New Deployment with 7.39.373 issues
Mon Feb 28, 2022 12:41 am
chase offline
Hi
I am trying to get this working with a fairly complex UniFi system on a UDM Pro running version Network 7.0.23. The network has 4 VLANs, 5 Switches and 10 APs.
I am using Protect with the plugin (which is working as needed).
Getting things configured is a work in progress. As reported by others, the folder '/Library/Application Support/Perceptive Automation/Indigo 2021.2/Preferences/Plugins/com.karlwachs.uniFiAP/' was not created when the plugin started. I created it manually and the configuration would get a little further along.
I had a heck of a time getting the login configuration set as needed. I think I have the credentials and most fields with valid data, but I am not seeing any UniFi_System devices get auto created (Other than . This is strange as when I stop and start the plugin I can see the log entries showing the Listener Processes stopping for all the UniFi devices....
I am seeing client being created but these are only wireless. I have no evidence of a wired client being created.
Any suggestions?
Tue Mar 01, 2022 9:24 am
Re: New Deployment with 7.39.373 issues
could you do
menue/plugins/unifiap/print parameters to logfile
the click on # 1 and 2
and post as "code". please make sure you xxx the userid and passwords
you should get something like:
UniFi   =============plugin config Parameters========
debugAreas                             []
logFile                                /Library/Application Support/Perceptive Automation/Indigo 2021.2/Logs/com.karlwachs.uniFiAP/plugin.log
enableFINGSCAN                         F
count_APDL_inPortCount                 T
enableBroadCastEvents                  F
ignoreNeighborForFing                  T
expirationTime - default               120 [sec]
sleep in main loop                     5 [sec]
use curl or request                    curl
curl path                              /usr/bin/curl
cpu used since restart:                347:03.23
====== used in ssh userid@switch-IP, AP-IP, USG-IP to get DB dump and listen to events
UserID-ssh                             xx
PassWd-ssh                             xx
UserID-ssh-UDM
PassWd-ssh-UDM
read buffer size                       16384
promptOnServer 192.168.1.18            '8# '
promptOnServer 192.168.1.13            '7# '
pr...
and
UniFi    =============plugin config Parameters========  END
   uniFiAP
 ===== UniFi device info =========                              curr.;  exp;   use ping  ; use WOL;     use what 4;       WiFi;WiFi-max;    DHCP;  SW-UPtm; lastStatusChge;                              reason;     member of;
dev Name                       id:         MAC#             ;  status; time;   up;   down;   [sec];         Status;     Status;  idle-T; max-AGE;    chged;               ;                          for change;        groups;
AP_3_unifi                     1805049652  f0:9f:c2:d6:df:2f;      up;  150; False; False; no     ;  OptDhcpSwitch;           ;        ;      -1;     True; 01-27 17:35:22;                        Period Check;           lan;
UniFi-Mom-iMac                 1262616680  a8:60:b6:1b:62:8d;      up;  150; False; False; no     ;         SWITCH;           ;        ;      60;     True; 02-19 23:37:38;              Period Check SWITCH up;           lan;
UniFi-rpi-5                    925097363   b8:27:eb:5e:c7:ed;      up;  150; False; False; no     ;         SWITCH;           ;        ;      60;     True; 01-02 11:50:23;              Period Check SWITCH up;           lan;
I ned to see if your switch and controller and gateway are setup correctly
Q: do you have different userIDs passwords for setup on your controller for web access and ssh ?
then also set debug on for
numbers 2, 4, 7, 7.1
in config at the bottom
and post lines from
also some userid and password in there,
or may be better send it to
karlwachs at me com
Tue Mar 01, 2022 11:11 am
chase offline
Hi Karl
Emailing as the UniFi Device info text is HUGE....
I have different login credentials setup on the controller for web access and ssh ... They are tested and verified and I am getting feedback in the log that the plug in is able to log in and confirm the unifiedOS.
  uniFiAP                         getunifiOSAndPort cmd:https://10.0.0.1:443
  uniFiAP                         getunifiOSAndPort sucess: 10.0.0.1:443 ==>  osCode:200, OS:unifi_os
I have configured debugging as your request. What actions do you want the debugging text from?
