latest unifi 7.3.76 (Build: branch_7.3.76_19582_M) chaos
Wed Nov 30, 2022 10:28 am
dtich offline
hello karl et al. installed latest unifi build this am and since i get this in indigo log repeating:
Nov 30, 2022 at 8:18:03 AM
DSC Alarm Alarm Zone 'alarm/motion/living room (6)' Opened.
DSC Alarm Alarm Zone 'alarm/motion/living room (6)' Closed.
uniFiAP Error UNIFI executeCMDOnController error no json object: (wrong UID/passwd, ip number?192.168.100.100) ...>><<
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
100 63 0 0 100 63 0 176 --:--:-- --:--:-- --:--:-- 181
100 63 0 0 100 63 0 42 0:00:01 0:00:01 --:--:-- 42
100 63 0 0 100 63 0 23 0:00:02 0:00:02 --:--:-- 23
100 63 0 0 100 63 0 16 0:00:03 0:00:03 --:--:-- 16
100 63 0 0 100 63 0 12 0:00:05 0:00:04 0:00:01 12
100 63 0 0 100 63 0 10 0:00:06 0:00:06 --:--:-- 0
100 63 0 0 100 63 0 8 0:00:07 0:00:07 --:--:-- 0
100 63 0 0 100 63 0 7 0:00:09 0:00:08 0:00:01 0
100 63 0 0 100 63 0 6 0:00:10 0:00:09 0:00:01 0
100 63 0 0 100 63 0 6 0:00:10 0:00:10 --:--:-- 0
curl: (28) Operation timed out after 10146 milliseconds with 0 bytes received
Nov 30, 2022 at 8:18:35 AM
Received INSTEON "hvac/therm A" temperature changed to 69.0
100 63 0 0 100 63 0 23 0:00:02 0:00:02 --:--:-- 24
100 63 0 0 100 63 0 10 0:00:06 0:00:06 --:--:-- 10
curl: (28) Operation timed out after 10141 milliseconds with 0 bytes received
uniFiAP comsumeLogData excessive time consumed: 12.1[secs]; 192.168.100.11 ; len:9, lines:['Wed Nov 30 08:18:45 2022 daemon.info hostapd[1264]: ath1: STA 70:b3:06:82:70:16 IEEE 802.11: sta_s
uniFiAP comsumeLogData Total excessive time consumed: 12.1[secs]; 192.168.100.11 ; items: 5 len:2, lines:['Wed Nov 30 08:18:56 2022 daemon.info hostapd[1264]: ath1: STA 70:b3:06:82:70:16 RADIUS: starting a
Nov 30, 2022 at 8:19:14 AM
100 63 0 0 100 63 0 179 --:--:-- --:--:-- --:--:-- 182
100 63 0 0 100 63 0 41 0:00:01 0:00:01 --:--:-- 42
curl: (28) Operation timed out after 10134 milliseconds with 0 bytes received
any thoughts on this? not sure if this is a unifi issue, could be. the dashboard login is a bit laggy since the update... anyway, fyi. hopefully this is rectified in short order.
edit: seems perhaps the plugins curl call got itself in a bad state? i've restarted both unifi and the plugin again and *maybe* things are more stable. currently the error that was repeating in indigo log is not firing.. fingers x'd. fyi.
Wed Nov 30, 2022 10:40 am
dtich offline
Re: latest unifi 7.3.76 (Build: branch_7.3.76_19582_M) chaos
?: does it want https? does the plugin support this?
Wed Nov 30, 2022 11:09 am
dtich offline
NOPE. still happening.
there is a line in there about a specific AP, .11... not sure i understand it tho, something about log data... too full? not sure why that particular AP is pointed out. perhaps it's not relevant tho.
at any rate, nothing has changed in the system. and obviously i've upgraded version on unifi many many times since installing the plugin without this issue.
Indigo Cocoa client authenticated (192.168.100.127)
100 63 0 0 100 63 0 176 --:--:-- --:--:-- --:--:-- 180
curl: (28) Operation timed out after 10144 milliseconds with 0 bytes received
uniFiAP comsumeLogData excessive time consumed: 15.6[secs]; 192.168.100.11 ; len:2, lines:['Wed Nov 30 09:06:16 2022 daemon.info stahtd: stahtd[1261]: [STA-TRACKER].stahtd_dump_event(): {"me
uniFiAP comsumeLogData Total excessive time consumed: 15.6[secs]; 192.168.100.11 ; items: 1 len:2, lines:['Wed Nov 30 09:06:16 2022 daemon.info stahtd: stahtd[1261]: [STA-TRACKER].stahtd_dump_event(): {"me
100 63 0 0 100 63 0 190 --:--:-- --:--:-- --:--:-- 194
100 63 0 0 100 63 0 24 0:00:02 0:00:02 --:--:-- 24
Wed Nov 30, 2022 9:07 pm
dtich offline
switched read method to python, still throwing errors. fyi.
Nov 30, 2022 at 7:05:38 PM
uniFiAP Error HTTPSConnectionPool(host='192.168.100.100', port=8443): Read timed out. (read timeout=4.0); line#,Module,Statement:(532, 'send', 'raise ReadTimeout(e, request=request)')
Nov 30, 2022 at 7:06:09 PM
any thoughts on rectifying this? anything i can do on my end? thx!
