatic caption name generation when changing devices and variables.
  • Cleaned up menus in the Mac Client to make them clearer and more concise. Also removed an extraneous menu item (Show Tool Bar) automatically added to the Edit menu by Sierra+.
  • Increased width of URL edit field for Refreshing Image URL coontrols in Control Page editor.
  • Improved Plugins->Reload Libraries and Attachments menu item to also stop and reload the python script executor.
  • Improved robustness of handling multiple fast plugin enable/disable requests.
  • Enabled modem drivers in the Insteon serial port popup.
  • Fixed bug in action panel UI that set incorrect scroll position for run sprinkler schedule table.
New Z-Wave Devices and Fixes
  • Added support for Aeotec Doorbell 6 (ZW162).
  • Added support for Dome Motion Sensor (DMMS1).
  • Added support for Dome Siren (DSM01).
  • Added support for Ecolink Door/Window Sensor (DW-ZWAVE2).
  • Added support for Ecolink Flood / Freeze Sensor (FLF-ZWAVE5).
  • Added support for Ecolink Motion Sensor (PIR-ZWAVE2).
  • Added support for Ecolink Motion Sensor (PIR-ZWAVE2.5).
  • Added support for Everspring Motion Sensor (SP816).
  • Added support for Everspring Doorbell (UTSE03A).
  • Added support for Everspring Door/Window Sensor (SM810).
  • Added support for Everspring Dimmer Plug (AD147).
  • Added support for Everspring In-Wall Remote Module (HAC01).
  • Added support for Express Controls Multisensor (EZMultipli).
  • Added support for Fibaro Carbon Monoxide Sensor (FGCD001).
  • Added support for Fibaro Wall Plug Relay (FGWPG111).
  • Added support for GE Smart Lighting and Appliance Control Receptacle Outlet (14288).
  • Added support for GE Smart Motion Sensor (34193 / ZW6302).
  • Added support for GE Hinge Pin Smart Door Sensor (32562 / ZW6301).
  • Added support for GE Smart Motion Switch (26931).
  • Added support for GE Smart Motion Switch (26933/ ZW3008).
  • Added support for GE Smart Plug-in Lamp Dimmer (28167).
  • Added support for GE Wall Outlet (12721).
  • Added support for GoControl/LinearLinc Door/Window Sensor (WADWAZ-1).
  • Added support for GoControl/LinearLinc Glass Break Detector (GB00Z).
  • Added support for GoControl/LinearLinc Multi Sensor (WAPIRZ-1).
  • Added support for GoControl/LinearLinc Relay Switch (WS15Z-1).
  • Added support for GoControl/LinearLinc Single Wall Outlet (WO15Z-1).
  • Added support for GoControl/LinearLinc Thermostat (GC-TBZ48).
  • Added support for HomeSeer Floodlight Sensor (HS-FLS100+).
  • Added support for HomeSeer Leak Sensor (HS-LS100+).
  • Added support for HomeSeer Motion Sensor (HS-MS100+).
  • Added support for HomeSeer Multisensor (HSM200).
  • Added support for HomeSeer Perimeter Water Sensor (HS-FS100+).
  • Added support for Leviton Appliance Module (DZPA1).
  • Added support for MonoPrice Smart Plug (HKZW-SO01 and HKZW-SO05).
  • Added support for MonoPrice RGB Smart Bulb (27482).
  • Added support for Neo CoolCam Multi Sensor (NEOEMS02Z).
  • Added support for Neo Door/Window Sensor (Z-Door-US / S1469).
  • Added support for Neo Single Relay Switch (NAS-SC01ZE).
  • Added support for POPP Flood Sensor (700052).
  • Added support for POPP Z-Rain (700168).
  • Added support for Ring Contact Sensor (4SD1S70EN0).
  • Added support for Sensative Temperature Sensor (Strips Comfort).
  • Added support for Steinel LED Floodlight (XLED home 2).
  • Added support for ZLINK Plug-in Appliance Module (ZL-PA-100).
  • Added support for ZLINK Plug-in Dimmer Module (ZL-PD-100).
  • Added support for Zooz Door/Window Sensor (ZSE08).
  • Added support for Zooz Outdoor Motion Sensor (ZSE29).
  • Added support for Zooz Siren (ZSE01).
  • Added preliminary support for GE Smart Fan Control (14287) - appears as a dimmer in Indigo but works correctly.
  • Added preliminary support for HomeSeer Fan Speed Controller (HS-FC200+) - appears as a dimmer in Indigo but works correctly.
  • Added support for new variant of Fibaro Double Relay (FGS222).
  • Added support for new variant of Fibaro Double Switch 2 (FGS223).
  • Added support for new variant of Fibaro Door/Window Sensor 2 (FGDW002).
  • Added support for new variant of Fibaro Leak Sensor (FGFS101 and FGFS111).
  • Added support for new variant of Fibaro Motion Sensor (FGMS001).
  • Added support for new variant of Fibaro Roller Shutter Controller (FGRM222).
  • Added support for new variant of Fibaro Single Switch 2 (FGS213).
  • Added support for new variant of Fibaro Smoke Sensor (FGSD002).
  • Added support for new variant of Fibaro Shutter Controller (FGR221).
  • Added support for new variant of Fibaro Wall Plug Relay (FGWP102).
  • Added support for new variant of Neo CoolCam Siren.
  • Added HomeSeer actions to control LED color of the HomeSeer Multisensor (HSM200), HomeSeer Fan Speed Controller (HS-FC200+), and Express Controls Multisensor (EZMultipli).
  • Improved support of Aeotec Water Sensor 6 (ZW122) - added Tamper device.
  • Improved support of Black Cat Double Relay Module (ZWBCL2).
  • Improved handling of Z-Stick controller sending bad/corrupt data to Indigo during communication initialization (devices are no longer disabled and initialization is retried after 10 minutes).
  • Improved error handling of socket errors when communicating to a remote Z-Wave Controller.
  • Fixed bug that caused RFC2217 remote serial port connections to fail to connect.
  • Fixed bug that caused Qubino Flush Micro Dimmer (ZMNHDD) temperature sensor state to not correctly update after a server restart.
  • Fixed bug that prevented incoming scene commands from updating the device's lastSuccessfulComm time stamp.
  • Added new Start Brighten, Start Dim, and End Brighten/Dim device actions.
New Insteon Device Features
  • Added several options to the INSTEON Execute Scene action UI: Scene Increase by 3%, Scene Decrease by 3%, Scene Start Increase, Scene Start Decrease, and Scene Stop Increase/Decrease.
  • Added new Set Siren Alarm Sound action and menu item to change the Insteon Siren between chime and siren.
  • Added new Set Siren LED Mode action and menu item to change the LED on the Insteon Siren between: On Solid, Blink on Insteon Traffic, or Off.
  • Added new Set OutletLinc Load Sense menu item and action to enable/disable load sense on the dual outlet OutletLinc.
Scripting, Developer and API Changes
  • We have bumped the Server API version to 2.1 - you can use this in your plugin if you want to conditionally hide/show any internal plugin updating (for older versions of Indigo that don’t have it built-in).
  • The installer now creates a new directory, /usr/local/indigo/, which contains command line tools useful for interacting with the Indigo Server.
  • Added indigo-host command line tool (see above) which will launch an interactive scripting environment. You may also pass -x and a script file, -e and a script string to be executed and -m followed by full method specifier ("module.method" or "package.module.method" for instance) followed by any number of space-separated parameters that will get passed to the specified method.
  • Added indigo-start and indigo-stop command line tools which will start and stop the Indigo Server process.
  • Added indigo-restart-plugin command line tool to restart a running plugin. You may pass --debug to restart the plugin in the debugger and --no_wait to make the script finish without waiting for the plugin to restart.
  • Added indigo-clean-and-zip-plugin command line tool to assist plugin developers with creating plugin releases.
  • The Scripts/Attachments folder in the install folder is now included in the Python paths. Python scripts and plugins can then import any python modules/packages that are in that directory. This will make shared functionalty easier to manage as part of your normal backup/restore/upgrade process.
  • Added new Insteon scene APIs: indigo.insteon.sendSceneIncrease, indigo.insteon.sendSceneDecrease, indigo.insteon.sendSceneStartChange, indigo.insteon.sendSceneStopChange.
Sun May 12, 2019 1:44 pm
Indigo 7.3.1 Release Notes
7.3.1 is now available for download (you must be logged in to your Indigo Account to download). This update includes the following changes:
  • Fixed bug that caused spurious error log messages when using the new new Start Brighten, Start Dim, and End Brighten/Dim device actions.
  • Added device timestamp updating after successful ping command response.
  • Added support to hide setpoint and mode logging for HeatIT Thermostat (TF021).
  • Added support for FortrezZ Flow Meter (FMI).
  • Fixed bug that prevented action to correctly set LED color mode for HomeSeer modules.
  • Fixed bug that caused thermostat operating state reports of 2nd stage heating to incorrectly update in Indigo as cooling.
  • Fixed bug that caused Ecolink Motion Sensor (PIR-ZWAVE2.5) motion state to not properly update.
  • Fixed bug that caused POPP Z-Rain (700168) rain fall/rate state to not properly update.
  • Fixed PyCharm debugging so it will work with PyCharm 2019.X
Users browsing this forum: Google Feedfetcher and 2 guests
